rietveld
how to make physical TI disks
Some years ago I wrote some utilities for reading and writing floppy disks on the PC. You need a 3.5" or 5.25" drive, and Linux.
19 minutes ago, rietveld said:
Is there a way to use a PC to make disks for my ti
Yes, although I haven't done it in a while...
You need a PC with a motherboard BIOS capable of using a 360kb DS/DD floppy drive. And "TI99-PC" software:
http://www.99er.net/download2/index.php?act=view&id=243
As a side note: I didn't use Omniflop for Windows, just did it in DOS.
I remember having to format the disk in a real TI PEB floppy drive first before I could successfully write disk images to it using TI99-PC.
Yup, I make disks all the time.  I have an Asus motherboard (its on the compatible list), 360K floppy and  XP installed. I have DOS 5 on a bootable floppy. I use TI99-PC, I boot off my floppy then I create all my disks using TI99-PC. Very simple once you have all the peices.
  • Like 4
Frankly it's easier to hook up a HDX server and make them in the TI. In the FAQ I link to the post walking though the steps.
If you have the xb27 cart it includes the software and is also available for the finalgrom
Sent from my LM-G820 using Tapatalk
I use a gotek drive as drive 2 and a half ht floppy Drive as drive 1, (some prefer the other way around), then I can move my flashdrive files between the PC,(my laptop), and the gotek and I can also copy from gotek to floppy Drive.
I agree. Keeping around an old PC with the proper low density drive is cumbersome. I have installed in my PEB a second RS232 card dedicated to the HDX and all I have to do is plug in my USB to serial adapter into it connected to my laptop. The downside of HDX disk transfers is that they are quite slow.
Thank you for the links. I was able to make a few disks using my old win 95 machine with a 5 1/4 drive and the software
Supposedly I can use my SuperCard Pro to make physical disks from images.  Have never tried it.  Should add that to my List of Things To Do One Day.
pc99 has a utility to transfer whole disk. you start pc disk transfer on the ti, and pc99 + ti disk transfer on the pc and you have a choice to copying the disk one direction or the other. It uses a rs232 cable to attach both machines.
I use the "old school" method. I copy the files in a .dsk or other file to my USB 3.5" drive on my PC with a TIFILES header using either TI99Dir or TI Image Maker. Then, I take the physical PC-formatted disk and put it in my TI and transfer the contents to a TI-formatted disk (I have 3.5" disk drives in it as well) and copy between them using PC-TRANSFER. Despite what the docs say, it will handle 720K disks. A bit slower, but it works just fine.
