+Mr Robot #1426 Posted August 14, 2020 If you followed the instructions on the wiki and got it working, now all you should need to do is systemctl stop tnfsd cd to the spectranet folder you built tnfsd in in the first place git fetch cd tnfs/tnfsd make os=linux mv bin/tnfsd /usr/local/bin/ systemctl start tnfsd Quote Share this post Link to post Share on other sites
+Mr Robot #1427 Posted August 14, 2020 13 minutes ago, DrVenkman said: Okay, here is the serial debug for my file mounting issues. I can see one big problem right off: the log data says it's trying to mount the first image from host #6 but that's not correct. The host I am using for this test is #7 in my setup; host #6 is currently my SD card. That's ... too bad. Because it was kind of a pain in the ass to figure out to set up a TNFS server on my RPi. The current documentation is somewhat scattered and incomplete. I am not looking forward to doing it again. FujiNet_Log.zip 13.67 kB · 2 downloads Looks like long filenames still need to be longer [15:38:13]Fuji cmd: MOUNT IMAGE [15:38:13]Selecting '/Games/I/Infidel (1983)(Infocom)(Di' from host #6 as r on D1: [15:38:13]TNFS open file: "/Games/I/Infidel (1983)(Infocom)(Di" (0x0001, 0x01b6) [15:38:13]ERROR! Quote Share this post Link to post Share on other sites
tschak909 #1428 Posted August 14, 2020 52 minutes ago, Mr Robot said: Does that auto build to fujinet.online or do we need to wait for someone to say it's been updated? @Mr Robot We need to crank another update. There is still at least one other bug I am trying to squish first. @DrVenkman The host slot is zero based, so 0 is host slot 1, 6 is host slot 7. Looking at it now. -Thom - 1 Quote Share this post Link to post Share on other sites
tschak909 #1429 Posted August 14, 2020 (edited) 29 minutes ago, Mr Robot said: Looks like long filenames still need to be longer [15:38:13]Fuji cmd: MOUNT IMAGE [15:38:13]Selecting '/Games/I/Infidel (1983)(Infocom)(Di' from host #6 as r on D1: [15:38:13]TNFS open file: "/Games/I/Infidel (1983)(Infocom)(Di" (0x0001, 0x01b6) [15:38:13]ERROR! Ok, still looks like the filename is silently being truncated to 36 bytes after updating the device slot. I did make one change to the firmware to prevent this, am looking further. -Thom And fixed, I had to re-apply the change to not re-set the filenames when using the old write device slots call (which still has to be used for changes that AREN'T the filename, along with the new set filename call.) @mozzwald new build Things changed: * Filenames should no longer be truncated. * Support for TK-II keys * Default action is to go back to selecting more files, instead of Diskulator Hosts/Device Slots. use ESC to exit back to main screen. Things to be added soon: * Add ability to press OPTION anywhere to mount all and boot. -Thom Edited August 14, 2020 by tschak909 1 Quote Share this post Link to post Share on other sites
mozzwald #1430 Posted August 14, 2020 1 hour ago, Mr Robot said: Does that auto build to fujinet.online or do we need to wait for someone to say it's been updated? There is no auto build yet. I run it manually and post here when it's done... it's done and the new update is available 1 Quote Share this post Link to post Share on other sites
tschak909 #1431 Posted August 14, 2020 @mozzwald discovered an interesting edge case when specifying a WiFi network. This has now been fixed, and I've asked him to do ONE MORE BUILD today. (btw, caps-lock is now off by default.) -Thom 1 Quote Share this post Link to post Share on other sites
+Mr Robot #1432 Posted August 14, 2020 I'll be testing the latest build and my lowercase filtering tnfs server tomorrow morning Quote Share this post Link to post Share on other sites
tschak909 #1433 Posted August 14, 2020 <-- is having one of those days where everything I try to fix gets broken worse.... Quote Share this post Link to post Share on other sites
+DrVenkman #1434 Posted August 15, 2020 3 hours ago, Mr Robot said: systemctl stop tnfsd cd to the spectranet folder you built tnfsd in in the first place git fetch cd tnfs/tnfsd make os=linux mv bin/tnfsd /usr/local/bin/ systemctl start tnfs Nope. [email protected]:/home/tnfs/spectranet/tnfs/tnfsd $ ls bin datagram.h endian.h fileinfo.o README.txt strlcpy.o bsdcompat.h datagram.o endian.o log.c session.c tnfs_file.c chroot.c directory.c errortable.c log.h session.h tnfs_file.h chroot.h directory.h errortable.h log.o session.o tnfs_file.o chroot.o directory.o errortable.o main.c strlcat.c tnfs.h config.h Dockerfile fileinfo.c main.o strlcat.o vscode_sample datagram.c endian.c fileinfo.h Makefile strlcpy.c [email protected]:/home/tnfs/spectranet/tnfs/tnfsd $ sudo make OS=linux gcc -o bin/ main.o datagram.o log.o session.o endian.o directory.o errortable.o tnfs_file.o chroot.o fileinfo.o /usr/bin/ld: cannot open output file bin/: Is a directory collect2: error: ld returned 1 exit status Makefile:34: recipe for target 'all' failed make: *** [all] Error 1 [email protected]:/home/tnfs/spectranet/tnfs/tnfsd $ ¯\_(ツ)_/¯ EDIT: for what it's worth, I built my server again from scratch and filtering is now case-insensitive and does work. So thanks! Quote Share this post Link to post Share on other sites
+DrVenkman #1435 Posted August 15, 2020 Okay, time for a usability request: display the full, untruncated filename for the currently highlighted file below the file list and above the list of command hints. Otherwise it's impossible to tell the difference between, say, the three different files on my server that hit for "Zork III" or the four files for "Zork II". They might be versions of the same 1-disk version but what if they're not?The first two might well be Side A and Side B of one version, with the third a single-disk version. But with the filename display truncated with an * at the end, there's no way to tell. So either display the full name below, or allow the user to press a key ("I" for information? The spacebar?) for the full name. Otherwise, the user is merely guessing about which file to load into which slot for multi-disk games and applications. 1 Quote Share this post Link to post Share on other sites
mozzwald #1436 Posted August 15, 2020 New build is up with the wifi fix. 39 minutes ago, DrVenkman said: [email protected]:/home/tnfs/spectranet/tnfs/tnfsd $ sudo make OS=linux You don't build as root (sudo). just run make as regular user, then cp the binary as root 2 Quote Share this post Link to post Share on other sites
tschak909 #1437 Posted August 15, 2020 7 minutes ago, DrVenkman said: Okay, time for a usability request: display the full, untruncated filename for the currently highlighted file below the file list and above the list of command hints. Otherwise it's impossible to tell the difference between, say, the three different files on my server that hit for "Zork III" or the four files for "Zork II". They might be versions of the same 1-disk version but what if they're not?The first two might well be Side A and Side B of one version, with the third a single-disk version. But with the filename display truncated with an * at the end, there's no way to tell. So either display the full name below, or allow the user to press a key ("I" for information? The spacebar?) for the full name. Otherwise, the user is merely guessing about which file to load into which slot for multi-disk games and applications. You and I seem to be on similar wavelengths. Yup, I have been shuffling bits around to do just that. It's coming. -Thom Quote Share this post Link to post Share on other sites
+DrVenkman #1438 Posted August 15, 2020 6 minutes ago, mozzwald said: New build is up with the wifi fix. You don't build as root (sudo). just run make as regular user, then cp the binary as root Permissions issue on a standard Raspbian build - if I don't build with sudo, it won't build at all outside my own regular user directory. Ultimately I deleted everything, cloned the current repository and built it from scratch. Worked fine (though I did have to use sudo for the same reason as above). Quote Share this post Link to post Share on other sites
mozzwald #1439 Posted August 15, 2020 (edited) 7 minutes ago, DrVenkman said: Permissions issue on a standard Raspbian build - if I don't build with sudo, it won't build at all outside my own regular user directory. Ultimately I deleted everything, cloned the current repository and built it from scratch. Worked fine (though I did have to use sudo for the same reason as above). Clone the repo in your home dir or make a 'build' dir in your home dir and clone it there. There's no reason why you have to be root to build tnfsd. Edited August 15, 2020 by mozzwald No reason Quote Share this post Link to post Share on other sites
+DrVenkman #1440 Posted August 15, 2020 37 minutes ago, mozzwald said: Clone the repo in your home dir or make a 'build' dir in your home dir and clone it there. There's no reason why you have to be root to build tnfsd. You will still need sudo to move the binary to the usr/local/sbin directory, so no big deal. As I said before, I have it working fine. Quote Share this post Link to post Share on other sites
+Stephen #1441 Posted August 15, 2020 9 hours ago, tschak909 said: Yup, this is mine right now, a Model F keyboard from modelfkeyboards.com ... Hey man - your keycaps all got rubbed off! How can you type?!? Quote Share this post Link to post Share on other sites
tschak909 #1442 Posted August 15, 2020 9 minutes ago, Stephen said: Hey man - your keycaps all got rubbed off! How can you type?!? Heehee. I deliberately ordered mine with blank legends. Very striking, no? -Thom 1 Quote Share this post Link to post Share on other sites
jamm #1443 Posted August 15, 2020 1 hour ago, tschak909 said: Heehee. I deliberately ordered mine with blank legends. Very striking, no? -Thom Also does wonders for keeping most others off your computer! 1 1 Quote Share this post Link to post Share on other sites
manterola #1444 Posted August 15, 2020 14 hours ago, DrVenkman said: So either display the full name below, or allow the user to press a key ("I" for information? The spacebar?) for the full name. Otherwise, the user is merely guessing about which file to load into which slot for multi-disk games and applications What about scrolling the current selection? That way you will have no problem with extra long filenames. 1 Quote Share this post Link to post Share on other sites
+DrVenkman #1445 Posted August 15, 2020 7 minutes ago, manterola said: What about scrolling the current selection? That way you will have no problem with extra long filenames. That would work too, though there are always disagreements about how fast to scroll, especially if the filename is very long or very short. Scrolling the name would certainly take up less screen real estate than a display panel, though it might take up some computational resources too.trust I trust Thom and his gang of merry code boffins will figure out a good solution. Quote Share this post Link to post Share on other sites
leech #1446 Posted August 15, 2020 14 hours ago, DrVenkman said: You will still need sudo to move the binary to the usr/local/sbin directory, so no big deal. As I said before, I have it working fine. Actually it is easy enough to modify you $PATH and install it in $HOME/bin. Actually Debian has this set by default, if you 'mkdir $HOME/bin' bash will look there for executables. Quote Share this post Link to post Share on other sites
+DrVenkman #1447 Posted August 15, 2020 2 minutes ago, leech said: Actually it is easy enough to modify you $PATH and install it in $HOME/bin. Actually Debian has this set by default, if you 'mkdir $HOME/bin' bash will look there for executables. I'm using this on an RPi Zero W. I'm running Raspbian (and not even the latest image ...) not Debian. As I said, it's working fine. Quote Share this post Link to post Share on other sites
manterola #1448 Posted August 15, 2020 I'll try to install tnfs in a pogoplug device. There is still devices of this defunct service on sale, like 2 for $15 if someone is interested. You basically can load arch Linux or debian if I remember correctly and attach any USB drive. Quote Share this post Link to post Share on other sites
leech #1449 Posted August 15, 2020 27 minutes ago, DrVenkman said: I'm using this on an RPi Zero W. I'm running Raspbian (and not even the latest image ...) not Debian. As I said, it's working fine. Ha, Raspbian IS Debian. But cool that it is working. When are the rest of us getting this device? Quote Share this post Link to post Share on other sites
tschak909 #1450 Posted August 15, 2020 #FUJINET #ATARI8BIT Because the Read Directory call can specify a length in AUX1, we can give it double duty displaying the primary file list, and a view for longer filenames. @DrVenkman #FujiNet #Atari8bit CONFIG now mounts disks quicker, by returning to the file list after selecting the disk slot for the previous entry. 3 Quote Share this post Link to post Share on other sites
