rietveld Posted December 18, 2019 Share Posted December 18, 2019 When I am using the Adam module do I unplug the colecovision power brick and just use printer? Or do I need both power supplies? Quote Link to comment Share on other sites More sharing options...
rietveld Posted December 18, 2019 Author Share Posted December 18, 2019 I have always kept both plugged in but I jusst recently picked up the plastic tray that holds the two together and found that it has a tab that covers the colecovision power cord port. Quote Link to comment Share on other sites More sharing options...
adamcon Posted December 18, 2019 Share Posted December 18, 2019 38 minutes ago, rietveld said: I have always kept both plugged in but I jusst recently picked up the plastic tray that holds the two together and found that it has a tab that covers the colecovision power cord port. And there is your answer. Probably made no difference by leaving both plugged in, as the voltages all go the same place; but the idea of the module 3 ADAM add-on was that the stuff out of the box was a complete ADAM if you added your own CV unit to the back of the ADAM module. Quote Link to comment Share on other sites More sharing options...
NIAD Posted December 18, 2019 Share Posted December 18, 2019 Do not use the CV Power Supply when connecting the Expansion Module #3 ADAM. The tab on the joiner tray is there for a reason as you have figured out. Quote Link to comment Share on other sites More sharing options...
rietveld Posted December 18, 2019 Author Share Posted December 18, 2019 1 hour ago, NIAD said: Do not use the CV Power Supply when connecting the Expansion Module #3 ADAM. The tab on the joiner tray is there for a reason as you have figured out. I used the colecovision power brick so that I could also connect my roller controller Quote Link to comment Share on other sites More sharing options...
doubledown Posted December 18, 2019 Share Posted December 18, 2019 Does the ADAM Expansion version not use the same side-located power plug as the stand-alone? If it does, there was a Connector Adapter which plugs inline, and gives you a connection for the Roller Controller. Quote Link to comment Share on other sites More sharing options...
rietveld Posted December 18, 2019 Author Share Posted December 18, 2019 You are correct. i just noticed that my stand alone adam has that connector. I will just use the roller controller on that adam instead. Thanks Quote Link to comment Share on other sites More sharing options...
NIAD Posted December 19, 2019 Share Posted December 19, 2019 On 12/18/2019 at 10:32 AM, rietveld said: I used the colecovision power brick so that I could also connect my roller controller There was a power adapter included with the Roller Controller for connecting to the ADAM 9-pin power port. Quote Link to comment Share on other sites More sharing options...
NIAD Posted December 19, 2019 Share Posted December 19, 2019 On 12/18/2019 at 1:20 PM, doubledown said: Does the ADAM Expansion version not use the same side-located power plug as the stand-alone? If it does, there was a Connector Adapter which plugs inline, and gives you a connection for the Roller Controller. The EM#3 ADAM used the same 9-pin Power/ADAMnet port as the Stand Alone ADAM. Quote Link to comment Share on other sites More sharing options...
