AtariGeezer #1 Posted January 9, 2020 (edited) This is the latest project for the Atari that I've Been working on. The Atari Wifi Modem (or #AtaWiModem for short). Currently supports Full 850 Emulation with internal Booter and Handler code. Works with many terminal programs such as Amodem, BobTerm and the Express! Cart (Which I highly recommend). The Express! Cart can handle 9600 Baud rather reliably where other terminal programs can not do. After booting the Fuji Board, press <Return> and you'll be shown a "->" Prompt. From here you can type "HELP" or "AT?" (Without Quotes) to display two different menus. The "SCAN" command will show you a list of nearby WiFi Access Points, this list will show you the [Channel], (Signal Level), SSID and either an asterisk "*" if the connection is Secure or "!" if it is Open. You can then type "NET# (Number on List)" followed by an <optional> Password depending upon the AP having a Secure or Open connection. You can also just type "PASS (Your Password) to store the Password temporarily. #AtaWiModem also has a PhoneBook to store your favorite BBS #'s that can be displayed by the "ATL" command. As shown in the pictures below, you can see some of the screens that are used. For the 850 Emulation, the next thing I'll be testing is File Transfers and then Add and Test BBS Support from AMIS, Express, Express Pro, FoReM and FoReM XEP. This should cover most types of BBS's used on the Atari 8-Bits. After the 850 Emulation is fully tested, I'll finish the Client side of TNFS. One feature I'll be adding soon is #IRC Chat 🙂 Other protocols that can be easily added would be POP3, IMAP and SMTP email support. (I already have these coded on Windows using the WinSock API's...) Jay AtaWiModem.ino.esp32.bin AtaWiModem.ino.esp32thing.bin Edited January 9, 2020 by AtariGeezer 11 Quote Share this post Link to post Share on other sites
tuf #2 Posted January 9, 2020 Very cool! What hardware are you using for this? I've got a WiModem232 hooked up to a real 850 I use for similar things. Quote Share this post Link to post Share on other sites
AtariGeezer #3 Posted January 9, 2020 The current build is for the ESP32 board built by Mozzwald. I'll make a version for the ESP8266 too, will have to see about adding support for the WiModem232... Quote Share this post Link to post Share on other sites
Kyle22 #4 Posted January 10, 2020 How does this compare with FujiNet? 1 Quote Share this post Link to post Share on other sites
Kyle22 #6 Posted January 10, 2020 1 hour ago, Kyle22 said: How does this compare with FujiNet? I'd like to add that this is a serious question. All I want is information. I do NOT seek to accelerate flames of any kind. 2 Quote Share this post Link to post Share on other sites
AtariGeezer #7 Posted January 10, 2020 I've already beaten that horse to death in this thread and the other about the talking points. Let's just move forward on this Two things I haven't mentioned is that while connected to a BBS, you can go back into command mode by temporarily pressing the Flash/Program Button. The Blue LED will indicate this Also in the works is accessing a WiFi Enabled Printer 1 Quote Share this post Link to post Share on other sites
+skr #8 Posted January 10, 2020 Do I understand correctly, that all I need is an ESPxx connected to the SIO support and your software? That´ll be cool, as this would be a very simple and inexpensive solution. I´m already testing my ESP with Mr. Atari´s LiteDos, which in general works, but I need to make a better SIO-plug for it. Right now I´ve just loosely soldered four wires directly to the SIO-port... Quote Share this post Link to post Share on other sites
AtariGeezer #9 Posted January 10, 2020 45 minutes ago, skr said: Do I understand correctly, that all I need is an ESPxx connected to the SIO support and your software? That´ll be cool, as this would be a very simple and inexpensive solution. I´m already testing my ESP with Mr. Atari´s LiteDos, which in general works, but I need to make a better SIO-plug for it. Right now I´ve just loosely soldered four wires directly to the SIO-port... I think this is the latest diagram for the Esp32. AtariWiFi GPIO Table - ESP32.pdf Quote Share this post Link to post Share on other sites
AtariGeezer #10 Posted January 17, 2020 Good news Tonight I'll be testing the APE Time code I've added a few days ago, the Server code is ready for testing a BBS and in a couple of days I'll have a companion ready for a BBS Server / TNFS Server or what have you. It's using the onboard SD Card as a SIO2SD device that will have 9 virtual drives and can use the Flash / Boot Button to rotate drives 1 Quote Share this post Link to post Share on other sites
bfollowell #11 Posted January 17, 2020 I know there are at least a couple of modem type projects for the 8-bits. I'd like to look into these as a future project, for after I get my 1088XEL build completed. These are awesome! Quote Share this post Link to post Share on other sites
JohnPolka #12 Posted January 17, 2020 On 1/9/2020 at 2:25 PM, AtariGeezer said: This is the latest project for the Atari that I've Been working on. The Atari Wifi Modem (or #AtaWiModem for short). Currently supports Full 850 Emulation with internal Booter and Handler code. Works with many terminal programs such as Amodem, BobTerm and the Express! Cart (Which I highly recommend). The Express! Cart can handle 9600 Baud rather reliably where other terminal programs can not do. I actually found that the latest version of BobTerm performs the best of the bunch at 9600 baud. When I used the Express Cart! to connect to Part-Time BBS and the Basement BBS, I noticed some buffer overloads with some of the ATASCII screens/movies. Another good test is the 'W'ho's called command (which dumps the last 50 callers to the BBS). -JP Quote Share this post Link to post Share on other sites
AtariGeezer #13 Posted January 19, 2020 On 1/17/2020 at 2:40 PM, JohnPolka said: I actually found that the latest version of BobTerm performs the best of the bunch at 9600 baud. When I used the Express Cart! to connect to Part-Time BBS and the Basement BBS, I noticed some buffer overloads with some of the ATASCII screens/movies. Another good test is the 'W'ho's called command (which dumps the last 50 callers to the BBS). -JP I get complete dropouts with bobterm above 2400, which version are you using? On call logs, don't all callers show a connection at 9600 baud when using the lantronix devices on the BBS??? Quote Share this post Link to post Share on other sites
JohnPolka #14 Posted January 19, 2020 (edited) 19 hours ago, AtariGeezer said: I get complete dropouts with bobterm above 2400, which version are you using? On call logs, don't all callers show a connection at 9600 baud when using the lantronix devices on the BBS??? The call logs for BBS Express Pro! when it's connected to the Internet, show the baud rate on the BBS side. So, if the BBS' Internet device is locked at 9600, the call log will show every caller connecting at 9600. Incidentally, Alcatraz BBS is locked at 4800 baud. So, it appears everyone who connects to Alcatraz are connecting at 4800 baud. As for the BobTerm test... I just tried it again....So, I used version 1.20 of BobTerm (I think the last version was 1.21 -- but I could only find 1.20 for this test). I connected to Part-Time BBS and first tried the 'W'hos called list. I also tried the "Jazz (Basement Cat)" ATASCII slide show. The Express Cart gets buffer overflows on both of these two BBS features. With BobTerm, I get a perfect display when I use a P:R: Connection connected to the Lantronx or when I use an MIO connected to the Lantronix. When I use an 850, I experience some buffer overflowing on the ATASCII slide show. However, it was pretty minor compared to the Express Cart. When I ran the ATASCII slide show, I could still make most of it out. With the Express Cart, you could not make out big portions of the ATASCII slide show. I did not get any buffer overflows on the 'W'hos called list with the 850 and BobTerm. In summary, it looks like BobTerm works best with a P:R: Connection or with an MIO. Despite the Express Cart's shortcomings, I still like its ease of use and convenience of being on a cartridge. It still does a great job for most BBS sessions. -JP Edited January 19, 2020 by JohnPolka Quote Share this post Link to post Share on other sites
Mathy #15 Posted January 20, 2020 Hello John Lastest version of BobTerm is 1.23, but on a real Atari, 1.22 works best. Sincerely Mathy 1 Quote Share this post Link to post Share on other sites
JohnPolka #16 Posted January 20, 2020 44 minutes ago, Mathy said: Hello John Lastest version of BobTerm is 1.23, but on a real Atari, 1.22 works best. Sincerely Mathy Thanks...I found version 1.21 and saw the same results as version 1.20. What is the difference between version 1.22 and 1.23? Quote Share this post Link to post Share on other sites
Kyle22 #17 Posted January 20, 2020 48 minutes ago, JohnPolka said: Thanks...I found version 1.21 and saw the same results as version 1.20. What is the difference between version 1.22 and 1.23? Not sure of the details, but IIRC, 1.23 is said to work better on an emulated Atari. Use 1.22 on the real thing. What we need to have fixed is CP.BTM module for the latest SDX. It was hard coded for an old (4.2x) version of SDX. Command prompt in BobTerm no longer works with recent SDX versions. 1 Quote Share this post Link to post Share on other sites
AtariGeezer #18 Posted January 25, 2020 Update: Booting off the SD card now works, but have a bit more to go on talking better with the Config Tool.... Quote Share this post Link to post Share on other sites
AtariGeezer #19 Posted January 31, 2020 (edited) It's working now I will post the update after a few more tests... https://youtu.be/bknNZPNmBKY Edited January 31, 2020 by AtariGeezer Quote Share this post Link to post Share on other sites
tuf #20 Posted January 31, 2020 16 minutes ago, AtariGeezer said: It's working now I will post the update after a few more tests... https://youtu.be/bknNZPNmBKY The video is private Quote Share this post Link to post Share on other sites
AtariGeezer #21 Posted January 31, 2020 (edited) Should be ok now. Edited January 31, 2020 by AtariGeezer 4 Quote Share this post Link to post Share on other sites
AtariGeezer #22 Posted March 10, 2020 Atari WiFi Modem v0.3 update. This update includes support for SIO2SD, plus more Hayes AT Commands that allow comm programs such as FoReM XE BBS that test each AT command for a valid response in text or numeric format depending on V0 or V1 settings. To configure the SIO2SD, you'll need to place the CnfgTool.atr in the SD Card's Root Directory. Then when you power up the fujinet board, you'll see the blue LED light up for a few seconds before it goes out. You have to press the Program/Flash Button before it goes out to boot the cnfgtool.atr. When the Atari WiFi Modem has completed it's Initialization, the blue LED will blink twice... After booting up your Atari, you can press the Program/Flash Button to rotate Drives 1 to 4. The blue LED will blink indicating which emulated Drive is in Slot #1. So the first time you press it, it will blink twice indicating D2: is now in D1: ... The SIO2SD supports up to 8 ATR / XFD images that can be configured using the CnfgTool.atr. After DOS loads, press L to load a binary file, then SIOV20.XEX... Today I connected to Kyle's BBS using Bobterm 1.22 and was able to download a 16k cart file @ 19.2k successfully Jay CnfgTool.atr AtaWiModem.esp32.v03.zip 3 Quote Share this post Link to post Share on other sites
tuf #23 Posted March 11, 2020 This is awesome. Still hoping for a WiModem232 version to magically appear Quote Share this post Link to post Share on other sites
xrbrevin #24 Posted March 11, 2020 On 1/10/2020 at 3:58 AM, Stephen said: EEE-HEE!! Quote Share this post Link to post Share on other sites
AtariGeezer #25 Posted March 11, 2020 Just bought these to add to the NodeMCU boards: https://www.ebay.com/itm/322401196555 3 Quote Share this post Link to post Share on other sites
