Omega-TI
TI-99/4A Related -- Image challenge thread
The rules are simple:
1) The winner gets to pick the next photo.
2) The first one to guess correctly wins that round.
I'll start the ball rolling with this...
15 minutes ago, FarmerPotato said:
Supersketch
The ADC and connector are the ringers.
Dang, I thought that would last a bit longer!  Well, you win that round, your up! :thumbsup:
One note on that one, the PPI on the board, with Irving, TX under it would have been the most obvious clue. . .I do have to laugh at the fact that they had to redrill the central hole in the cartridge board though. They must not have had their calipers set right when they laid the board out.
OK, lets step it up a bit - where would you find this?
You're more likely to see it this way round:
Hint: it's an item manufactured by TI.
Edited by Stuart
The serial connector on the RS-232 card!
  • Like 4
The PEB cable 'foot' that plugs into the console?
(With some questionable soldering quality bottom right ...)
Edited by Stuart
Correct, and good call on the soldering quality. :P That was a quick fix a couple years back when I was touching up the PCB (rubber piece underneath it started rotting), should probably hit a lot of those joints again with some flux.
I recognized the capacitors--TI used them everywhere on their memory boards--and the 32K was the most likely one, based on the part number of the visible memory chip.
7 hours ago, mizapf said:
Correct! How did you know?
I couldn't think of any other TI hardware with 4116s on it (besides the motherboard, but it doesn't look like what's in the picture). Also the black silkscreen on green soldermask, the only place I can remember seeing that is on the PEB cards.
I'll let somebody else go after me since I posted a picture only a couple days ago :)
