kerobaros
New Atari 600XL owner!
Hi all! Recently received a 600XL from a friend, and it seems to boot just fine. Now I need to upgrade the RAM on it, which seems easy enough, along with put a monitor jack into it. Are there any kits available for either of these mods, or do I have to track down all the individual parts myself?
Once I get all that done, I'll have to decide between getting an Sdrive or the Ultimate/SIDE combo... thoughts?
cartridge solutions load games very quickly, SIO devices are a little slower but not much and both are v.user-friendly to use
UAV gives great image quality and fitment is straightforward/uncomplicated
Alright, I ordered some 4464 compatible ICs from eBay, we'll see how long they take to arrive. Looking at the Brewing Academy's storefront, it seems that I want the plug-in model of the UAV board, right? Is there a good place to get the correct DIN socket for the monitor jack?
12 hours ago, Paul Westphal said:
could share a high Rez pic
here is my 64k mod:
here is my 600XL UAV - with explanation
due to height of the components surrounding the 4050 chip, i decided to relocate the UAV board as shown in the image. to do so, i had to run link wires instead of the usual direct method.
the bottom 2 wires are DC +/-
the group of 5 wires above that are the input signals from the 4050 chip to the UAV
the top 4 wires are the display output signal to the display port 5-pin DIN
the guidance material i used is here:
UAV.zip
but i also got v.good support from user: @Bryan who i bought it off
for a 600XL you need 41464 ICs - they are 18-pin (see my innards pic above)
im not sure but arent 4464 the same as 4164? if so they are 16-pin and used in the 64k & 128k Ataris
might be worth a check
@tf_hh makes a ram upgrade, 512k iirc.
Also, check out how he uses a cable for av out on his SCCC board for the 400, it may be easier to do something similar for your UAV upgrade on the 600xl?
The ICs I bought are NEC D41464C-10s, which appear to be 18 pin. Thank you for the clarification!
4 hours ago, kerobaros said:
D41464C-10s
fast ones eh? should be an agile 600XL after that  😁
4464 and 41464 are both numbers that have been used for 64k x 4-bit DRAM chips, used in several Atari 8-bit models, and compatible with the 600XL for a 64k upgrade.
yes, inconsistent part numbering..
pincount confirmed good for this venture tho 🙂
Not really, the part numbers differed between manufacturers. I know them as 4464, probably because of TI, many others used 41464.
Fujitsu: MB81464
Motorola: MCM41464
NEC: D41464
Samsung: KM41464A/KM41C464P
Texas Instruments: TMS4464
Edited by BillC
If the Postal Service cooperates, I should have two deliveries today: one package with my RAM ICs, and one package from the Brewing Academy with a new power adapter, a monitor jack, and a UAV board. I desoldered my channel 2/3 switch and cleared the solder out of the monitor jack mounting holes before work last night in preparation for a busy evening of soldering. Quite excited! I'll keep you all updated how things go.
Also, I managed to rig together an SIO2PC cable the other day from parts I had around the house already, and tested it out by loading the cassette version of Space Invaders. Any suggestions for what I should use to test my system after I get things out back together?
sounds like you have a good session lined up hehe 🙂
test with your favourite games but also try 64k games too. it should behave just like an 800XL after the RAM mod. the inbuilt RAM self-test should be booted with option held in order not to load basic.
UAV is super-sharp compared to standard so any software will give pleasing results
I also recommend UAV connected to a cable running to a female 5 pin DIN coming out of the back of the computer like the SCCC uses. This way no case modding/drilling is needed.
The 600XL has great s-video once the blurring cap is removed. If you can be bothered to find/do the 600XL Supervideo mod, it's even better.
Blurring cap? Please elaborate.
Only got the RAM today, UAV is somewhere between the west coast and the midwest. Oh well.
I am late to the party on this one but I have a 600XL with an ANTONIA board and a SOPHIA board installed in it.  This gives the 600XL a huge RAM upgrade, seven selectable OS and BASIC slots, and a digital output.  It is pretty much a perfect machine now.
I forget the component number at this point, but if you search for tf_hh's comments on 600XL video tuning, all will become clear (literally!).
Edited by flashjazzcat
It´s a 180pF ceramic cap, mostly in disc shape, with component name C109. Remove it and the picture will be MUCH clearer.
is it still beneficial to remove the blurring cap even if you already have UAV installed?
I did this plus a full SuperVideo mod on one 600XL and aside from some feint clocking bars (which perhaps the blurring cap was supposed to obscure) which may be alleviated by better cable shielding, s-video is really nice... one level below UAV quality, IMHO.
