clth
dungeon crawler attempt
Hi,
i've been occasionally working few months on DM styled dungeon crawler. Kind of fed up with it so time to take a break and post results :). There is lot to improve in terms of size and speed but it did come out quite nicely i think.
game.obx
Edited by clth
updated program fle
  • Like 11
12 minutes ago, Justin Payne said:
Looks great! What's becoming a struggle for you?
It is character mode based and there was needed lot of preprocessing of tiles, choosing right view size, scene grid etc for it to look good and still have room for other content than wall tiles. There was already several iterations and every one needed custom fitting which easily becomes chore. Slowly approaching fun part of it i hope :)
Edited by clth
typos
Well, keep at it. I look forward to playing it. Did you design a map builder program or are you doing it by hand?
Looks really good!  Have you considered using a narrow playfield for the display?  With a display area that's 32 bytes wide, some transformations / calculations might be easier and faster.
Actually using TILED - https://www.mapeditor.org/ ,trying to offload as much work possible to existing tools.
Not sure what you mean. It is basically text mode with hardcoded charsets - nothing here to transform/calculate.
Would it help if you had other contribute maps. Also, does the game have any sort of story?
Edited by Justin Payne
7 hours ago, clth said:
Hi,
Looks good !
Please finish it :)
We need more rpgs on atari.
Looks amazing! Btw, if you are curious how Dungeon Master maps and data structures are organized in original game, there is a lot on the DM fan page e.g. http://dmweb.free.fr/?q=node/217
Btw, the game.obx when executed shows wrongly rendered display for me.
Edited by ilmenit
Hi, can you please post screenshot of wrongly rendered screen and/or steps to reproduce? Thanks!
Yes, there is this possibility but bit too early for that. Also, there is no story - still kinda trying out if i can get features planned done.
9 hours ago, FifthPlayer said:
It looks like the players and missiles are available to render content items in addition to wall tiles.
Yep, just not sure how use them. I dont know much about atari hardware but presented width of 8 pixels makes them very limiting and unusable for me.
This is how it looks like when executed in Altirra (different settings produce the same results).
10 minutes ago, Bill Lange said:
I was a play-tester on a Palm Pilot game called Dragon Bane II that had this look back in the early 2000s.
http://www.mythological.com/db2.htm
Looks nice though i cant get anywhere near that visuals :) I've got somewhere my my palm T2, there were some nice RPGs on palm for sure.
Thank you, reproduced just fine. Looks like DLI timing issue, should be fixed in file on first post.
Edited by clth
Looks as a really good start for DM game! What language do you use? The drawing is fast for fluent move but slow enough to require a double buffering. I really like how you organized the graphics to fit the byte boundaries.
It is done in Mad Pascal but except DLI routine there is nothing written in assembler so i believe there is lot of room to improve and make scene drawing almost unnoticeable even without double buffering. What will be bit of a challenge is to get on screen at most 6(2x3) 4-directional enemy sprites.
Edited by clth
In fact black and white version graphics reminds Atari attempt.
Stores don't work. Is it available for free now?
I don't think Dragon Bade II hasn't been available for a very long time. There are some tools and other ideas on the site that might be useful.
Is it because of the 128 chars in font set? Don't you use different font sets in different lines, changed in DLI?
For speed up of drawing, if you use multiplication (*40 for screen pos) I recommend a lookup table. In my project written in C for drawing I use:
// mul_lookup40 for mul [0,23]
#define SetChar(x,y,a) video_ptr[(x)+mul_lookup40[(y)]]=(a);
unsigned mul_lookup40[] = {
    0, 40, 80, 120, 160,
    200, 240, 280, 320, 360,
    400, 440, 480, 520, 560,
    600, 640, 680, 720, 760,
    800, 840, 880, 920
Edited by ilmenit
    800, 840, 880, 920
Yes, at this moment 7 charsets with varying height and all are already 40-50% full. With 4-directional  9*9 tiles big is impossible to have enemy sprites in charset more than few at once. Only option is to have reserved tiles in charset and and copy to them from normal memory as needed - which could be quite bottleneck. Having various premade tables is definitely way to go, already doing so alot.
