Sign in to follow this
damosan
Native debugger
Morning All,
I'm working on something in CA65 (assembler that comes with cc65) - I need a native debugger that I can run on the Atari that stays out of the way until a BRK instruction is encountered.  Normally I'd use an emulator but I'm interfacing with a bit of hardware so I need something on the Atari.
Any suggestions?
I personally found DDT (from the Mac65) pretty workable and would recommend it. Of course, a debugger within an emulator is more powerful.
1 hour ago, damosan said:
Morning All,
Any suggestions?
Altirra can emulate most commonly-encountered hardware very accurately. Unless you’re going to emulate something quite unusual like a satellite radio receiver or something like a home built A/D converter with the joysticks, I’d suggest you use Altirra.
Posted (edited)
Turbo Freezer might be an option if you can get your hands on one (and afford it).
When I did native development, I usually used ATMAS II, which has a monitor/debugger built in:
atari000.png.d8bdf70e95098d037f22ffca3cbce16e.pngatari001.png.6a9e14fcd52f2b32757aff23e53b6f9b.png
After that you can use M (memory dump) and D (disassemble) to look what happened.
Edit: manual in German and partly translated to English: https://github.com/ivop/atmas2-manual
Edit2: download link: https://atariwiki.org/wiki/Wiki.jsp?page=Atmas II
Edited by ivop
There's various OSes with monitor built in like Omniview, QMeg etc.
The advantage is they can be unobtrusive as in not steal part of the address space that otherwise is needed by a cartridge etc.
