Mehridian Sanders #1 Posted November 30 RCA XL-100 Solid State TV Circa 1986Surprisingly still works Sent from my SM-G955U using Tapatalk Quote Share this post Link to post Share on other sites
Mehridian Sanders #2 Posted November 30 Original RF connectors.Asking price $20 on FB marketplace. Pretty good dealSent from my SM-G955U using Tapatalk 1 Quote Share this post Link to post Share on other sites
+--- Ω --- #3 Posted November 30 Screw Terminals! Now THAT is RETRO! 😉 1 Quote Share this post Link to post Share on other sites
Mehridian Sanders #4 Posted November 30 Also found this thought I might try it as a tape datasette. Not entirely sure it will work but willing to try. Looks like I am about to learn how to split some lines Sent from my SM-G955U using Tapatalk Quote Share this post Link to post Share on other sites
wierd_w #5 Posted November 30 Can be done, but without the REM port, you will have to be johnny on the spot with the play and stop buttons. Quote Share this post Link to post Share on other sites
Mehridian Sanders #6 Posted November 30 Can be done, but without the REM port, you will have to be johnny on the spot with the play and stop buttons.Thought the Remote input was that port? Just checked and the REM will have to be sliced too to work. If that is the port. Sent from my SM-G955U using Tapatalk Quote Share this post Link to post Share on other sites
Mehridian Sanders #7 Posted November 30 Gonna go read the manual lolSent from my SM-G955U using Tapatalk Quote Share this post Link to post Share on other sites
wierd_w #8 Posted November 30 REM port is really just a jumper on a pigtail. When the leads are closed, it disables the drive motor. That's all it does; lets the computer disable the motor. You can live without it, it just means you have to press play and or record pretty quickly when it prompts. The leads on the back are separated left and right audio channels. The TI datasette is a monotone signal. Might be more sensible to just use a single channel and be done with it. Quote Share this post Link to post Share on other sites
JB #9 Posted November 30 2 hours ago, Mehridian Sanders said: RCA XL-100 Solid State TV A Solid State Television for enjoying your Solid State Software. 3 Quote Share this post Link to post Share on other sites
+OLD CS1 #10 Posted November 30 That REM port is (usually) for an IR protocol, daisy-chained between units. A lot of systems back-in-the-day used them for a multi-device stack in which your tape deck, CD player, amplifier, etc. were not a single monolithic unit, which also allowed punters to build their own system. For instance, we had a (Fisher, IIRC) system in which we replaced the single-disc CD player with a 100-disc CD changer -- quite fancy for the time -- and were still able to use the same remote by linking the REM ports. Usually the remote receiver is in the amplifier or head unit which then sends IR remote commands to the other devices. I never bothered to see if it intercepts its own commands and only sends unused commands to the chain, or if it sends all commands. Quote Share this post Link to post Share on other sites
+OLD CS1 #11 Posted November 30 11 hours ago, wierd_w said: The leads on the back are separated left and right audio channels. The TI datasette is a monotone signal. Might be more sensible to just use a single channel and be done with it. The other issue to over-come as I discovered when interfacing system tape decks to the TI is the TI expects speaker-level inputs, while these systems almost always output line-level unamplified signals. Quote Share this post Link to post Share on other sites
Mehridian Sanders #12 Posted November 30 The other issue to over-come as I discovered when interfacing system tape decks to the TI is the TI expects speaker-level inputs, while these systems almost always output line-level unamplified signals.Well... I feel fortunate to have only spent 5 on this lolSent from my SM-G955U using Tapatalk Quote Share this post Link to post Share on other sites
Mehridian Sanders #13 Posted December 1 The other issue to over-come as I discovered when interfacing system tape decks to the TI is the TI expects speaker-level inputs, while these systems almost always output line-level unamplified signals.I have found this to be true. Well the 32k sidecar and the Fg99 have some preliminary solders down. Basic resistors and some buttons.Sent from my SM-G955U using Tapatalk Quote Share this post Link to post Share on other sites
