Tonyscouter Posted January 30, 2020 Share Posted January 30, 2020 When you open the 5200 the metal shield has an opening to adjust a red potentiometer, what is that for? Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted January 30, 2020 Share Posted January 30, 2020 That red plastic item visible through the hole in the RF shield is not a potentiometer. It’s an RF coil that adjusts the audio carrier part of the RF signal. It’s very fragile, doesn’t adjust very much and it you do adjust it, use a plastic or ceramic screwdriver because anything conductive will affect the signal. There are two other actual potentiometers on the board outside the RF shield - the larger one is the color pot, the smaller is the POKEY adjust resistor, which affects calibration of the analog control circuit. Quote Link to comment Share on other sites More sharing options...
orion1052003 Posted January 31, 2020 Share Posted January 31, 2020 I have a maker matrix controller and it doesnt work, but was tested and works with other 5200s. Do I need to mess with the potentiometer to make it work? The multicart menu goes a scrolling like crazy when i plug the controller in and i can't select or run a game. I can with the original controller. Quote Link to comment Share on other sites More sharing options...
Tonyscouter Posted February 4, 2020 Author Share Posted February 4, 2020 On 1/30/2020 at 9:35 AM, DrVenkman said: That red plastic item visible through the hole in the RF shield is not a potentiometer. It’s an RF coil that adjusts the audio carrier part of the RF signal. It’s very fragile, doesn’t adjust very much and it you do adjust it, use a plastic or ceramic screwdriver because anything conductive will affect the signal. There are two other actual potentiometers on the board outside the RF shield - the larger one is the color pot, the smaller is the POKEY adjust resistor, which affects calibration of the analog control circuit. Thank you for the information. I did a video mod to get composite out so I have no need to adjust the red coil. Quote Link to comment Share on other sites More sharing options...
