sparkdrummer #1 Posted December 5, 2019 My Nanopebs don’t seem to like the PLATO cart when used off a FinalGROM. A real PLATO cart works just fine. I just get a blue screen when using the FinalGROM version. Anybody else have issues with this? Quote Share this post Link to post Share on other sites
+arcadeshopper #2 Posted December 5, 2019 My Nanopebs don’t seem to like the PLATO cart when used off a FinalGROM. A real PLATO cart works just fine. I just get a blue screen when using the FinalGROM version. Anybody else have issues with this?Nope.. I'll double check this evening Sent from my LM-G820 using Tapatalk Quote Share this post Link to post Share on other sites
+pixelpedant #3 Posted December 5, 2019 (edited) Works just fine for me. NanoPEB v1 and FinalGROM with the August firmware. Non-QI unit with F18A. Edited December 5, 2019 by pixelpedant Quote Share this post Link to post Share on other sites
sparkdrummer #4 Posted December 5, 2019 Maybe I’ve got some funky Plato bin files. Can I convert GK cart saves to .bin? Quote Share this post Link to post Share on other sites
+arcadeshopper #5 Posted December 6, 2019 Maybe I’ve got some funky Plato bin files. Can I convert GK cart saves to .bin? are you using the ones in the zip file on https://ftp.whtech.com/Cartridges/FinalGROM99/ Quote Share this post Link to post Share on other sites
+Airshack #6 Posted April 10, 2020 On 12/5/2019 at 6:08 PM, arcadeshopper said: https://ftp.whtech.com/Cartridges/FinalGROM99/ Thanks Greg! Has anyone here tested PLATO running off of FinalGROM with the disk images on TIPI? Quote Share this post Link to post Share on other sites
+arcadeshopper #7 Posted April 10, 2020 no plato uses a nonstandard disk format that won't work at all on TIPI the disks only have one file in the catalog but there's much more there on the disk than that.. likely sector access which TIPI doesn't support Greg 1 Quote Share this post Link to post Share on other sites
+arcadeshopper #8 Posted April 10, 2020 I just did a couple of tests and on my system if a TIPI is in the p box the Plato cart won't even try to load Plato disks it just hangs up on the disk controllerSent from my LM-G820 using Tapatalk 1 Quote Share this post Link to post Share on other sites
+arcadeshopper #9 Posted April 10, 2020 I just did a couple of tests and on my system if a TIPI is in the p box the Plato cart won't even try to load Plato disks it just hangs up on the disk controller Sent from my LM-G820 using Tapatalk Correction if you put the TIPI at 1800 cru then it works fine with a real disk in DSK1 Sent from my LM-G820 using Tapatalk 1 Quote Share this post Link to post Share on other sites
twoodland #10 Posted April 13, 2020 On 4/10/2020 at 12:51 PM, arcadeshopper said: no plato uses a nonstandard disk format that won't work at all on TIPI the disks only have one file in the catalog but there's much more there on the disk than that.. likely sector access which TIPI doesn't support Greg Do you know if the TI Plato courseware disks have been integrated into the Plato IRATA Online courses? If not, can we get them added? Maybe a question for tschak909. Quote Share this post Link to post Share on other sites
+arcadeshopper #11 Posted April 13, 2020 Likely they are based on the online onesSent from my LM-G820 using Tapatalk 1 Quote Share this post Link to post Share on other sites
