Sign in to follow this
jenorton
Loading Myarc Disk Manager from Extended Basic
Hi:
I have a copy of the Myarc Disk Manager (mdm150.dsk) which is supposed to load from Extended Basic.  I can use "CALL MDM" to load it, but, if I let Extended Basic load it through the "LOAD" program, it says "Subprogram not found in 100".
Seems like this happens when the CALL LINK("SLOAD") statement tries to execute.
Do I have an outdated version? or is something genreally wrong with the latest version.
Thanks!
18 minutes ago, jenorton said:
Hi:
Thanks!
Might Crash in RXB, I had to rewrite my loader using RXB instead.
I used a dump of the code in Lower 8K from the CALL LINK("SLOAD") on disk to make a copy for my RXB CALL BSAVE("DSK2.MDMLOAD")
The dump was converted to TEXT and RXB opened it like a DV80 file to read the bytes and move them into Lower 8K using CALL LOAD.
That way the BSAVE just made a Program Image file of the lower 8K loaded by BLOAD thus CALL BLOAD("DSK2.MDMLOAD") did the same thing with out crashing.
The reason for the crash is that the loader used a GRAM address that did not really make sense and was a bug used to make the loader work, RXB removed that bug.
Note that it is also part of three of the XB Suite cartridges: XB 2.7 (Tony Knerr), Expanded BASIC 3 (Winfried Winkler), and Triton Super Extended BASIC. I use them all the time when I want to load the Myarc Manager.
