Compile bug in ATASM and MADS?
tsom
I, for my own amusement, was trying to build the source to ANALOG Magazine's RaceInSpace (https://ksquiggle.neocities.org/asmgames/raceinsp.htm / https://github.com/jtsom/AnalogSourceCode/blob/master/RaceInSpace.asm ) and using ATASM it was generating an Immediate Overflow warning on this snippet of code:
ORIGIN	=	$1000
DRAM	=	ORIGIN+$1000
    *= $0090
GRP20P	*=	*+2	;scrn pntr -20
    *= $600
    LDA	# <DRAM-20	;w/offset lo  -- Warning here
	STA	GRP20P	;offset pntr lo
	LDA	# >DRAM-20	;w/offset hi
	STA	GRP20P+1	;offset pntr hi
(this is snipped from around line 1745).
Looking at the generated code from ATASM I see:
In test.s, line 11--
 Warning: Immediate overflow
00:06  A9 EC        LDA # <DRAM-20      ;w/offset lo
02:06  85 90            STA     GRP20P  ;offset pntr lo
04:06  A9 0C            LDA     # >DRAM-20      ;w/offset hi
06:06  85 91            STA     GRP20P+1        ;offset pntr hi
Using MADS I get the same assembled bytes. (without any warnings)
Using the original Mac/65 assembler the assembled bytes are:
04:06  A9 1F            LDA     # >DRAM-20    ;w/offset hi
Notice the high and low bytes of the LDA instructions. Aside from I'm not sure why Atasm is giving the warning, it looks like both assemblers are taking the high and low bytes of the address BEFORE subtracting 20. Mac/65 (correctly?) subtracts first THEN gets the high/low bytes. Now I can make it assemble correctly(?) if I add parenthesis - LDA #<(DRAM-20), which is fine, but if attempting to build old code that doesn't take that into account, lots of errors and crashes will happen. I can try to post issues (somewhere) for this on the respective assemblers, but it doesn't look like ATASM is even maintained anymore.
Thoughts?
Thanks!
Probably a difference in evaluation priority as you mention.
It would probably be preferable that the low/high byte operators only act on the immediate following part of the expression since that gives both options - bracketting the rest as you show gives the other option.  I guess if it did it the other way then you might need to use LDA # (<DRAM) - 20 which would likely confuse the assembler and give an error.
I think you're right about AtAsm not being actively supported.  I used an older build for a time that had some annoying nasty bugs so sought out the current one of the time.  I think someone resurrected it for a little while to add a couple of features/fixes but AFAIK it's an inactive project for some time now.
The advantage of AtAsm is you can feed it Mac-65 source with minimal modification.
MADs though, does have a bit of a learning curve but is well supported and somewhat more powerful than AtAsm.
Best bet is to endure a bit of initial pain and use the better product.
I suppose my main question is, is the way Mac/65 assembling the correct output? I would think it would be - which would mean both Atasm and MADS, without any changes, are incorrect.
The down side to MADS is you have to build it from source. And being on MacOS, it took a little doing. Luckily the Free Pascal compiler comes as a Homebrew package, so all it took was 'brew install fpc' to have it, then just build the MADS source. And also the page/site isn't fully in English, (and the source isn't in something like Github), so have to keep checking to see if there's a new version.
Thanks for the help, either way!
  • 3 weeks later...
MAC/65 is right, the unary operators < and > should extract the low and high byte, respectively, from the value of the operand. Which means that the assembler should first evaluate the entire expression and then apply the unary operator.
It has always been natural for me, and not only for me, as it seems - see a snippet from the WDC's 65C816 manual, chapter six:
Quote
6.3.3.4 The assembler shall use the <, >, and ^ characters after the # character in immediate address to specify which byte or bytes will be selected from the value of the operand. Any calculations in the operand must be performed before the byte selection takes place.
ATASM has the precedence also in its docs. Same as MADS regarding unary < > and binary + -. For me, this is also strange, but it has the advantage, that it has same precedence as unary -, e.g. -5+7 is 2 and not -(5+7) = -12. And you can use expressions like x+<y+z, where you probably don't expect x+<[y+z].
So put the expr in brackets [] and it works as it should without warnings, e.g. lda #<[adr-1].
Yes, they both say the have the same precedence. But I'd say that the < and > are not quite the same as math functions (+, -). The < and > should act on the result of any calculations of the operand - returning the high / low bytes of the calculated address. Going forward (if I choose to use ATASM or MADS) I can remember to use ( ) to get the precedence right - but if I want to compile old code with these newer compilers, I'd have to make sure to watch for that code, so it compiles correctly (like the RaceInSpace code where I originally found the issue).
