[email protected] #1 Posted January 31, 2020 I recently purchased an Atari 130XE, in "perfect" condition. The computer boots, but composite video has no output (screen is completely black). The SVideo output provides nice and crisp video. The composite cable works on my 800xl, so the cable is fine. Before I open it up, any ideas what might be the culprit? Quote Share this post Link to post Share on other sites
+Nezgar #2 Posted January 31, 2020 That's not a failure symptom I've seen before. First thing I'd do is go ahead and open it up to see if any mods have been done by a previous owner, because for instance if a stereo pokey upgrade was installed, the composite video pin may have been repurposed for the right audio channel if the previous owner didnt want to make any new holes in the case... 2 Quote Share this post Link to post Share on other sites
Gavin1968 #3 Posted January 31, 2020 I have to agree with Nezgar, it probably has been modified and that connection either disconnected or repurposed. Need to open it an explore. Quote Share this post Link to post Share on other sites
+hueyjones70 #4 Posted March 25, 2020 I have an 800XL that has no composite video. No mods. Which POKEY pin is the composite video. Quote Share this post Link to post Share on other sites
ApolloBoy #5 Posted March 25, 2020 16 hours ago, hueyjones70 said: I have an 800XL that has no composite video. No mods. Which POKEY pin is the composite video. The POKEY isn't responsible for generating video, that would be the GTIA. Even then there isn't a pin for composite video on the GTIA, it's generated through additional circuitry as the GTIA outputs a chroma signal and four digital luma signals. Looking at the schematic, you may want to try replacing U20 (a 4050 hex inverter) as that's the only IC involved in generating the 800XL's video signals outside of the GTIA. Failing that, you may want to take a look at transistors Q2 through Q5 as those are also part of the video circuitry. 3 Quote Share this post Link to post Share on other sites
+hueyjones70 #6 Posted March 25, 2020 Thanks for the info. I will look at the transistors, I have already tried replacing the 4050 (U20). I realize now that the previous reference to the video pin was for the composite pin for the monitor cable. Quote Share this post Link to post Share on other sites
ApolloBoy #7 Posted March 25, 2020 By any chance is the RF output working? If so, the problem might be elsewhere as the composite video signal is also piped into the RF modulator. Quote Share this post Link to post Share on other sites
ChildOfCv #8 Posted March 25, 2020 From what I can see, an unmodified 800XL should already have composite output. The schematics show that it's connected. J2 (the DIN plug), pin 4 IIRC. Quote Share this post Link to post Share on other sites
+hueyjones70 #9 Posted March 25, 2020 2 hours ago, ChildOfCv said: From what I can see, an unmodified 800XL should already have composite output. The schematics show that it's connected. J2 (the DIN plug), pin 4 IIRC. I know that an 800XL has composite video, the issue is that the composite video is not working on the 800XL that I am currently repairing. Quote Share this post Link to post Share on other sites
ChildOfCv #10 Posted March 26, 2020 Oh, well your initial question made it sound like you were looking to mod it. Okay. Do you have RF output? Most of the outputs are interconnected through passive parts (resistors, capacitors, and chokes), so it's not likely that you'd lose only one output. It's possible that the DIN plug has a bad connection though. Quote Share this post Link to post Share on other sites
+hueyjones70 #11 Posted March 26, 2020 54 minutes ago, ChildOfCv said: Oh, well your initial question made it sound like you were looking to mod it. Okay. Do you have RF output? Most of the outputs are interconnected through passive parts (resistors, capacitors, and chokes), so it's not likely that you'd lose only one output. It's possible that the DIN plug has a bad connection though. I chose this topic because it sounded similar to my situation. I don't know if I have RF or not I don't have a TV that I could connect to. I use a monitor. I will check the monitor DIN. Quote Share this post Link to post Share on other sites
+hueyjones70 #12 Posted March 27, 2020 The problem was with the monitor DIN. 1 Quote Share this post Link to post Share on other sites
