tschak909 Posted April 24, 2020 Author Share Posted April 24, 2020 @jeffpiep how do we set the printer to one of the PDF printer emulations? -Thom Quote Link to comment Share on other sites More sharing options...
manterola Posted April 25, 2020 Share Posted April 25, 2020 Hi All, I tried the comm.atr image in FujiNet.online. The problem was that I need no space between the atdt command and the address. Now it is working. Thanks Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 25, 2020 Author Share Posted April 25, 2020 1 minute ago, manterola said: Hi All, I tried the comm.atr image in FujiNet.online. The problem was that I need no space between the atdt command and the address. Now it is working. Thanks sigh, again, manterola, please try the N: version on atari-apps.irata.online -Thom Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 25, 2020 Author Share Posted April 25, 2020 #FujiNet #Atari8bit. Now that the SIO layer for the N: device is mostly stable, I have started on the third re-write of the CIO handler, shown here loading a BASIC program over HTTP and doing TCP input from BASIC. 5 Quote Link to comment Share on other sites More sharing options...
jeffpiep Posted April 25, 2020 Share Posted April 25, 2020 2 hours ago, tschak909 said: @jeffpiep how do we set the printer to one of the PDF printer emulations? -Thom Sorry about that! We need to make a simple web interface to allow switching printers. Change line 162 in main.cpp to sioP.connect_printer(new(atari1027)); 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 25, 2020 Share Posted April 25, 2020 so we could use an atari 8 bit based browser to config the switching of printers? rather than some method directly from the Atari to the fujinet. 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 25, 2020 Author Share Posted April 25, 2020 basically, either: * From Config, like everything else, or * From the web browser connecting to the fujinet, or * Via an XIO call once I get the CIO handler done. -Thom 3 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 25, 2020 Author Share Posted April 25, 2020 It must be understood that everything that can be done via CIO on this device, can be done via SIO, virtually all of the device functions are done via SIO and there are absolutely no hidden functions, as every SIO command is slated to be documented with parameters.. so virtually everything that can be done in CONFIG, can be done in other programs, as well. This is deliberate. -Thom Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 25, 2020 Author Share Posted April 25, 2020 #Atari8bit #FujiNet I finally folded in RFC compliant URL handling into network.cpp and the protocols, which allows for e.g. URL prefixing to work, so that DOS can handle Network URLs! 5 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 25, 2020 Share Posted April 25, 2020 (edited) Now you've got Einies' attention, he's got his eyes open, one ear pointing up, and he's sitting upright. You're really starting to crush it! Great Job! -Doc Brown aka _The Doctor__ Edited April 25, 2020 by _The Doctor__ 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 25, 2020 Author Share Posted April 25, 2020 Thanks! It will take some time to work through all of the details (so many edge cases in the FMS, and lots of complex edge cases for protocols like HTTP, and I still have to fold in SSH and FTP support...) but I am trying to prove that this will work. -Thom Quote Link to comment Share on other sites More sharing options...
+MrFish Posted April 25, 2020 Share Posted April 25, 2020 One useful thing you could do, is have NPrefix utilize a config file where a default URL can be specified that would get autoloaded when NPrefix is run. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 25, 2020 Author Share Posted April 25, 2020 good suggestion. will see how best to implement. for CLI DOSes this just is part of your startup script. -Thom Quote Link to comment Share on other sites More sharing options...
evilmoo Posted April 25, 2020 Share Posted April 25, 2020 On 4/19/2020 at 11:16 AM, ivop said: I have been thinking about creating alumin(i)um molds Won't all that metal interfere with the wifi signal? Quote Link to comment Share on other sites More sharing options...
StickJock Posted April 25, 2020 Share Posted April 25, 2020 59 minutes ago, evilmoo said: Won't all that metal interfere with the wifi signal? The molds are metal. Then you cast your plastic shells inside the metal molds. Quote Link to comment Share on other sites More sharing options...
evilmoo Posted April 25, 2020 Share Posted April 25, 2020 15 minutes ago, StickJock said: The molds are metal. Then you cast your plastic shells inside the metal molds. It is all so clear now. Thanks for the explanation. Quote Link to comment Share on other sites More sharing options...
manterola Posted April 25, 2020 Share Posted April 25, 2020 22 hours ago, tschak909 said: sigh, again, manterola, please try the N: version on atari-apps.irata.online -Thom Is it the plato.atr image there? I tried the plato inside comm.atr which I assume is the r: version (with altirra r: handler) I was able to connect at 9600bps. I typed atdtirata.online:8005 to get connected. It was great, super fast. The plato.atr in atari-apps server got me to the first black screen with white characters but I couldn't pass that... I was assuming that th platoterm in atari-apps sets everything up for the n: device to connect to irata.online plato server. Anyway, don't worry about it since I was just curious about the current state of FujiNet. Regards! Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 25, 2020 Author Share Posted April 25, 2020 5 minutes ago, manterola said: Is it the plato.atr image there? I tried the plato inside comm.atr which I assume is the r: version (with altirra r: handler) I was able to connect at 9600bps. I typed atdtirata.online:8005 to get connected. It was great, super fast. The plato.atr in atari-apps server got me to the first black screen with white characters but I couldn't pass that... I was assuming that th platoterm in atari-apps sets everything up for the n: device to connect to irata.online plato server. Anyway, don't worry about it since I was just curious about the current state of FujiNet. Regards! Yup, it's there, and I just made a series of changes to the N: device to handle a new URL structure. I have updated the disk image there, and it should work again. -Thom Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 26, 2020 Author Share Posted April 26, 2020 #Atari8bit #FujiNet The N: device will be a complete CIO device exposing all of the modern network protocols to the Atari and its operating system. Shown here is the ability to copy files to and from HTTP and TCP connections in various DOSes. 3 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 26, 2020 Share Posted April 26, 2020 old video play just fine , but this last one says it can't find any blah blah html5 but the youtube checker says I'm all good and can enjoy youtube so.. wtf... wonder if my browser broke... Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted April 26, 2020 Share Posted April 26, 2020 56 minutes ago, _The Doctor__ said: old video play just fine , but this last one says it can't find any blah blah html5 but the youtube checker says I'm all good and can enjoy youtube so.. wtf... wonder if my browser broke... It worked just fine using New Moon on XP32. :) Quote Link to comment Share on other sites More sharing options...
+MrFish Posted April 26, 2020 Share Posted April 26, 2020 Fine on Win7 64-bit with Opera. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 26, 2020 Share Posted April 26, 2020 it's working now.... Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 26, 2020 Author Share Posted April 26, 2020 #FujiNet #Atari8bit I have written a simple terminal emulator to work through the details of the CIO portion of the N: device. Still trying to resolve interrupt issues, but shows what can be done with very little effort. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted April 26, 2020 Share Posted April 26, 2020 silly control M;s :-), Quote Link to comment Share on other sites More sharing options...
