rensoup #501 Posted April 7, 2020 5 hours ago, _The Doctor__ said: maybe he lands so close on the edge he must steady himself for a bit... yeah that's it. seriously though, he prolly lands at decision point and the game doesn't know where he really can go... after a bit the player resets and you get to go on your way. It does sound like some form of the bug rensoup pointed out... Have you watched the TAS exploit/trick speed play of the game... at 12 minutes and a few seconds flat? I don't remember exactly but I might have seen various consequences for that bug: once the game froze indefinitely (but flames kept going) and another time the prince fell down the screen and died. Not seen that speedrun I believe... Quote Share this post Link to post Share on other sites
rensoup #502 Posted April 7, 2020 4 hours ago, tjlazer said: How do you walk slow using the keyboard? Usually that’s done by holding shift down while moving the cursor keys. 16 hours ago, rensoup said: playing with the keyboard ? (my keyboard handler only allows 1 key at a time 😀) if you're on a real machine, you're out of luck but you can use joystick emulation with an emu of course Quote Share this post Link to post Share on other sites
rensoup #503 Posted April 7, 2020 3 hours ago, Jacques said: When playing on my real 130XE yesterday, it happened several times during fights, that with some joystick movement (I'm not sure exactly how), our hero hid the sword in the middle of the fight with enemy still very close. Is it a behaviour of BBC Master version? Normally on Amiga/PC version, I believe and think the Prince did not hide the sword until some more far distance between him and enemy. stating the obvious, but I guess you know that pressing down during a fight will cause the prince to put the sword away? (spoiler: it's useful exactly once in the game 🙂) 1 hour ago, _The Doctor__ said: moving backwards or forward with the sword out needs to be done by small moves, if you hold the joystick backing away from an enemy for too long you will put away your sword and make ready to run damn, I didn't even know that! Quote Share this post Link to post Share on other sites
Jacques #504 Posted April 7, 2020 2 minutes ago, rensoup said: stating the obvious, but I guess you know that pressing down during a fight will cause the prince to put the sword away? (spoiler: it's useful exactly once in the game 🙂) damn, I didn't even know that! Didn't know that, thanks! Anyway, I think hiding sword was due to backing off from the enemy, not accidentally pushing down on joystick. Quote Share this post Link to post Share on other sites
xxl #505 Posted April 7, 2020 After the release of PoP, if you want, you can upload ATR on the cartr. if the game uses xBIOS for I / O operations then the new xBIOS allows you to run from a cartridge. 3 Quote Share this post Link to post Share on other sites
rensoup #506 Posted April 7, 2020 (edited) 3 hours ago, xxl said: After the release of PoP, if you want, you can upload ATR on the cartr. if the game uses xBIOS for I / O operations then the new xBIOS allows you to run from a cartridge. nice!!!👍 So I have nothing to do ? Edited April 7, 2020 by rensoup Quote Share this post Link to post Share on other sites
bfollett #507 Posted April 7, 2020 (edited) Mistake post.... Ignore Edited April 7, 2020 by bfollett Quote Share this post Link to post Share on other sites
_The Doctor__ #508 Posted April 7, 2020 (edited) bill was that the latest version? was it the NTSC version? It doesn't flicker and carry on like that on a real NTSC machine. check your versions and settings. Edited April 7, 2020 by _The Doctor__ Quote Share this post Link to post Share on other sites
bfollett #509 Posted April 7, 2020 7 minutes ago, _The Doctor__ said: bill was that the latest version? was it the NTSC version? It doesn't flicker and carry on like that on a real NTSC machine. check your versions and settings. Ugh, it wasn't the NTSC version. I edited my original post. 1 Quote Share this post Link to post Share on other sites
xxl #510 Posted April 7, 2020 (edited) 49 minutes ago, rensoup said: nice!!!👍 So I have nothing to do ? you have to "just" finish the game Edited April 7, 2020 by xxl 2 3 Quote Share this post Link to post Share on other sites
Wrathchild #511 Posted April 7, 2020 Save states? Quote Share this post Link to post Share on other sites
rensoup #512 Posted April 7, 2020 1 hour ago, Wrathchild said: Save states? Meh... the BBC version has it but what's the point when you have a level select (+ future health select) ? It takes a lot of space and you need a bit of UI,... Plus on emulators, you can already save the state anywhere you want. 1 Quote Share this post Link to post Share on other sites
rensoup #513 Posted April 7, 2020 (edited) 7 hours ago, xxl said: After the release of PoP, if you want, you can upload ATR on the cartr. if the game uses xBIOS for I / O operations then the new xBIOS allows you to run from a cartridge. So I'm curious how this work... I guess instead of load sectors from disk into the disk buffer, you just replace it with a ROM bank switch ($8000/$A000-$BFFF?), copy it to the disk buffer, bank switch RAM back and copy the buffer into its final position ? guess I shouldn't put the disk buffer at $A000 😀 Edited April 7, 2020 by rensoup Quote Share this post Link to post Share on other sites
xxl #514 Posted April 7, 2020 roughly speaking (for cartridges) yes. you can put a sector buffer at $a000 but then the readings will be slower (because you would have to change the memory configuration / read the byte / change the memory configuration / write the byte) over and over again ... it could be even slower if you put the screen memory and Display List in this area, then you would have to wait for the vertical blank (of course, all this is done by the library, the programmer does not have to worry about it). Fortunately, nothing like this happens in your project and it can work quickly. Quote Share this post Link to post Share on other sites
_The Doctor__ #515 Posted April 7, 2020 maybe xxl help do this the best way possible and create the solutions and then give educational course discussion using in the cartridge as the example Quote Share this post Link to post Share on other sites
Wilheim #516 Posted April 8, 2020 (edited) About the bug I noticed, here's a video showing it: pop bug.avi Edited April 8, 2020 by Wilheim Mispell Quote Share this post Link to post Share on other sites
_The Doctor__ #517 Posted April 8, 2020 I can't watch it. no codec lolzor Quote Share this post Link to post Share on other sites
pseudografx #518 Posted April 8, 2020 Plays fine in latest version of VLC. Quote Share this post Link to post Share on other sites
_The Doctor__ #519 Posted April 8, 2020 (edited) replacement machine has nothing on it... I have to go out and find 20+ years of add ons… pffffft nothing works with windows 10..... this S*X Edited April 8, 2020 by _The Doctor__ 1 Quote Share this post Link to post Share on other sites
rensoup #520 Posted April 8, 2020 (edited) 11 hours ago, xxl said: roughly speaking (for cartridges) yes. you can put a sector buffer at $a000 but then the readings will be slower (because you would have to change the memory configuration / read the byte / change the memory configuration / write the byte) over and over again ... it could be even slower if you put the screen memory and Display List in this area, then you would have to wait for the vertical blank (of course, all this is done by the library, the programmer does not have to worry about it). Fortunately, nothing like this happens in your project and it can work quickly. All good as the memory layout is pretty much final... I may have an issue with disk space: I was planning to use a 128KB disk but I don't think that's going to fit. So I'm thinking about making 2 versions: -a 2 SD 90KB disk version for 100% compatibility with all drives -a 1 DD 180KB disk version which would only work on some drives So I have questions: 1. does Xbios support disk swapping ? (I don't care about multiple drive support). I suppose yes and I just need to try to load a file and if it fails, ask the user for a disk swap ? 2. Is the 180KB version usable for a cart version ? 11 hours ago, _The Doctor__ said: maybe xxl help do this the best way possible and create the solutions and then give educational course discussion using in the cartridge as the example Yes please 🙂 Edited April 8, 2020 by rensoup more details about Q1 1 Quote Share this post Link to post Share on other sites
rensoup #521 Posted April 8, 2020 8 hours ago, Wilheim said: About the bug I noticed, here's a video showing it: doesn't work for me. latest VLC (3.0.8) Quote Share this post Link to post Share on other sites
rensoup #522 Posted April 8, 2020 13 hours ago, rensoup said: 15 hours ago, Wrathchild said: Save states? Meh... the BBC version has it but what's the point when you have a level select (+ future health select) ? It takes a lot of space and you need a bit of UI,... ...or you mean save states for reproducing the bug ? Quote Share this post Link to post Share on other sites
zbyti #523 Posted April 8, 2020 (edited) I used https://convertio.co/pl/download/84dcd93cf2063ec909178d9ba216279a04c663/ either way, I have the right codecs on Linux, works for me Edited April 8, 2020 by zbyti mispell Quote Share this post Link to post Share on other sites
rensoup #524 Posted April 8, 2020 Just now, zbyti said: I use https://convertio.co/pl/download/84dcd93cf2063ec909178d9ba216279a04c663/ Thanks... yes that's the bug I've seen... now is it a game bug or specific to the A8 ? because I'm not going to try to fix game bugs due to possible knock on effects! Do you know how to reproduce it 100% ? any chance of trying this on the BBC ? Quote Share this post Link to post Share on other sites
Wrathchild #525 Posted April 8, 2020 14 minutes ago, rensoup said: ...or you mean save states for reproducing the bug ? No, was in-game saving of progress, but if anyone can just start on any level then it does seem to eliminate the need. Quote Share this post Link to post Share on other sites
