Lardo Boffin
Atari 800 - SIO2SD not working
Posted (edited)
5 hours ago, Lardo Boffin said:
That is an impressively clear screen output. 😃
How do you do it?
The 800 has @tf_hh's very nice SCCC, and it's connected to the monitor using the equally nice RetroTink 2K Pro 🙂
There's a small issue with some light vertical bands on the display when using s-video that I'd like to fix eventually, but it looks fantastic otherwise, and obviously a huge improvement over using composite video on and old TV set...
I still have to adjust the colors either on the 800 or the monitor - not sure which.
And, of course, back to the topic of this thread: it'd be great if we could get sources for the eight-year-old SIO2SD configurator from "Pajero/MadTeam"!
Edited by jamm
1 hour ago, jamm said:
The first picture is from "Atari Control Picture".
The second one is from si224.com
Thanks, I don't have sdx so only used the first one.
I'm guessing there is something amiss with my pal 800?
You don't need SDX for SI224 - load it as you would any other Atari executable binary.
As for your display; are you referring to the vertical bar in the middle?  I don't know if that's normal on PAL, but someone else can certainly answer that easily.
Thanks again, yes I was referring to the vertical line
That's normal - it happens because the luma bits go from 0111 to 1000 for that brightness.  The UAV video mod prevents this, but almost all stock Ataris will exhibit that line.
Ah - so I don't see it because of the SCCC!
Cool, thanks for the info
Very neat explanation, and as you might expect, there's a fainter version of the line going from 0011 to 0100. 👍
