mozzwald #1376 Posted August 9, 2020 6 minutes ago, DrVenkman said: What's the point of setting the time for FujiNet? And for that matter, is there supposed to be a dropdown with timezones or are we supposed to enter text? Personally, I can't ever recall how many hours I am minus-GMT because of stupid DST ... It's used for Apetime. Clicking the ? takes you to a page with info about the timezone scheme. I happen to have a list of timezones that I used for openwrt which is probably more useful http://mozzwald.com/zipit/openwrt/openwrt-tz-data.txt 1 Quote Share this post Link to post Share on other sites
tschak909 #1377 Posted August 9, 2020 2 minutes ago, mozzwald said: It's used for Apetime. Clicking the ? takes you to a page with info about the timezone scheme. I happen to have a list of timezones that I used for openwrt which is probably more useful http://mozzwald.com/zipit/openwrt/openwrt-tz-data.txt Actually I can parse that into something more palatable. -Thom 1 Quote Share this post Link to post Share on other sites
StickJock #1378 Posted August 9, 2020 7 minutes ago, tschak909 said: The text field is preliminary, and will be replaced with a better drop-down, but e.g. it accepts TZINFO identifiers. * EST5EDT for Eastern * CST6CDT for Central * MST7MDT for Mountain * PST8PDT for Pacific. These identifiers take DST into account. I'm guessing that the time will be displayed wrong for Arizona, which stays on MST and doesn't use MDT? Quote Share this post Link to post Share on other sites
tschak909 #1379 Posted August 9, 2020 1 minute ago, StickJock said: I'm guessing that the time will be displayed wrong for Arizona, which stays on MST and doesn't use MDT? in which case, the TZINFO MST would be appropriate. -Thom Quote Share this post Link to post Share on other sites
jamm #1380 Posted August 9, 2020 (edited) 1 hour ago, StickJock said: I'm guessing that the time will be displayed wrong for Arizona, which stays on MST and doesn't use MDT? The letters actually don't matter - they're more there for human readability. It's only the number that matters. For example: MST+7 -- This says you're 7 hours west of UTC and you don't observe DST MST7 -- This is the same ABC7 -- This is also the same XYZ7 -- Same... ARIZONA7 -- Same! MST-7 -- You're 7 hours east of UTC, probably somewhere in Russia or Vietnam MST+7MDT -- This says you're 7 hours west of UTC and that you change your time by 1 hour during DST MST7MDT -- This is the same MST7MST -- This is also the same MST7ABC -- Same! ARIZONA7WILDCATS -- SAME! The reality is that time zones, and, more importantly when DST time starts and ends for your particular region, are not only complicated, but they change from year to year and region to region. So there's no reliable way to compute them without a database or rule set that describes them, and that database needs to be updated as things change. "Full size" operating systems will have a database like this from which you can pick a location (e.g. "USA/Phoenix") and the TZ and DST rules for that particular location have been helpfully provided by someone. They'll be out of date (ha!) sooner or later, so unless updates are provided somehow, you'll find the operating system will not switch to DST time on the correct dates. Notice in the examples above we didn't specify when DST starts or stops. There are built-in defaults: if you specify any letters after that number, then you observe daylight savings that changes the time by one hour starting on the first Sunday in April at 2:00AM and ends on the last Sunday in October at 2:00AM. (The specific defaults chosen can change from one operating system to another.) If those defaults don't work for you and you want to provide the correct details, you can do so like this: MST+7MDT+6,M5.1.0/01:30,M9.1.0/1:30 That says you're 7 hours west of UTC during standard time, and you're 6 hours west of UTC during daylight savings. Daylight savings starts on the first Sunday of May at 1:30AM and ends on the first Sunday of September at 1:30AM. The "MST" and "MDT" there are just to give humans something to read. Anyway - I thought that was an interesting diversion... We'll put a drop-down list in the web interface to make it easy to pick something for most people, and you'll be able to override it manually if those options don't meet your needs. Edited August 9, 2020 by jamm 3 Quote Share this post Link to post Share on other sites
Fierodoug5 #1381 Posted August 9, 2020 2 hours ago, jamm said: I added a couple of font files that probably put things over the edge on WROOM boards. If you remove the two TTF files in the /DATA/WWW folder you should be fine and it won't affect operation. Yup, that fixed it. Thanx 1 Quote Share this post Link to post Share on other sites
leech #1382 Posted August 9, 2020 3 hours ago, tschak909 said: It provides correct time e.g. in SpartaDOS. #FujiNet will respond to APE Time device requests with a time pulled from an NTP server. The text field is preliminary, and will be replaced with a better drop-down, but e.g. it accepts TZINFO identifiers. * EST5EDT for Eastern * CST6CDT for Central * MST7MDT for Mountain * PST8PDT for Pacific. These identifiers take DST into account. It is one of those "why not?" features. -Thom Plus now I know I'm in the same TZ as mozzwald Now to set a cron to back up configs... Quote Share this post Link to post Share on other sites
tschak909 #1383 Posted August 9, 2020 #Atari8bit The rewrite for #FUJINET CONFIG is nearing completion, and is now supporting directory pagination, and mounting long filenames! Now to implement the rest... 5 Quote Share this post Link to post Share on other sites
Mathy #1384 Posted August 9, 2020 Hello guys DST in Central Europe is always from the last Sunday of March (02:00 AM) until the last Sunday of October (03:00 AM (first time the clock turns 03:00 AM)). Sincerely Mathy Quote Share this post Link to post Share on other sites
StickJock #1385 Posted August 10, 2020 The US changed the DST dates several years ago to start earlier and end later. It screwed up devices that had the DST "smarts" built in that used the historical dates. Quote Share this post Link to post Share on other sites
+DrVenkman #1386 Posted August 10, 2020 2 hours ago, tschak909 said: #Atari8bit The rewrite for #FUJINET CONFIG is nearing completion, and is now supporting directory pagination, and mounting long filenames! Great! This is the single biggest remaining hole in functionality for probably the vast majority of users. Quote Share this post Link to post Share on other sites
tschak909 #1387 Posted August 10, 2020 #Atari8bit #FUJINET Creating New Disks is now in a much saner place in the CONFIG rewrite, as part of the disk image list, providing both the host slot and a visible context for the new disk image. 7 Quote Share this post Link to post Share on other sites
tschak909 #1388 Posted August 11, 2020 given that we should show the type of files in the disk image window, and that we have a limited amount of available text space (40 columns), I'm thinking that there needs to be custom 16 pixel wide glyphs (two character cells together) to show each disk type, SD, DD, etc. Am wondering if maybe a graphical form could be done that makes sense for all the different disk types? I had initially done a set of glyphs like this: but they smudge like crazy on composite displays. Anybody have any ideas? -Thom Quote Share this post Link to post Share on other sites
luckybuck #1389 Posted August 11, 2020 Your 1st try fits best, so I think. We have MD and ED meaning the same in your case: 140K. To avoid double meaning, the actual number does the job best. Key, to my mind is, to get the needed info in a blink of an eye. If we change to symbol language, like in the cult movie Idiocrazy, we risk to be 500 years ahead of our time... 2 Quote Share this post Link to post Share on other sites
DjayBee #1390 Posted August 11, 2020 Why don't you just use letters and digits? S, E, D, 3, 7, H A second letter would render the display unreadable. Quote Share this post Link to post Share on other sites
+DrVenkman #1391 Posted August 11, 2020 I’ve seen lots of Github activity over the last couple days. Good things happening, it looks like. 1 Quote Share this post Link to post Share on other sites
manterola #1392 Posted August 11, 2020 (edited) On 8/9/2020 at 11:25 AM, jamm said: I added a couple of font files that probably put things over the edge on WROOM boards. If you remove the two TTF files in the /DATA/WWW folder you should be fine and it won't affect operation. I did what you suggested and now it fits in the SPIFFS. Thanks! I have a question, though: I think it is possible to make the SPIFFS "partition" larger, and still fit the "firmware" in the WROOM memory. Or am I wrong? Edited August 11, 2020 by manterola Quote Share this post Link to post Share on other sites
mozzwald #1393 Posted August 11, 2020 2 minutes ago, manterola said: I did what you suggested and now it fits in the SPIFFS. Thanks! I have a question, though: I think it is possible to make the SPIFFS "partition" larger, and still fit the "firmware" in the WROOM memory. Or am I wrong? You can adjust the partition sizes for the 4MB WROOM boards by editing 'fujinet_partitions_4MB.csv' in the platformio directory. Quote Share this post Link to post Share on other sites
Kyle22 #1394 Posted August 12, 2020 19 hours ago, tschak909 said: given that we should show the type of files in the disk image window, and that we have a limited amount of available text space (40 columns), I'm thinking that there needs to be custom 16 pixel wide glyphs (two character cells together) to show each disk type, SD, DD, etc. Am wondering if maybe a graphical form could be done that makes sense for all the different disk types? I had initially done a set of glyphs like this: but they smudge like crazy on composite displays. Anybody have any ideas? -Thom Nice, but you forgot about 77 track disks. Some people have ATR-8000's (and other controllers) with 8" drives. Quote Share this post Link to post Share on other sites
Fuji-Man #1395 Posted August 12, 2020 4 minutes ago, Kyle22 said: Nice, but you forgot about 77 track disks. Some people have ATR-8000's (and other controllers) with 8" drives. and Black box. Some ATR are not full 720 sectors, seen a few with 368? or less as well. Just enough to hold the directory sectors and VTOC. Quote Share this post Link to post Share on other sites
manterola #1396 Posted August 12, 2020 22 hours ago, mozzwald said: You can adjust the partition sizes for the 4MB WROOM boards by editing 'fujinet_partitions_4MB.csv' in the platformio directory. Thanks! that worked. I expanded the spiffs partition (new offset: 0x250000 new size: 0x1B0000) by shrinking the app0 previous partition (size from 0x340000 to 0x240000) Now I was able to print to emulated Epson printer. 2 Quote Share this post Link to post Share on other sites
tschak909 #1397 Posted August 12, 2020 #Atari8bit #FujiNet With the CONFIG Rewrite, It's now possible to specify a wildcard to filter directory entries... 6 Quote Share this post Link to post Share on other sites
Fierodoug5 #1398 Posted August 12, 2020 30 minutes ago, manterola said: Thanks! that worked. I expanded the spiffs partition (new offset: 0x250000 new size: 0x1B0000) by shrinking the app0 previous partition (size from 0x340000 to 0x240000) Now I was able to print to emulated Epson printer. Could you walk me through that, i have the file open, just a bit confused which numbers to change. Thanx Doug Quote Share this post Link to post Share on other sites
mozzwald #1399 Posted August 13, 2020 3 hours ago, Fierodoug5 said: Could you walk me through that, i have the file open, just a bit confused which numbers to change. Thanx Doug 1 Quote Share this post Link to post Share on other sites
mozzwald #1400 Posted August 13, 2020 Another updated firmware is available with the ALL NEW CONFIG program thanks to @tschak909. 3 Quote Share this post Link to post Share on other sites
