0078265317
weird connector?
That is quite unusual.
Looking at some of the images, It definitely says 'Alpha Stick 3' on the back of the controller board; but googling that brings up nothing relevant (Street Fighter controllers and hockey sticks).
I would think it is perhaps someones own home creation? The joystick looks like a pretty standard console use design, but the connector certainly looks like it is intended to be installed inside something, and not readily removed/swapped.
The base looks very much like a Wico command controller (They also had 'TOP' stamped into them), but I do not think they made a two button version? Perhaps someone had modified one to be a two button joystick?
Certainly quite an interesting unit!
I think it has been modified for use with a ZX Spectrum, which has no joystick port so there are a variety of commercial and user-made options.
I have seen the stick before on eBay with a normal 9 pin Atari connector.  I just can't find the link right now.  But that connector looked weird.  Almost like an old hard drive connector or something.
Exactly.
I mentioned that it was so cheap that they didn't even include joystick ports, but the ZX80 (predecessor to the ZX Spectrum) was built too cheap to pay for a slot connector on the mainboard. The card edge connector they have instead is merely an exposed part of the mainboard PCB (effectively free). As a result, the accessory/expansion device needs to have the card slot.
Since it doesn't have a slot or a joystick port, even joysticks and joystick adapters need to connect with a "weird" card edge connector like that.
You are correct that the joystick is a common stick used on C64, Atari, etc with the traditional 9-pin joystick port. People building joysticks for a ZX micro would absolutely repurpose an existing joystick design if they didn't out-right or adapt or modify it with the stuff needed for a Speccy.
Edit:
Here is a modern adapter...
https://lotharek.pl/productdetail.php?id=66
It has more pins so the one you see may not be for a Spectrum but it's gotta be something similar.
I'm pretty sure that's a stick that was sold for the TRS-80 and that's the parallel port connector. They also made a TRSStick that was an actual Atari 2600 controller. It was just closed contacts on the printer port leads so games could recognize it.
It is 25 pins. :)
Might be interesting to catalog the number of computers/consoles that used a 50-pin edge connector.  For instance, the Amstrad CPC and PCW appear to be a couple of the possibilities.
