Mehridian Sanders #1 Posted December 26, 2019 So ... quick joystick adapter makey thing Sent from my SM-G955U using Tapatalk 2 Quote Share this post Link to post Share on other sites
Mehridian Sanders #2 Posted December 26, 2019 And I think I messed up my keyboard by adding the joystick alpha lock fix. U . I . O . P . Enter Shift Dont work now.... drat.Sent from my SM-G955U using Tapatalk 1 Quote Share this post Link to post Share on other sites
Mehridian Sanders #3 Posted December 26, 2019 Futaba keyboard is shot... looks like I am replacing it with the stackpole... ugh the keys fall out... also this a normal Wumpus cart menu?Sent from my SM-G955U using Tapatalk Quote Share this post Link to post Share on other sites
wierd_w #4 Posted December 26, 2019 As I recall, the Hunt the Wumpus cartridge contains several regionalisations inside it. This was mentioned on a youtube video I saw for xload, since the program only initiates the first entry in a multi-program cartridge image. (which in the case of hunt the wumpus, is the german localization.) Sorry to year about your keyboard though. 1 Quote Share this post Link to post Share on other sites
Mehridian Sanders #5 Posted December 26, 2019 Well I bought the second 99/4a in case something happened to the first. Which, it seems it did. If anyone is any good at fixing mechanical keyboards, I would be most appreciative. I also have this coming.. just in case. I found it when looking for oddities.http://www.ebay.com/itm/264567937931Sent from my SM-G955U using Tapatalk Quote Share this post Link to post Share on other sites
+arcadeshopper #6 Posted December 26, 2019 18 hours ago, Mehridian Sanders said: And I think I messed up my keyboard by adding the joystick alpha lock fix . U . I . O . P . Enter Shift Dont work now.... drat. Sent from my SM-G955U using Tapatalk keyboards are very simple things.. you should be able to troubleshoot with a meter.. if you want to send it to me lmk always need parts Greg 1 Quote Share this post Link to post Share on other sites
Mehridian Sanders #7 Posted December 26, 2019 keyboards are very simple things.. you should be able to troubleshoot with a meter.. if you want to send it to me lmk always need parts GregWell after removing the joystick fix lead U I O P started working again. Enter, R- Shift, and Spacebar are still not working. The Stackpole feels nice just that the keys fall out if the keyboard is inverted. Yeah I think I will send you the Futaba. For parts only, I think one of the pads came off. Sent from my SM-G955U using Tapatalk Quote Share this post Link to post Share on other sites
mizapf #8 Posted December 26, 2019 Check this. The columns are supplied with GND level one after another, and the INT lines are sensed by the keyboard scan. So if OIUYP fail, it is likely that pin 1 of the keyboard connector is bad. 1 Quote Share this post Link to post Share on other sites
Mehridian Sanders #9 Posted December 26, 2019 Check this. The columns are supplied with GND level one after another, and the INT lines are sensed by the keyboard scan. So if OIUYP fail, it is likely that pin 1 of the keyboard connector is bad.Ok will check the points on my meter when I get home Sent from my SM-G955U using Tapatalk Quote Share this post Link to post Share on other sites
Mehridian Sanders #10 Posted December 27, 2019 Unable to check tonight... Honeydo list was longSent from my SM-G955U using Tapatalk Quote Share this post Link to post Share on other sites
Mehridian Sanders #11 Posted December 27, 2019 ok the pads were coming away from the Alpha Lock trace and the pin 6 trace in general. Running a trace connection from Pin 6 to AL, should fix that issue. gonna be rerunning a lot of traces rom the looks of it ... also gonna redo the connection from the keyboard to the wires for a nice neat header. Quote Share this post Link to post Share on other sites
Mehridian Sanders #12 Posted December 27, 2019 Ran a trace from AL to Pin 6. Followed the trace carefully. Also added some headers for the outputSent from my SM-G955U using Tapatalk Quote Share this post Link to post Share on other sites
Mehridian Sanders #13 Posted December 27, 2019 so wait a second ... since I now have headers on this ... is it possible to split the keyboards function .. add a 10 key pad through USB and use the TI keyboard while in the keyboard with another PC? like make it dual purposed? Using a teensy 2.0 should be able to use the keyboard while the TI is off for the PC? hmmmmmmmmmmmmmm Quote Share this post Link to post Share on other sites
Mehridian Sanders #14 Posted December 28, 2019 On 12/26/2019 at 3:12 PM, mizapf said: Check this. The columns are supplied with GND level one after another, and the INT lines are sensed by the keyboard scan. So if OIUYP fail, it is likely that pin 1 of the keyboard connector is bad. ok checked my points from pin 1 to enter and U. I. O. P. all are showing a signal of about 1 ohm so the signal is still there this is of course after the header addition. I am using the end point of the header to check the traces to make sure signal gets all the way through. On 12/26/2019 at 12:02 PM, arcadeshopper said: keyboards are very simple things.. you should be able to troubleshoot with a meter.. if you want to send it to me lmk always need parts Greg Thanks Greg, you were right they are very simple creatures. I guess I should have a bit more faith in my abilities. Either that or just not go bananasandwich when something new rears its head 1 Quote Share this post Link to post Share on other sites
Ed in SoDak #15 Posted December 28, 2019 While you're trying to repair it, don't forget the leaf switches exposed by popping a keycap off. If the traces, soldering and wiring look good but it's still a bit flaky, pop the offending caps off and spray a small shot of contact cleaner in there then work it a bit. My last balky keyboard had failed solder on a few switches, discovered when the cleaner didn't help. -Ed 1 Quote Share this post Link to post Share on other sites
Mehridian Sanders #16 Posted December 28, 2019 Thanks, I will remember this. Unfortunately, I can't use it. The keycaps (which look very Cherry MX like) only show the pole i'd have to de-solder the switch. I tested the keyboard out though. And it will work but my headers come right into contact with the connector. So I get to redo that lol.Sent from my SM-G955U using Tapatalk Quote Share this post Link to post Share on other sites
gpaJeb #17 Posted December 29, 2019 I have that style keyboard and the keys do come off very easy. Quote Share this post Link to post Share on other sites
Mehridian Sanders #18 Posted December 29, 2019 I am glad they do. Made it much easier to clean them from the previous owners buildup. The Stackpole keyboard though... the keys literally fall out if inverted. Still feels good to type on ... will use it for a spell and see if it grows on me.Sent from my SM-G955U using Tapatalk Quote Share this post Link to post Share on other sites
Ed in SoDak #19 Posted December 29, 2019 (edited) That style is more tedious. See those two tabs either side of the post? Push them inwards and the white plastic part then lifts off. Don't recall the innards, so expect maybe a spring or other fly-away parts. Or not! I do recall needing three hands or six fingers to get it out! Oh, another possible gotcha. The switch terminals may have to be desoldered and cleared since that's part of the switch! It's been awhile since I've had to do that, so my memory of it is a bit cloudy with a chance of a clearing trend. What I've done for an easy fix, having lots of spares laying around, was to swap in a better snap-in switch from a donor board. In a pinch, you could swap a heavily used switch with another on the same keyboard that's used less often. -Ed Edited December 29, 2019 by Ed in SoDak 1 1 Quote Share this post Link to post Share on other sites
Mehridian Sanders #20 Posted December 29, 2019 Alright yes it is more tedious. I am going to give it a go on the morrow. Thank you kindly. I will also post a pic of my setup for ya'll in the proper thread Sent from my SM-G955U using Tapatalk Quote Share this post Link to post Share on other sites
Ed in SoDak #21 Posted December 29, 2019 Added more info to my post above as my recollection sharpens a bit. -Ed Quote Share this post Link to post Share on other sites
