Xebec #1 Posted December 1, 2019 Hi folks! I'm prepping a bone stock 48K Atari 800+AVGCart for a retro LAN party next weekend, and I just noticed the versions of MULE that I have limit me to 1 or 2 planeteers only. I've tried .XEX versions found via forum searches here, and what I already had from a while ago. I also tried the multijoy figuring it wouldn't be compatible, and it wasn't. It's not that the 3rd and 4th ports don't work - I can actually use those joysticks for players 1 or 2, but there's literally no option for 4 humans. Are there any other XEXs available? I have an .ATR version that won't work on the latest AVGCart firmware, and a .bin file that also doesn't load. P.S. After updating my AVGCart to the latest firmware, my existing mule.XEX won't even load now.. ugh (tried copying a fresh version down, no change). Quote Share this post Link to post Share on other sites
mimo #2 Posted December 1, 2019 (edited) Error Edited December 1, 2019 by mimo Error in post Quote Share this post Link to post Share on other sites
Wrathchild #3 Posted December 1, 2019 (edited) You're welcome to try this cart version as the AvgCart provides the mapper. I did have a report of it locking up after a few rounds but didn't get any followup on that if I recall, so worth giving it a try first. Mule_MaxFlash.car Edited December 1, 2019 by Wrathchild 1 Quote Share this post Link to post Share on other sites
mimo #4 Posted December 1, 2019 7 minutes ago, Wrathchild said: You're welcome to try this cart version as the AvgCart provides the mapper. I did have a report of it locking up after a few rounds but didn't get any followup on that if I recall, so worth giving it a try first. Mule_MaxFlash.car 128.02 kB · 1 download I was just searching for that 👍 Quote Share this post Link to post Share on other sites
Chilly Willy #5 Posted December 2, 2019 I can't recall seeing an executable version of MULE, but here's my old disk image. Plays 4 humans on 400/800 just fine. AMULE.xfd Quote Share this post Link to post Share on other sites
tmp #6 Posted December 2, 2019 19 hours ago, Xebec said: P.S. After updating my AVGCart to the latest firmware, my existing mule.XEX won't even load now.. ugh (tried copying a fresh version down, no change). can you attach the XEX that stopped working? thanks Quote Share this post Link to post Share on other sites
Xebec #7 Posted December 6, 2019 On 12/2/2019 at 8:40 AM, tmp said: can you attach the XEX that stopped working? thanks See attached I did a FC vs a fresh download and everything appears OK MULE.xex Quote Share this post Link to post Share on other sites
tmp #8 Posted December 7, 2019 this xex works for me, what was the version you upgraded from and what's your current firmware version? Quote Share this post Link to post Share on other sites
Xebec #9 Posted December 7, 2019 3 hours ago, tmp said: this xex works for me, what was the version you upgraded from and what's your current firmware version? I upgraded to 17 from the original AVGCart post (download link = http://avgcart.tmp.sk/files/atari/avgcart-0017.zip), and believe it was version 12 before. I tested this on a second Atari 800 (bone stock, no mods at all) and same result. Of course I don't know if it worked before on that version. Mule.Atr also doesn't work (though I'm not sure which ATRs work / don't work on AVGCart). Thanks! Quote Share this post Link to post Share on other sites
tmp #10 Posted December 7, 2019 looks like xex loader fix in 0016 broke something for OS B machines, if i choose that on my U1MB XL, mule doesn't work, it works with stock XL OS downgrading to 0015 seems to help, on the other hand the menu doesn't run without pressing reset, i don't know if that was also happening on a real 800 since nobody reported that i should get an 800 for testing but they're quite hard to come across around here 1 Quote Share this post Link to post Share on other sites
Kyle22 #11 Posted December 8, 2019 Let's get 4 players working in XE mode in Incognito. It disturbs me to see 2 ports that I can't use. :) Quote Share this post Link to post Share on other sites
_The Doctor__ #12 Posted March 17, 2020 On 12/7/2019 at 10:38 AM, tmp said: looks like xex loader fix in 0016 broke something for OS B machines, if i choose that on my U1MB XL, mule doesn't work, it works with stock XL OS downgrading to 0015 seems to help, on the other hand the menu doesn't run without pressing reset, i don't know if that was also happening on a real 800 since nobody reported that i should get an 800 for testing but they're quite hard to come across around here Is this sorted out for 18 0r 19? 1 Quote Share this post Link to post Share on other sites
