TGB1718 #1 Posted January 13, 2020 Can anyone suggest a simple test editor to use, I know ED.COM is available using SpartaDOS X, but I am using SpartaDOS 3.2F as the programs I am writing won't run properly under SPDX so ED is not available. Just want to use it to make/edit some batch files Quote Share this post Link to post Share on other sites
Mathy #2 Posted January 13, 2020 Hello TGB1718 Not sure if it'll work with SD(X), but I'd recommend T:Edit from ANALOG Computing. Sincerely Mathy Quote Share this post Link to post Share on other sites
+Roydea6 #3 Posted January 13, 2020 (edited) EDIT.XEX and EDIT9.XEX should be MyDos and SpartaDos 3.x friendly. The first is version 2.5 and the second is version 2.9 Edited January 13, 2020 by Roydea6 To add another version of same program. 2 Quote Share this post Link to post Share on other sites
TGB1718 #4 Posted January 13, 2020 thanks guys Quote Share this post Link to post Share on other sites
+Nezgar #5 Posted January 14, 2020 Good ol TextPro is what I used to use back in the day to edit my BBS menus and batch files, and it runs under SpartaDOS 3.2. https://atari.fox-1.nl/atari-400-800-xl-xe/400-800-xl-xe-tools/textpro-4-0x/ Little heaver weight than the previously suggested options. Quote Share this post Link to post Share on other sites
576XE #6 Posted January 22, 2020 Hello, TGB1718- Here in attachment is Sparta Editor (I rename it as SED) It's useful and convenient too. Take a look, please SED.XEX Best wishes from Moscow zen 2 Quote Share this post Link to post Share on other sites
TGB1718 #7 Posted January 22, 2020 (edited) @576XE thanks, not seen that one before, looks interesting Edited January 22, 2020 by TGB1718 spelling Quote Share this post Link to post Share on other sites
baktra #8 Posted January 22, 2020 (edited) EDIT13.COM from FLOP#48, side A - http://flop.atariportal.cz/archives/Flop_48.zip. Simple, efficient, by Raster. Control+ Q Quit L Load S Save I Insert/Overwrite toggle P Paper/Text Color toggle O Non-printable characters toggle Y Delete line A Home Z End W Next Word U Page Up D Page Down T Top of the document B Bottom of the document C Copy - Copy to clipboard. Position cursor the the beginning of a block. Press CTRL+C. Then position cursor to the end of a block. Press CTRL+C again. Max block size is 4 KB V - Paste from clipboard to the cursor position. Edited January 22, 2020 by baktra 4 Quote Share this post Link to post Share on other sites
576XE #9 Posted January 22, 2020 SED belongs to RIF SpartaDOS Utilities. You may find some very interesting tools there... zen Quote Share this post Link to post Share on other sites
576XE #10 Posted February 19, 2020 Hello, baktra. Edit13 is very suitable editor. Is it possible to eliminate CR symbol? The dots evidently shows us the end of line, isn't it? zen Quote Share this post Link to post Share on other sites
baktra #11 Posted February 20, 2020 19 hours ago, 576XE said: Hello, baktra. Edit13 is very suitable editor. Is it possible to eliminate CR symbol? The dots evidently shows us the end of line, isn't it? zen Press CTRL+O twice :-). It toggles displaying non-printable characters. It cycles in three modes. Nothing, dots+crlf, dots only The dots just show unused space (and also can serve as a primitive ruler) The CR shows end of a paragraph 1 Quote Share this post Link to post Share on other sites
Marius #12 Posted February 20, 2020 I have very fond memories of panther. This was a great tool, and also supported Atascii graphics IIRC. http://atarionline.pl/v01/index.php?ct=utils&sub=1. Biuro&tg=Panther#Panther It was also compatible with SpartaDos disk version. 1 Quote Share this post Link to post Share on other sites
576XE #13 Posted March 15, 2020 Hello baktra I tried EDIT13 and it's very clear looking and the text is very readable!!! Here <msg .by...> stanza has some digits - it's ASC("...") of MAE controls... And the result... Hello, Marius Is it possible to use all ATASCII Pseudographics in PANTHER and how? Sometimes it's very big problem in programming because some of the symbols are used by editor as control symbols. zen 1 Quote Share this post Link to post Share on other sites
Faicuai #14 Posted March 16, 2020 On 2/20/2020 at 5:19 AM, Marius said: I have very fond memories of panther. This was a great tool, and also supported Atascii graphics IIRC. http://atarionline.pl/v01/index.php?ct=utils&sub=1. Biuro&tg=Panther#Panther It was also compatible with SpartaDos disk version. Very nice. Overall, gram-by-gram, seems the best of the bunch (reminds me of MS-DOS editing tools). Very easy to use, no need to invoke a help menu (as it uses a GUI-like drop-down visual representation), supports multiple column-width formats, customizable screen colors and text brightness, and works very well with SDX Way to go! 1 Quote Share this post Link to post Share on other sites
flashjazzcat #15 Posted March 16, 2020 (edited) On 1/22/2020 at 11:04 AM, baktra said: EDIT13.COM from FLOP#48, side A - http://flop.atariportal.cz/archives/Flop_48.zip. Simple, efficient, by Raster. Can't get this to run at all from the SDX command line prompt. On 2/20/2020 at 10:19 AM, Marius said: I have very fond memories of panther. This was a great tool, and also supported Atascii graphics IIRC. http://atarionline.pl/v01/index.php?ct=utils&sub=1. Biuro&tg=Panther#Panther Nice: I quite like this one. The 'DIR' function could use some means of traversing the Sparta directory tree. Edited March 16, 2020 by flashjazzcat Quote Share this post Link to post Share on other sites
drac030 #16 Posted March 16, 2020 52 minutes ago, flashjazzcat said: Can't get this to run at all from the SDX command line prompt Because this is a DOS 2.0 disk marked in the VTOC as MyDOS disk. Edit the sector $168, change the first byte from $03 to $02, save the changes - and voila, it will now be readable. 1 Quote Share this post Link to post Share on other sites
flashjazzcat #17 Posted March 16, 2020 12 minutes ago, drac030 said: Because this is a DOS 2.0 disk marked in the VTOC as MyDOS disk. Edit the sector $168, change the first byte from $03 to $02, save the changes - and voila, it will now be readable. Aha... thanks so much! Quote Share this post Link to post Share on other sites
baktra #18 Posted March 16, 2020 49 minutes ago, drac030 said: Because this is a DOS 2.0 disk marked in the VTOC as MyDOS disk. Edit the sector $168, change the first byte from $03 to $02, save the changes - and voila, it will now be readable. It is in fact DOS II+ disk, that's why the difference in the file system organization. Quote Share this post Link to post Share on other sites
