repetto74
FINALGROM99 Building the card but sofware related questions
Hi guys,
I am in the process of building the FINALGROM99 card as I do feel confident now with smd soldering after some successfull trials. Despite the fact that I am ok with the hardware part I do have a weak side which is sofware related.
As explained by Ralph on his GitHub, a compile action is needed to build the files to be used to program both the Atmega328 and the CPLD. I do have installed Python 2.7 and downloaded the xdt99 suite but I am stuck as I do not know exactly where to insert the first command line :
$ cd ti/
$ ./make.py
Is that from the python console or the Windows 10 console?🤨
Is there a more detailed guide on how to compile the files?🙂
Thanks
Rick
Edited by repetto74
Those commands are written for either Linux or Mac. On Windows, use the Windows Command Prompt and use backslashes instead of forward slashes. You need to be in the root of the repository (wherever you cloned or unzipped the download) before running the commands.
Thanks a lot for your explanation InfiniteTape this looks more clear to me now.
I do have a mac so I tried to compile (I have installed Python 2.7.17 OSX) using the Terminal. I do get this error.
Last login: Sun Nov 24 00:17:28 on ttys000
Mac-mini:~ $ cd /Users/rick/Desktop/finalgrom99-master
Mac-mini:finalgrom99-master
$ cd ti/
Mac-mini:ti
$ ./make.py
Traceback (most recent call last):
  File "./make.py", line 11, in <module>
    if call(xas + ["menu.a99"], shell=False):
  File "/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 172, in call
    return Popen(*popenargs, **kwargs).wait()
  File "/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 394, in __init__
    errread, errwrite)
  File "/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 1047, in _execute_child
    raise child_exception
OSError: [Errno 2] No such file or directory
Mac-mini:ti
You need to have xdt99 installed and in your path. Add a line like this to the file ~/.bash_profile
export PATH=/Users/brian/Documents/endlos99/xdt99:$PATH
Be sure to load a fresh terminal after you make that change.
Then you'll need to update the make.py file to point to the xdt99 lib files. Near the top of the file, you'll see a line like this:
xas = ["xas99.py", "-b", "-R", "-I", "/Users/brian/Documents/endlos99/xdt99/lib/"]
Change that path to the path to your xdt99/lib folder.
Hi InfiniteTape,
Ok the second part where I have to update the make.py Python executable is fine. I can use Pycharm installed on OSX and update the path to the lib folder of the xdt99 main folder.
The first part I do not catch exactly how I am supposed to install the xdt99? I have downloaded a folder as per attached screenshot. Where can I find the ~/.bash_profile file in order to add the PATH to xdt99 folder?
Sorry for asking my knowledge on unix command lines is somehow limited.
Rick
Edited by repetto74
.bash_profile or .profile are hidden files in your home directory. (All Unix files starting with a period are hidden; show them with ls -a.) It depends on the Unix flavor and used shell which of the files actually set the PATH. You can use any text editor to change them.
Thanks mizapf.
ls -a will list hidden files then I had to set the option to show hidden files on Mac OS High Sierra and I do have this file visible now :-). Ok I will try with the guide of InfiniteTape and cross my fingers 🙂
I went a step further but getting a different error when compiling....
    errread, errwrite)
OSError: [Errno 13] Permission denied
Here is below the batch profile file :
# Setting PATH for Python 3.7
# The original version is saved in .bash_profile.pysave
PATH="/Library/Frameworks/Python.framework/Versions/3.7/bin:${PATH}"
export PATH
# Setting PATH for Python 2.7
PATH="/Library/Frameworks/Python.framework/Versions/2.7/bin:${PATH}"
export PATH
export PATH="/Users/Desktop/finalgrom99/xdt99:${PATH}"
maybe a syntax mistake on the added line ?
Edited by repetto74
Can you do the following command and post the output? I'm wondering if there's a file executable bit problem.
ls -l /Users/Desktop/finalgrom99/xdt99
Here it is
Mac-mini-de-RICCARDO-4:ti riccardorepetto$ ls -l /Users/riccardorepetto/Desktop/finalgrom99/xdt99
total 728
[email protected]  1 riccardorepetto  staff  18092  8 jui 13:32 COPYING
[email protected]  9 riccardorepetto  staff    306  8 jui 14:31 doc
[email protected]  7 riccardorepetto  staff    238  8 jui 13:54 example
[email protected]  6 riccardorepetto  staff    204  8 jui 13:32 ide
[email protected] 23 riccardorepetto  staff    782  8 jui 13:55 lib
[email protected]  1 riccardorepetto  staff  87554  8 jui 14:31 xas99.py
[email protected]  1 riccardorepetto  staff  21608  8 jui 14:31 xbas99.py
[email protected]  1 riccardorepetto  staff  32619  8 jui 14:31 xda99.py
[email protected]  1 riccardorepetto  staff  41737  8 jui 14:31 xdg99.py
[email protected]  1 riccardorepetto  staff  45983  8 jui 14:31 xdm99.py
[email protected]  1 riccardorepetto  staff  64059  8 jui 14:31 xga99.py
[email protected]  1 riccardorepetto  staff  29341  8 jui 14:31 xhm99.py
[email protected]  1 riccardorepetto  staff  11687  8 jui 14:31 xvm99.py
10 minutes ago, InfiniteTape said:
For some reason, your py files aren't marked as executable. Run this command in that folder.
chmod +x *.py
That did the trick apparently 🙂
Last login: Sun Nov 24 20:01:19 on ttys001
Mac-mini-de-RICCARDO-4:~ riccardorepetto$ cd /Users/riccardorepetto/Desktop/finalgrom99
Mac-mini-de-RICCARDO-4:finalgrom99 riccardorepetto$ cd ti/
Mac-mini-de-RICCARDO-4:ti riccardorepetto$ ./make.py
> browser.a99 <2> 0218 - Warning: Possible branch/jump optimization
Warning: Unreferenced constants: C_FF
Now I have the TI folder with help.bin and menu.bin files created. Hope this is what I should expect 🙂
Edited by repetto74
Now I tried step 2 with the compile of the microcontroller and bootloader code in avr/
Getting again an error message. I suppose that the bash_profile file needs to be updated also?
Mac-mini-de-RICCARDO-4:ti riccardorepetto$ cd /Users/riccardorepetto/Desktop/finalgrom99
Mac-mini-de-RICCARDO-4:finalgrom99 riccardorepetto$ cd avr/
Mac-mini-de-RICCARDO-4:avr riccardorepetto$ make
rm -f update.avr
rm -f finalgrom.hex
rm -f finalgrom.eep
rm -f finalgrom.obj
rm -f finalgrom.cof
rm -f finalgrom.elf
rm -f finalgrom.map
rm -f finalgrom.obj
rm -f finalgrom.a90
rm -f finalgrom.sym
rm -f finalgrom.lnk
rm -f finalgrom.lss
rm -f finalgrom.o loader.o wire.o lib/pff.o lib/diskio.o jtag/ports.o jtag/lenval.o jtag/micro.o
rm -f  finalgrom.lst loader.lst wire.lst lib/pff.lst lib/diskio.lst jtag/ports.lst jtag/lenval.lst jtag/micro.lst
rm -f finalgrom.s loader.s wire.s lib/pff.s lib/diskio.s jtag/ports.s jtag/lenval.s jtag/micro.s
rm -f finalgrom.d loader.d wire.d lib/pff.d lib/diskio.d jtag/ports.d jtag/lenval.d jtag/micro.d
rm -f .dep/*
Compiling: finalgrom.c
avr-gcc -c -mmcu=atmega328p -I. -g -D F_CPU=8000000L   -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -fno-strict-aliasing -Wall -Wstrict-prototypes -Wa,-adhlns=finalgrom.lst -std=gnu99 -MD -MP -MF .dep/finalgrom.o.d finalgrom.c -o finalgrom.o
make: avr-gcc: No such file or directory
make: *** [finalgrom.o] Error 1
You'll need the AVR toolchain installed. You can get it through Homebrew.
brew install avr-gcc
But if you look a little further down in the FinalGROM, you'll need Windows or Linux to program the CPLD. Hopefully you have one available.
Thanks InfiniteTape :-). Yes I do have a WIndows 10 running through bootcamp on the Mac so it should be ok.
I will install this Homebrew package installer with this command /usr/bin/ruby -e "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/master/install)"
Then, brew install avr-gcc.
Sounds good 🙂
Well... Homebrew install went well but this is the result when I try to install avr-gcc 😞. Could be the name of the avr package has changed?
Mac-mini-de-RICCARDO-4:~ riccardorepetto$ brew install avr-gcc
Error: No available formula with the name "avr-gcc"
==> Searching for a previously deleted formula (in the last month)...
Warning: homebrew/core is shallow clone. To get complete history run:
  git -C "$(brew --repo homebrew/core)" fetch --unshallow
Error: No previously deleted formula found.
==> Searching for similarly named formulae...
Error: No similarly named formulae found.
==> Searching taps...
==> Searching taps on GitHub...
Error: No formulae found in taps.
Edited by repetto74
Nope I tried to follow this the above installation guide but keep gettings errors.... 🤔 I cannot install the avr-libc.
Mac-mini-de-RICCARDO-4:~ riccardorepetto$ brew tap osx-cross/avr
Updating Homebrew...
==> Auto-updated Homebrew!
Updated 1 tap (homebrew/core).
==> Updated Formulae
eslint              jenkins             librsvg             node
==> Tapping osx-cross/avr
Cloning into '/usr/local/Homebrew/Library/Taps/osx-cross/homebrew-avr'...
remote: Enumerating objects: 36, done.
remote: Counting objects: 100% (36/36), done.
remote: Compressing objects: 100% (34/34), done.
remote: Total 36 (delta 7), reused 12 (delta 0), pack-reused 0
Unpacking objects: 100% (36/36), done.
Tapped 10 formulae (85 files, 134.4KB).
Mac-mini-de-RICCARDO-4:~ riccardorepetto$ brew install avr-libc
Error: No available formula with the name "avr-libc"
UPDATE: the command to run has changed, I need to run brew tap osx-cross/avr && brew install avr-gcc
That installed the avr-gcc succesfully apparently. Will test the compile now 🙂
Edited by repetto74
That did the trick 🙂 I have finally the package.hex built
Packaging Bootloader and cart firmware: package.hex
head -n -1 ../finalgrom.hex | cat - bootload.hex > package.hex
head: illegal line count -- -1
bootload.elf  :
section                     size      addr
.data                         12   8388864
.text                       4136     28672
.bss                         173   8388876
.comment                      17         0
.note.gnu.avr.deviceinfo      64         0
.debug_aranges               296         0
.debug_info                 8549         0
.debug_abbrev               3421         0
.debug_line                10417         0
.debug_frame                 892         0
.debug_str                  1757         0
.debug_loc                  5864         0
.debug_ranges                456         0
Total                      36054
Mac-mini-de-RICCARDO-4:boot riccardorepetto$
Thanks a lot for your help InfiniteTape much appreciated ! :-D
@mizapf If you're using RPI linux how would you edit your path? This is the current hang up. I made sure I had 2.7 python installed but am getting the same error as above Errno 25c3b824c0efa8dcdf58a65db3b1c4d36.jpg
Sent from my SM-G955U using Tapatalk
I don't have too much experience in Python programming; your problem seems to be calling another Python script from this Python script. Maybe someone else could chime in.
Assuming by "RPI linux" you mean Raspbian and that you haven't changed the defaults, you're likely running the bash shell. Try putting this in /home/pi/.bash_profile:
export PATH="/Users/pi/finalgrom99/xdt99-master:${PATH}"
I checked the for the file in the directory listed
[email protected]:~ $ cd /home/pi/
[email protected]:~ $ ls -a
.              .claws-mail  .gnupg    .pp_backup   .Xauthority
..             .config      .local    .profile     .xsession-errors
.bash_history  Desktop      MagPi     Public       .xsession-errors.old
.bash_logout   Documents    Music     Templates
.bashrc        Downloads    Pictures  .thumbnails
.cache         finalgrom    .pki      Videos
Couldn't find the file. Is there a way to create it?
oh damn my work buddy reformatted this to Buster... ok lemme put Raspbian on here.
Edited by Mehridian Sanders
The config files are ".profile", ".bashrc", or ".bash_profile". To clarify: The ".profile" file is executed when you log into your machine, and it applies to various shells (including the bash, which you seem to use). The ".bash_profile" is a specific bash configuration file which overrides the ".profile". So if you have a ".profile", you do not need a .bash_profile. The .bashrc file is executed whenever you open a shell; this may happen many times after you log into your machine.
So you have to add the "PATH" setting to the end of your .profile. Either you open the file with an editor of your choice (I suppose it is not vi 🙂 ), write
export PATH=$PATH:/home/pi/finalgrom99/xdt99-master
as the last line, save it. Or you do the following outside of the editor, in the shell:
echo "export PATH=$PATH:/home/pi/finalgrom99/xdt99-master" >> .profile
The ">>" adds the echoed text to the end of the file specified behind. Then log out and log in again.
