Bikerbob
800xl all ram bad??
Hello all, I fixed my one 800xl for my friend - only 1 bad ram chip - lucky!
The other one the ram was heating up.. I tested the chips one by one in a known good working machine.. EACH ONE Failed to boot it.
Have you seen all 8 ram go bad without something else causing it?
I am afraid to put new ram in...
James
Never had a machine where all RAM was bad that wasn't caused by using an incorrect power supply.  That being said, usually if I am replacing one chip, I'll do all 8.
No the MT branded ram.. only one chip was bad in that machine.
its Mostek 4564-15..
All the personality chips are fine in the machine.. nothing else got hot.
James
If the power supply failed or if a c64 power supply was used then yes, I’d suspect all the ram to be fried plus mmu ( at the very least ). drams are quite sensitive to overvoltage and usually die instantly.
remove all the ram first then check +5 voltages ( in case there’s still a shorted component somewhere ) before troubleshooting or swapping in new chips.
When replacing the RAM chips, are the following chips acceptable replacements?
TMS4164-12 / MN4164-12 / HM4864P-2
16-Pin Dip DRAM - brand new
64Kx1 bit DRAM
TMS4164 - Texas Instruments
MN4164 - Panasonic
HM4864 - Hitachi
Edited by pusakat
Spelling error
YES, , one thing I would say and agree.. try and keep all 8 the same.. trying to mix chips does not mean they are bad, but might not work together.. my experience in this thread.
To those that were following.. 8 new ram chips in.. machine is good.. mmu was not an issue.
James
If it is Freddie machine (C061991-29 - NCR, C061922 - CITEL ) - replace it, probably it is issue. Fault Freddie can damage all DRAM chips mounted in computer in future.
64Kx1 bit DRAM
MN4164 - Panasonic
HM4864 - Hitachi
TI are my favourites but the speed is more important. Try to match the speed that you had in there before or install slightly faster ones. 120ns work fine
