Mehridian Sanders #1 Posted February 2, 2020 I thought I saw a thread at one point where you could put the TI-99/4a inside the PEB. Was I mistaken or badly associating ? Sent from my SM-G955U using Tapatalk Quote Share this post Link to post Share on other sites
+arcadeshopper #2 Posted February 2, 2020 there are two computers (so far) that run in a PEB. neither are the original TI.. Myarc Geneve SGCPU – Second generation CCU Card 2 Quote Share this post Link to post Share on other sites
Mehridian Sanders #3 Posted February 2, 2020 Much obliged .. now to learn of this new (to me) project.Sent from my SM-G955U using Tapatalk Quote Share this post Link to post Share on other sites
+Ksarul #4 Posted February 2, 2020 Actually, you can put the console into a Rave PE-2 if you purchased the appropriate interface card when you bought the PE-2. I suspect that less than 10% of the 100 or so PE-2 boxes sold had this additional interface card though, as I have only ever seen one of them in the wild (out of the dozen or so of the PE-2s that I've owned or seen in the past). Quote Share this post Link to post Share on other sites
+arcadeshopper #5 Posted February 2, 2020 2 minutes ago, Ksarul said: Actually, you can put the console into a Rave PE-2 if you purchased the appropriate interface card when you bought the PE-2. I suspect that less than 10% of the 100 or so PE-2 boxes sold had this additional interface card though, as I have only ever seen one of them in the wild (out of the dozen or so of the PE-2s that I've owned or seen in the past). Pictures? Where's this documented? 1 Quote Share this post Link to post Share on other sites
+Ksarul #6 Posted February 2, 2020 (edited) I don't own one (I didn't get one for either of the PE-2 boxes I own)--but the PE-2 manual documents it. . .and as noted, I've seen one person who actually had one in their PE-2. I don't think the manual is on WHT though. Looks like I need to dig mine out and scan it in one of these days. . . Edited February 2, 2020 by Ksarul 2 Quote Share this post Link to post Share on other sites
+arcadeshopper #7 Posted February 2, 2020 29 minutes ago, Ksarul said: I don't own one (I didn't get one for either of the PE-2 boxes I own)--but the PE-2 manual documents it. . .and as noted, I've seen one person who actually had one in their PE-2. I don't think the manual is on WHT though. Looks like I need to dig mine out and scan it in one of these days. . . Ok so basically this is a replacement PEB that had a main board hookup in part of it? Quote Share this post Link to post Share on other sites
+Ksarul #8 Posted February 2, 2020 Yes, it was a PC case and it expected you to put shorting leads on the regulators to bypass them. It had a custom card cage in it with an extended backplane--adding a 34-pin extension to the usual 60-pins. The only card that ever actually used the additional connections was the console interface board. It required that you took the TI mainboard out of the case and connect it to the interface board. It also let you use a PC keyboard with it. It was the only TI aftermarket PEB to actually sell more than a few examples. One other was the MicroStuph board sold by Ryte Data (I have one of the boards but not the case it was designed for). Both of these required the shorted voltage regulators, and caused a lot of problems later, when folks tried to move the cards back to a regular PEB and accidentally blew up their systems. . .failure to remove the shorting wires is a very bad thing in this type of situation. Quote Share this post Link to post Share on other sites
+arcadeshopper #9 Posted February 2, 2020 Yeah sounds like a nightmare waiting to happen. I have a stack of blown up boards with the regulators removed I've gotten from various people. So basically NO there's no way to use the TI in a stock PEB ..only in one that nobody has and nobody can get. 1 Quote Share this post Link to post Share on other sites
+Ksarul #10 Posted February 2, 2020 Almost true--a SNUG SGCPU is a modified TI console for the PEB--but it does need an EVPC (1 or 2) and an HSGPL card to work, as the three cards together replace all motherboard functionality (and add some additional things too, like some AMS memory). Quote Share this post Link to post Share on other sites
+dhe #11 Posted February 2, 2020 There was the sort of pbox made by Captains Wheel. I was a 3 card interface the plugged directly in the side of a of a console. I think I purchased mine from Harry Wilhelm. 1 Quote Share this post Link to post Share on other sites
sparkdrummer #12 Posted February 2, 2020 Had a member in our VAST group that had a Rave 99 PE-2 with the console adapter card. I was over there about every weekend trying to get the damn thing working for him. He also had a Myarc HFDC in the box which I think complicated the matter. 2 Quote Share this post Link to post Share on other sites
+Ksarul #13 Posted February 2, 2020 5 hours ago, dhe said: There was the sort of pbox made by Captains Wheel. I was a 3 card interface the plugged directly in the side of a of a console. I think I purchased mine from Harry Wilhelm. I haven't ever seen this one. I do have a three-slot side-attaching sort-of PEB, but it exposes the cards and looks like it may have been a one-off made using the plans for a simple 3-slot PEB out of Australia. 1 Quote Share this post Link to post Share on other sites
+Schmitzi #14 Posted February 2, 2020 21 hours ago, arcadeshopper said: Pictures? Where's this documented? For the Rave PE2, I have this pics 2 Quote Share this post Link to post Share on other sites
+Schmitzi #15 Posted February 2, 2020 and this doc: types: Manual: RAVE99_PE2-Expansion-Chassis.pdf 3 Quote Share this post Link to post Share on other sites
RickyDean #16 Posted February 3, 2020 I have a Rave PE-2/C. I am currently putting the board into a tower case, as somewhere the top shell of the case has come up missing. Was going to use a Geneve (or the upgrade when finished) and TI with a TIM as I ha d planned many years ago. Just have to wire a ATX PS to act like the original. 1 Quote Share this post Link to post Share on other sites
+arcadeshopper #17 Posted February 4, 2020 thanks I'll add that to the FAQ Quote Share this post Link to post Share on other sites
+9640News #18 Posted February 4, 2020 On 2/2/2020 at 5:31 PM, Schmitzi said: For the Rave PE2, I have this pics I had one of those back in the 90's I had my Geneve in. Wish I still had it. Beery 2 Quote Share this post Link to post Share on other sites
Omega-TI #19 Posted February 5, 2020 The are a couple of pictures that found there way to my HD a few years ago. I'm thinking Schmitzi originally posted them (because his name was on a file in that directory). 1 Quote Share this post Link to post Share on other sites
