0078265317 #1 Posted December 31, 2019 Found these cool adapters. Firdt few days ago. And there is one on ebay without the cable. But no shell so might be flimsy without a shell. Second one just found but more expensive. First one how hard would it be to make a shell? https://www.ebay.com/itm/Nintendo-NES2db9-Adapter-Pad-Nes-to-the-Atari-520-1040-st-Ste-and-Stf/293206009844?hash=item444470a7f4:g:P-kAAOSwaZRdPGmb https://touch.adverts.ie/arcade-retro/new-snes-nes-gamepad-db9-interface-adapter-for-amiga-atari-c64-computer-578/13821218 Quote Share this post Link to post Share on other sites
RamrodHare #2 Posted January 1, 2020 You can rewire an NES controller if you have a spare. I used to do it. As far as making an enclosure for that adapter, if you have access to a 3d printer it would be great. It would be really easy to make a shell out of sheet styrene. A wooden shell wouldn't be too hard, if you have the tools. There are a lot of possible ways to make a shell, it just comes down to what tools you have and your experience. Sheet styrene is by far the simplest and probably less costly. Quote Share this post Link to post Share on other sites
0078265317 #3 Posted January 1, 2020 I don't but my library has a 3d printer. Or legos might works also. I know there are ways to wire a controller. I remember that thread. But this adapter is better. I can use any and if it breaks I just plug in another controller. And I can try different ones like a new max. I have a broken max at home. But I can eBay another one. And there are other methods I discussed here like with some camerica adapters. But that uses a freedom connect and that uses 4AAA batteries. This is a direct connection. No batteries. Quote Share this post Link to post Share on other sites
