tschak909
#FujiNet - a WIP SIO Network Adapter for the Atari 8-bit
in my humble opinion, absolutely none. It's a power suck, and given how utterly awkward the SDrive-Max is to use, I'm completely turned off on the idea.
-Thom
-Thom
Oh, I just ordered it because it was 'neat'.  I can always order another one.  Need to find the rest of the parts anyhow, which I may or may not already have.  At least I can 3d print my own SIO connectors, and don't have to butcher an SIO cable...
I am very glad that people are going out and building these things. Build on! Build 'em for your friends!
We will release a completed product eventually, but it's more important to me that this thing get used and in the hands of those who can do neat things with it.
-Thom
@jeffpiep is checking in the now completed Atari 822 printing emulation, which now includes the 240 pixel wide graphics possible with this printer.
The secret? The Atari 822 firmware has an additional write command 'P' which accepts 240 pixels of graphic data per line, 1 bit per pixel, nicely mapping to a graphics 8 display, if flipped on its side, as seen in this test print.
Hi,
    Would it be possible to overload the "Next ATR" button functionality, so that if you have defined disk slots, e.g. D1=AA.ATR, D2=AB.ATR, you cycle those ATRs, if you only have slot D1 defined, you cycle to next ATR file in the current directory. Personally I would put all ATRs from a multi disk product in the same directory (and only those ATR's), and only define one disk slot, which I would boot from.
   Also, is there any progress on a public design for ESP32 boards that can be sent off and made up (ideally one that doesn't involve the word "eventually").
    I agree that the SDrive Max touch screen can be a little fiddly, but I've just asked @kbr if he can replace it with a Next Atr button, and use the SDrive menu program on the Atari for everything else. I think it would be fairly straightforward, but I don't know the electronics to do it, and would need the electronics done before I could hack the SDrive firmware.
Edited by E474
1 hour ago, E474 said:
Hi,
It could be possible to overload the single button press, would be interesting for further investigation, as soon as I get some of the other bits of functionality dealt with, I still need to make CONFIG handle more than 16 files, and directories, etc.
As for the board: Paging @mozzwald :)
-Thom
depending on what's configured in the slots/fujinet parms.... it could intelligently decide what the button does... as in overlay...
Ordered the parts for an ESP32 build. Are you still developing for esp8266 or is the esp32 now the main target ?
16 hours ago, E474 said:
Hi,
I created an SDRIVE, with no display and only one button, a reset. :)  it loads the menu and I use the keyboard to select a disk image on screen.  If I want to select a different disk image to boot from I reset the arduino so all 4 of my disk selections are dropped and I can reload them :) not sure if this is helpful, but it does seem to work ok :).
Edited by Waltermixxx
Hi,
    @kbr pointed out to me via PM that the micro sd card is on the screen. On the other hand there is a micro-USB connector on the Arduino that I currently use for power, not sure if I could use the barrel connector instead, and connect a USB memory stick using an OTG cable in the microUSB connector?
   I think I would wire up 2 buttons:
    - reset
    - cycle ATR
    If I could set everything else up via the 8-bit menu program, I think that would be all you need. You could probably get away with not having a reset button if you powered down each time, but I think there is a reset button on my Arduino anyway.
   Just out of curiosity @Waltermixxx, how do you store ATR images if you don't have a screen with a microSD card on it?
   Also, sorry for (slightly) hijacking the fujinet thread.
tap for atr cycle, hold for reset... always a way to get more out of a button... :) double click...
Edited by _The Doctor__
A reminder, there are two buttons. Currently one is the RESET button, pressing it causes device to reset, which re-mounts CONFIG.
The other is the disk rotate button, which rotates each disk entry into the next contiguous slot, the edge of the rotation is the first found blank slot.
-Thom
make that first found unoccupied slot :)   empty or blank ATR's exist... it will trip someone up otherwise.. inevitably
the SDrive automatically loads the menu program, and the Atari boots to that,  i use the menu program to load all 4 disk drive slots, browsing through the files on the TV/monitor.   Then i press the reset and it boots from the image I selected for Drive 0.    I put the disk images on the SD card from my windows PC,  i load up the sd card, then put it in the headless Sdrive. :)  (I hope I understood the question correctly) Cheers.
Just a thanks to the guys developing this,  another thing to keep us busy  Cheers guys.
Add pics.
*deep-breath*
If you watch my vid on disk swapping, you can see the behavior.
To fully articulate the feature's description:
The rotate's edge is the first unoccupied slot, some examples:
D1 DiskA.atr
D2 DiskB.atr
D3 DiskC.atr
Hit rotate, it becomes
D1 DiskB.atr
D2 DiskC.atr
D3 DiskA.atr
Hit rotate again, it becomes
D1 DiskC.atr
D2 DiskA.atr
D3 DiskB.atr
Hit rotate again, and we are back as we were
D1 DiskA.atr
D2 DiskB.atr
D3 DiskC.atr
If there are gaps, the first gap becomes the edge of the rotation, so e.g.
D1 DiskA.atr
D2 DiskB.atr
D3 DiskC.atr
D4 --- BLANK ---
D5 SomethingElse.atr
D6 AndAnotherThing.atr
D1 DiskB.atr
D2 DiskC.atr
D3 DiskA.atr
D4 -- BLANK ---
D5 SomethingElse.atr <-- still in same place
D6 AndAnotherThing.atr <-- still in same place
So as you can see, anything beyond the blank slot is unaffected. This was literally put in to handle games and programs that only support a single drive. e.g. games, or productivity software that expects you to swap out data disks.
-Thom
