Mehridian Sanders
oh boy oh boy the boards are coming!
I ordered 2 PCB's recently. The FinalGrom99 and the 32K Sidecar, they will be here on Friday!! Looks like I get to solder some components! Thanks to all here for the information they have gathered and for the time they put into this system.
  • Like 5
7 hours ago, wierd_w said:
Dear lord...
That iron clearly is not plugged in.  She looks entirely too calm for that the be the case. :P
Haven't you heard?  That's the new dual soldering iron and continuity tester.
Beery
It's also a cheap radio shack iron at that!  I guess if you are just testing the operator for function you dont need a quality iron, but still..
I did that once(well, more than...)
first thing I noticed was "what's that smell?"
one time i noticed the noise
THEN I noticed the obvious
9 hours ago, OLD CS1 said:
Who takes these pictures?  Who does the proofing?  I see at least four things wrong with this photo, there may be more.  Can you find them all?
I can try.
1) Where's the hot workstation? No sponge, no solder wick, no solder, no noclean flux, no temperature control, nothing!
2) Board on bare plastic table. Silly human, ESD aint just for kicks!
3) Really, didn't your mom tell you not to hold onto the business end of hot tools?
4) You DO know that applying direct heat to a coin cell battery will make it explode, right? That you should remove it from the socket if you are gonna reflow the socket? Right?
5) Why are you using the iron on THAT side of the board? That iron is not the right tool for surface mount work..
6) The side of your iron is laying on the PCI slot.  You know that will damage the slot, right?
(I am sure there are more, but that's just a quickie rundown of the obvious things I see)
Ok I went to Mouser for my parts for the FG99.. the github lists:
1x Atmel ATmega 328P (TQPF-32)
When I look for that the closest I can find for that is :
ATmega3208 (TQFP-32)
Is this the same processor or a child of it's progenitor?
- Wearing protective glasses (don't know whether this is mandatory for soldering workplaces)
- Missing air ventilation (I'm quite sure this required for professional workplaces here)
- No grounding strap
Definitely not the same processor.  328 is used in the Arduino Unos, though typically as a DIP32.
68747470733a2f2f692e696d6775722e636f6d2f
vs
I would note that the glasses are yellow tinted, which is typically for outside use.  When soldering, I'd like to the chips unhindered as much as possible.  At least the people in the other pictures are using clear glasses.
Here are results for 328P and 328PB.  PB adds 2-wire capability and a watchdog timer and leaves off the DAC.  AU vs AN is a difference of temperature tolerance.  AN can take up to 105C while AU only handles 85C.  R means that it's packaged as a reel instead of a tray.
https://www.mouser.com/Semiconductors/Embedded-Processors-Controllers/Microcontrollers-MCU/8-bit-Microcontrollers-MCU/_/N-a85ik?P=1z0y146&Keyword=atmega328p&FS=True
Edited by ChildOfCv
Perfect ... difference in price for 20C extra heat protection is a dime... I think I can spare the dime, and go with the AN, Thank you kindly.
I only see one thing wrong.
-Everything.
This reminds me of some rumors that NASA uses the movie "Armageddon" for job candidate assessment, who have to name all the factual errors they spot while watching the movie. (I mean, this is not too hard, first time I had pressure marks on my face from repeated facepalming.)
