cbmeeks #1 Posted November 11, 2019 I'm *finally* getting around to assembling my PEB setup. I thought I had everything I needed until I realized I don't have a correct floppy disk cable. When I look at the connector of the floppy drive (Shugart 400L), I noticed the edge connector has a slot that is in a different location than the disk controller (PHP1240). Now, the 1240 has two connectors. One is the old style 5.25" like you see for DOS. But it also has a 34 pin "newer" style like for 3.5" drives. The 5.25" edge connector on the disk controller has the slot in a different location. However, I'm not sure if that even matters. I *DO* have a cable that goes from the 34 pin connector (newer style) and on the other end, has the female connector to the drive. It has no slot. Both ends fit wonderfully. The problem is that the cable is about 4 inches long. So it cannot reach. My question is, does anyone know the definitive "use this" cable for this setup? Do you have one you could part with? Thanks! Quote Share this post Link to post Share on other sites
+arcadeshopper #2 Posted November 11, 2019 I sell these in my storeSent from my LM-G820 using Tapatalk Quote Share this post Link to post Share on other sites
apersson850 #3 Posted November 11, 2019 You don't have to worry about the slots, if you make your own cable. Ribbon cables can easily be made at home. Push the connectors together in a vice. Since you don't have any tab for the slot, you have to figure out how to orient them properly. But since one side of the edge connectors are all ground connections, that's not difficult to find out. Quote Share this post Link to post Share on other sites
+OLD CS1 #4 Posted November 11, 2019 3 hours ago, apersson850 said: But since one side of the edge connectors are all ground connections, that's not difficult to find out. heheheh just do not try it out with an important disk in the drive. Since the signals are active-low, grounding them all out turns on the motor, selects the drive, activates the write gate, and sends a never-ending signal to the head. Whoops! Of the numerous drives from various brands with which I have worked, I can count on one hand the number which do not have pin 1 or pin 2 marked at the connector. Quote Share this post Link to post Share on other sites
apersson850 #5 Posted November 11, 2019 Without a disk in the drive, what happens is never ending spinning of the drive. But I meant that you can easily measure which side is ground, since each of the pins are the same. Quote Share this post Link to post Share on other sites
+OLD CS1 #6 Posted November 11, 2019 1 hour ago, apersson850 said: Without a disk in the drive, what happens is never ending spinning of the drive. But I meant that you can easily measure which side is ground, since each of the pins are the same. No, I get that, but not everyone does and sometimes even the best of us leave a disk in the drive when futzing about. (Fairly recently, actually... ::sigh::) And measure?? Brother, please! No one breaks out the multi-meter until it is far too late 1 Quote Share this post Link to post Share on other sites
apersson850 #7 Posted November 12, 2019 Oh yes, I do. But then I'm an electric engineer by profession. In Swedish Att mäta är att veta translates to To measure is to know in English. The phrase sounds better in Swedish, though. 1 Quote Share this post Link to post Share on other sites
cbmeeks #8 Posted November 12, 2019 Thanks everyone for the suggestions. I believe I may just pull the one out of my 486 and try that one. Thanks! Quote Share this post Link to post Share on other sites
+arcadeshopper #9 Posted November 12, 2019 Thanks everyone for the suggestions. I believe I may just pull the one out of my 486 and try that one. Thanks!No twist.. Sent from my LM-G820 using Tapatalk Quote Share this post Link to post Share on other sites
cbmeeks #10 Posted November 13, 2019 Ah, good point. I forgot about the twist. Quote Share this post Link to post Share on other sites
+arcadeshopper #11 Posted November 13, 2019 I found old cables are brittle and old connectors do not stay connected when you take them off and put them back on that's why I make brand new cables and attach new connectors with a proper crimper and sell them in my store.Sent from my LM-G820 using Tapatalk Quote Share this post Link to post Share on other sites
cbmeeks #12 Posted November 13, 2019 I used to make SCSI cables by hand many moons ago. We had a special crimper for the job that made it easy. I used to also make network patch cables by hand too. Which sounds silly today but back then, network cables were expensive relatively speaking. Quote Share this post Link to post Share on other sites
+OLD CS1 #13 Posted November 13, 2019 37 minutes ago, cbmeeks said: I used to make SCSI cables by hand many moons ago. We had a special crimper for the job that made it easy. I used to also make network patch cables by hand too. Which sounds silly today but back then, network cables were expensive relatively speaking. A lot of cabling guys I know still make their own cables when the standard lengths will not work. Not quite a lost art, yet. I lost my IDC crimper a long time ago. Still sad about it. Quote Share this post Link to post Share on other sites
cbmeeks #14 Posted November 14, 2019 I actually enjoyed making my own cables. In fact, I really need to start doing it again. I have all of the stuff to make network patch cables but I still find myself going to my junk drawer and finding a pre-made one that is usually 40% too long. So I just roll it up and velcro it off. Instead of making a custom length. Guess I got lazy. Quote Share this post Link to post Share on other sites
apersson850 #15 Posted November 15, 2019 I'm repairing my network cables, when the little locking spring falls off the connector. Quote Share this post Link to post Share on other sites
