Lardo Boffin
Atari 800 lotharek SD2IEC multi-disc games
Hi
Does anyone know how to work multi-disc games on the lotharek SD2IEC connected to an Atari 800 (not XL)?
I have managed to put the four discs of Phantasie II into disc slots 1 to 4 (select the correct disc and then press 1, 2, 3 or 4. Simple once I worked out how!) but when I boot from disc 1 it soon asks for disc 3 but nothing I have tried so far allows me to mount disc 3 and load the rest of the game.
Any help appreciated thanks!
SD2IEC is a commodore device - do you mean SIO2PC or SIO2SD?
I think they said sio2sd in a different thread.
see the .pdf file in post #25 of this link:
Turns out I was over thinking the whole process. 😜
Just put all the discs in a separate folder called Phantasie II, call them D1, D2 etc. (so it is easy to see which is which on the LCD screen) and then use K2 to move between them at run time and K4 to mount. Simples!
Spent way too much time setting up multi-disc .LST files etc. on the C64 so I can play Wasteland.
