Serguei2 Posted January 18, 2020 Share Posted January 18, 2020 I can't make noise sound to hear. Quote #include <coleco.h> #include <getput1.h> const byte sound1[] = { 0x40,0xAB,0x01,0x08,0x42,0xAB,0x71,0x08,0x18,0x11,0x50, }; const byte sound2[] = { 0x80,0x5A,0x00,0x08,0x82,0x5A,0x70,0x08,0x18,0x11,0x90, }; const byte sound3[] = { 0xC0,0x20,0xF0,0x10,0xD0,0x00,0x00,0x03,0x08,0x02,0x73,0x08,0x18,0x11,0x10, }; const sound_t snd_table[] = { {sound1,SOUNDAREA1}, {sound2,SOUNDAREA2}, {sound3,SOUNDAREA6}, }; const byte gtsNAME[] = { 0xFE, 0x20, 0xFE, 0x20, 0xFE, 0x20, 0xFE, 0x20, 0xFE, 0x20, 0xFE, 0x20, 0x85, 0x20, 0xFF}; const byte gtsPATTERN[] = { 0xFE, 0x00, 0xFE, 0x00, 0x89, 0x00, 0x01, 0x1C, 0x38, 0x82, 0x18, 0x02, 0x00, 0x18, 0x18, 0x82, 0x66, 0x85, 0x00, 0x21, 0x44, 0xFE, 0x44, 0x44, 0xFE, 0x44, 0x00, 0x18, 0x3E, 0x60, 0x3C, 0x06, 0x7C, 0x18, 0x00, 0xFF, 0x81, 0xB9, 0xA5, 0xB9, 0xA5, 0x81, 0xFF, 0x3C, 0x66, 0x3C, 0x38, 0x67, 0x66, 0x3F, 0x00, 0x06, 0x0C, 0x18, 0x84, 0x00, 0x01, 0x0C, 0x18, 0x82, 0x30, 0x04, 0x18, 0x0C, 0x00, 0x30, 0x18, 0x82, 0x0C, 0x08, 0x18, 0x30, 0x00, 0x00, 0x66, 0x3C, 0xFF, 0x3C, 0x66, 0x82, 0x00, 0x81, 0x18, 0x02, 0x7E, 0x18, 0x18, 0x86, 0x00, 0x81, 0x18, 0x00, 0x30, 0x82, 0x00, 0x00, 0x7E, 0x88, 0x00, 0x81, 0x18, 0x81, 0x00, 0x10, 0x03, 0x06, 0x0C, 0x18, 0x30, 0x60, 0x00, 0x3C, 0x66, 0xCE, 0xD6, 0xE6, 0xCC, 0x78, 0x00, 0x18, 0x38, 0x83, 0x18, 0x2C, 0x1C, 0x30, 0x0E, 0x1E, 0x36, 0x06, 0xFC, 0xC0, 0xFE, 0x00, 0x0E, 0x1E, 0x36, 0x06, 0x3C, 0x86, 0xFE, 0x00, 0x0E, 0x1E, 0x36, 0x66, 0xFE, 0x06, 0x06, 0x00, 0x1E, 0x3E, 0x70, 0xE0, 0xFC, 0x0E, 0xFE, 0x00, 0x0E, 0x1E, 0x30, 0x60, 0xDE, 0xF2, 0xFE, 0x00, 0x7E, 0xC6, 0x0C, 0x82, 0x18, 0x18, 0x1C, 0x30, 0x1E, 0x3E, 0x66, 0x66, 0xFC, 0xC6, 0xFE, 0x00, 0x3C, 0x66, 0xCE, 0xFE, 0x06, 0x0C, 0x38, 0x00, 0x00, 0x18, 0x18, 0x00, 0x00, 0x18, 0x18, 0x82, 0x00, 0x0C, 0x18, 0x00, 0x00, 0x18, 0x18, 0x30, 0x0E, 0x18, 0x30, 0x60, 0x30, 0x18, 0x0E, 0x82, 0x00, 0x02, 0x7E, 0x00, 0x7E, 0x82, 0x00, 0x0F, 0x70, 0x18, 0x0C, 0x06, 0x0C, 0x18, 0x70, 0x00, 0x1E, 0x3E, 0x66, 0x06, 0x18, 0x18, 0x00, 0x18, 0x87, 0x00, 0x38, 0x0E, 0x1E, 0x36, 0x66, 0xFE, 0xC6, 0xC6, 0x00, 0x0E, 0x1E, 0x26, 0x66, 0xFC, 0xC6, 0xFE, 0x00, 0x0E, 0x1E, 0x32, 0x60, 0xC0, 0xC2, 0xFE, 0x00, 0xE0, 0xF0, 0xD8, 0xCC, 0xC6, 0xCE, 0xFC, 0x00, 0x0E, 0x1E, 0x30, 0x60, 0xFC, 0xC0, 0xFE, 0x00, 0x0E, 0x1E, 0x30, 0x60, 0xFC, 0xC0, 0xC0, 0x00, 0x0E, 0x1E, 0x32, 0x60, 0xCE, 0xC2, 0xFE, 0x00, 0x26, 0x82, 0x66, 0x05, 0xFE, 0xC6, 0xC6, 0x00, 0x1C, 0x78, 0x83, 0x18, 0x1D, 0x1C, 0x30, 0x0E, 0x1C, 0x0C, 0x0C, 0x4C, 0xCC, 0xFE, 0x00, 0x26, 0x66, 0x6C, 0x78, 0xFC, 0xCE, 0xC6, 0x00, 0x70, 0xE0, 0x60, 0x60, 0x62, 0x66, 0xFE, 0x00, 0x46, 0xEE, 0xFE, 0xD6, 0x82, 0xC6, 0x32, 0x00, 0x42, 0xC6, 0xE6, 0xF6, 0xDE, 0xCE, 0xC6, 0x00, 0x1C, 0x3E, 0x66, 0xC6, 0xC6, 0xCC, 0x78, 0x00, 0x0E, 0x1E, 0x36, 0x66, 0xFC, 0xC0, 0xC0, 0x00, 0x1C, 0x3E, 0x66, 0xC6, 0xD6, 0xDC, 0x77, 0x00, 0x0E, 0x1E, 0x36, 0x66, 0xF8, 0xCC, 0xC6, 0x00, 0x0E, 0x1E, 0x32, 0x60, 0xFE, 0x06, 0xFE, 0x00, 0x7E, 0xFC, 0x83, 0x30, 0x02, 0x38, 0x60, 0x26, 0x82, 0x66, 0x04, 0xE6, 0xC6, 0xFE, 0x00, 0x26, 0x82, 0x66, 0x22, 0xE6, 0x6C, 0x38, 0x00, 0x62, 0xC6, 0xC6, 0xD6, 0xFE, 0xEE, 0xC4, 0x00, 0x26, 0x66, 0xEC, 0x38, 0x7C, 0xEE, 0xC6, 0x00, 0x26, 0x66, 0xEC, 0x38, 0x18, 0x18, 0x1C, 0x30, 0x3E, 0x66, 0xCC, 0x18, 0x32, 0x66, 0xFE, 0xFE, 0x00, 0xFE, 0x00, 0xFE, 0x00, 0xFE, 0x00, 0xFE, 0x00, 0xFE, 0x00, 0xFE, 0x00, 0xFE, 0x00, 0xFE, 0x00, 0xFE, 0x00, 0xB2, 0x00, 0xFF}; const byte gtsCOLOR[] = { 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0xFE, 0x41, 0x8F, 0x41, 0xFF}; void main(void) { set_snd_table(snd_table); screen_mode_2_text(); paper(0xc); rle2vram (gtsPATTERN,0x0000); rle2vram (gtsCOLOR,0x2000); rle2vram (gtsNAME,0x1800); duplicate_pattern(); cls(); screen_on(); print_at(1,1,"PRESS 1, 2 OR 3"); enable_nmi(); loop: if(keypad_1==1){ disable_nmi(); print_at(1,2,"BOUTON 1"); play_sound(1); enable_nmi(); } if(keypad_1==2){ disable_nmi(); print_at(1,2,"BOUTON 2"); play_sound(2); enable_nmi(); } if(keypad_1==3){ disable_nmi(); print_at(1,2,"BOUTON 3"); play_sound(3); enable_nmi(); } delay(1); goto loop; } void nmi(void) {} button 1 = tome 1 button 2 = tome 2 button 3 = tome 3/noise can't hear it. Quote Link to comment Share on other sites More sharing options...
digress Posted January 18, 2020 Share Posted January 18, 2020 (edited) need to combine tone 3 with noise in order to hear. you can't just play noise separately. so you end up with 2 tone channels + 1 noise or 3 tone channels. I added it below so it adds new noise sound0 and then you play it the same time as channel 3 const byte sound1[] = { 0x40,0xAB,0x01,0x08,0x42,0xAB,0x71,0x08,0x18,0x11,0x50, }; const byte sound2[] = { 0x80,0x5A,0x00,0x08,0x82,0x5A,0x70,0x08,0x18,0x11,0x90, }; const byte sound3[] = { 0xc0,0x2B,0xf0,0x0c, 0xd0 }; const byte sound0[]={ 0x02,0x33,0x0c,0x1c,0x11, 0x10 }; const sound_t snd_table[] = { {sound1,SOUNDAREA1}, {sound2,SOUNDAREA2}, {sound3,SOUNDAREA6}, {sound0,SOUNDAREA4}, }; } if(keypad_1==3){ disable_nmi(); print_at(1,2,"BOUTON 3"); play_sound(3); play_sound(4); enable_nmi(); } Edited January 18, 2020 by digress 1 Quote Link to comment Share on other sites More sharing options...
Serguei2 Posted January 18, 2020 Author Share Posted January 18, 2020 Thanks. It works. 1 Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted January 18, 2020 Share Posted January 18, 2020 16 hours ago, digress said: need to combine tone 3 with noise in order to hear. you can't just play noise separately. so you end up with 2 tone channels + 1 noise or 3 tone channels. Is this a Colecovision software limitation? Because the datasheet for the sound chip doesn't mention any interaction between channel 3 and noise. Well, I'm finally in the process of writing diags for the sound chip, so I guess I'll find out soon enough. Quote Link to comment Share on other sites More sharing options...
Serguei2 Posted January 18, 2020 Author Share Posted January 18, 2020 Ok. If I want to use white noise I would write this? Quote const byte sound0[]={ 0x00,0x33,0x0c,0x1c,0x11, 0x10 }; Quote Link to comment Share on other sites More sharing options...
digress Posted January 19, 2020 Share Posted January 19, 2020 that seemed to work: this works too: //Simple Bass ch0: 0x00,0x00,0x06,0x08,0x24 ,0x10 ch3: 0xc0,0x40,0xf0,0x0c ,0xd0 Quote Link to comment Share on other sites More sharing options...
Serguei2 Posted January 19, 2020 Author Share Posted January 19, 2020 Thanks. I'll check it out. Quote Link to comment Share on other sites More sharing options...
newcoleco Posted February 11, 2020 Share Posted February 11, 2020 On 1/18/2020 at 3:26 PM, ChildOfCv said: Is this a Colecovision software limitation? Because the datasheet for the sound chip doesn't mention any interaction between channel 3 and noise. Well, I'm finally in the process of writing diags for the sound chip, so I guess I'll find out soon enough. It's a hardware thing. The sound chip specifications are telling us that we can use the "frequency" data from the channel tone 3 as an input for the noise channel if this one is set for it. I do use this "peculiar chemistry" in all my ColecoVision musics. The mode 3 on the noise channel is called PERIODIC NOISE tuned with the TONE 3 (sort of) to produce a BASS instrument sound. The mode 7 on the noise channel is called WHITE NOISE tuned with the TONE 3 channel, allowing for cool explosions sound effects without being limited to only 3 presets of white noises. Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted February 11, 2020 Share Posted February 11, 2020 (edited) 3 hours ago, newcoleco said: It's a hardware thing. The sound chip specifications are telling us that we can use the "frequency" data from the channel tone 3 as an input for the noise channel if this one is set for it. I do use this "peculiar chemistry" in all my ColecoVision musics. The mode 3 on the noise channel is called PERIODIC NOISE tuned with the TONE 3 (sort of) to produce a BASS instrument sound. The mode 7 on the noise channel is called WHITE NOISE tuned with the TONE 3 channel, allowing for cool explosions sound effects without being limited to only 3 presets of white noises. Interesting. In my tests, I can run all 4 channels at once, but didn't notice that it used channel 3 as the base freq for channel 4. I see that 4 lets you program in a frequency divider, though the data sheet didn't make it obvious what frequency was being divided. Okay, it's finally clear in the block diagram (figure 4). So you CAN run them separately or all at once, but the noise is still based on channel 3. Edit: Or maybe what the sheet says is that the noise clock divider has 4 settings: N/2048, N/1024, N/512 (all where N is the reference clock), or N=tone #3. If that's the case, it has one mode where it depends on tone 3, and 3 where it doesn't. Edited February 11, 2020 by ChildOfCv Quote Link to comment Share on other sites More sharing options...
Tursi Posted February 12, 2020 Share Posted February 12, 2020 Looks like you got it in your edit... both white noise and periodic noise have four modes each - three modes are pre-defined shift rates, and the fourth takes the shift rate from channel 3. You can always run channel 3, audibly, at the same time -- even when it's clocking the noise channel. The volume settings are independent. But it's a little less useful if you're trying to play tuned sounds on the noise channel. 1 Quote Link to comment Share on other sites More sharing options...
