+Andrew Davie Posted January 2, 2021 Share Posted January 2, 2021 "WiFi Firmware Update" is not working for me -- either on my guest, or my regular network. I have tried two carts (one with ESP8266 v 1.1.0.0 and the other with ESP8266 v 1.6.2.0). Neither changes firmware version after I do an update. Am I misunderstanding this feature? Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted January 2, 2021 Author Share Posted January 2, 2021 43 minutes ago, Andrew Davie said: "WiFi Firmware Update" is not working for me -- either on my guest, or my regular network. I have tried two carts (one with ESP8266 v 1.1.0.0 and the other with ESP8266 v 1.6.2.0). Neither changes firmware version after I do an update. Am I misunderstanding this feature? after you switched to the "Setup" menu wait 10 seconds before you press "WiFi Firmware Update" Link to comment Share on other sites More sharing options...
+Andrew Davie Posted January 2, 2021 Share Posted January 2, 2021 23 minutes ago, Al_Nafuur said: after you switched to the "Setup" menu wait 10 seconds before you press "WiFi Firmware Update" No luck. Menu item either returns immediately, or I see the "wait" spinner for about a minute, and then the Setup menu again. And the firmware version of the ESP8266 has not changed. Tested on both carts -- v1.1.0.0 and v1.6.2.0. Tried both guest and regular networks. Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted January 2, 2021 Author Share Posted January 2, 2021 36 minutes ago, Andrew Davie said: No luck. Menu item either returns immediately, or I see the "wait" spinner for about a minute, and then the Setup menu again. And the firmware version of the ESP8266 has not changed. Tested on both carts -- v1.1.0.0 and v1.6.2.0. Tried both guest and regular networks. Can you test with the new dev version from GIT Link to comment Share on other sites More sharing options...
Prizrak Posted January 2, 2021 Share Posted January 2, 2021 Want me to test on the new release as well?Sent from my SM-N960U using Tapatalk Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted January 2, 2021 Author Share Posted January 2, 2021 1 minute ago, Prizrak said: Want me to test on the new release as well? Sent from my SM-N960U using Tapatalk Yes, your WiFi firmware version should be 1.6.2.0 too. (can be checked in "Setup/System Info"). Wait 10 seconds before "Setup/WiFi Firmware Update". Link to comment Share on other sites More sharing options...
+Andrew Davie Posted January 2, 2021 Share Posted January 2, 2021 7 minutes ago, Al_Nafuur said: Can you test with the new dev version from GIT Tested. No luck on either. Link to comment Share on other sites More sharing options...
Prizrak Posted January 2, 2021 Share Posted January 2, 2021 Mines already on 1.6.2.0 so I'm good it seems Sent from my SM-N960U using Tapatalk Link to comment Share on other sites More sharing options...
+Andrew Davie Posted January 2, 2021 Share Posted January 2, 2021 Just now, Prizrak said: Mines already on 1.6.2.0 so I'm good it seems Sent from my SM-N960U using Tapatalk No, I think 1.6.2.0 is the version prior. If you see 1.6.2.0 then you update, you should see 1.7.something...? Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted January 2, 2021 Author Share Posted January 2, 2021 Just now, Prizrak said: Mines already on 1.6.2.0 so I'm good it seems Sent from my SM-N960U using Tapatalk the newest version is 1.7.4.0, so "WiFi Firmware Update" should be available.. Link to comment Share on other sites More sharing options...
Prizrak Posted January 2, 2021 Share Posted January 2, 2021 Ah, so guess mine isn't updating either when I try.Sent from my SM-N960U using Tapatalk Link to comment Share on other sites More sharing options...
Prizrak Posted January 2, 2021 Share Posted January 2, 2021 Surprised it doesn't update when the firmware update goes out, is it because it's a separate part in the cart?Sent from my SM-N960U using Tapatalk Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted January 2, 2021 Author Share Posted January 2, 2021 2 minutes ago, Prizrak said: Surprised it doesn't update when the firmware update goes out, is it because it's a separate part in the cart? Sent from my SM-N960U using Tapatalk yes, for updating the WiFi modul (if available) you have to select: "Setup/WiFi Firmware Update" Link to comment Share on other sites More sharing options...
Prizrak Posted January 2, 2021 Share Posted January 2, 2021 Yep, I tried that and got the same results as@Andrew Davie Sent from my SM-N960U using Tapatalk Link to comment Share on other sites More sharing options...
+Andrew Davie Posted January 2, 2021 Share Posted January 2, 2021 (edited) I'd like to see the System Info page made easier to read.... something like the following... PlusCart Device ID 0028blah3330851083036blah STM Firmware 0.16.5 DEV WiFi AT Firmware 1.6.2.0 Flash Size 1 MiB PlusStore ID 283 PlusStore Account namehere PlusStore API v0.13.2 Edit: Note the "MiB" instead of "MB". And also, if appropriate, use "KiB" Edit2: Note the space after the unit and before the suffix!! Edit3: Yes, I'm particular/pedantic about these things Edited January 2, 2021 by Andrew Davie 1 Link to comment Share on other sites More sharing options...
marauder666 Posted January 2, 2021 Share Posted January 2, 2021 (edited) Same result with wifi firmware update, stuck at 1.2.0.0. Get the spinner for 4 seconds then it returns to menu. Edited January 2, 2021 by marauder666 Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted January 2, 2021 Author Share Posted January 2, 2021 13 hours ago, Andrew Davie said: I'd like to see the System Info page made easier to read.... something like the following... PlusCart Device ID 0028blah3330851083036blah STM Firmware 0.16.5 DEV WiFi AT Firmware 1.6.2.0 Flash Size 1 MiB PlusStore ID 283 PlusStore Account namehere PlusStore API v0.13.2 Edit: Note the "MiB" instead of "MB". And also, if appropriate, use "KiB" Edit2: Note the space after the unit and before the suffix!! Edit3: Yes, I'm particular/pedantic about these things Just pushed some changes Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted January 2, 2021 Author Share Posted January 2, 2021 New draft version v0.16.6 DEV For draft User @Prizrak, @Thomas Jentzsch, @marauder666, @Andrew Davie and @Mr SQL new design for "System Info" page some changes in "WiFi Firmware Update" Link to comment Share on other sites More sharing options...
Prizrak Posted January 2, 2021 Share Posted January 2, 2021 What got changed in wifi update sir?Sent from my SM-N960U using Tapatalk Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted January 2, 2021 Author Share Posted January 2, 2021 3 minutes ago, Prizrak said: What got changed in wifi update sir? Sent from my SM-N960U using Tapatalk Wait 2 seconds and "clean" uart line to WiFi module before sending the update command. And reinitialize the WiFi module after an update: https://gitlab.com/firmaplus/atari-2600-pluscart/-/commit/b7a2fdfabb55f56c198bb82a0b5e62fe2e7ecbbb Link to comment Share on other sites More sharing options...
Prizrak Posted January 2, 2021 Share Posted January 2, 2021 I tried the update wifi option again and failed as before.Sent from my SM-N960U using Tapatalk Link to comment Share on other sites More sharing options...
Prizrak Posted January 2, 2021 Share Posted January 2, 2021 Being trapped at home I'm free for whatever testing you need me to do.Sent from my SM-N960U using Tapatalk Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted January 2, 2021 Author Share Posted January 2, 2021 5 minutes ago, Prizrak said: Being trapped at home because of COVID, hope you have a mild case. 11 minutes ago, Prizrak said: I'm free for whatever testing you need me to do. Sent from my SM-N960U using Tapatalk if you like you can test if you can reach from your WiFi network the espressif update server with your Browser: http://iot.espressif.cn/v1/device/rom/?is_format_simple=true everyone else that is having trouble with the "WiFi Firmware Update" can test from his WiFi network too. response should be: { "message": "key is nil", "status": 500 } Link to comment Share on other sites More sharing options...
Prizrak Posted January 2, 2021 Share Posted January 2, 2021 That's The exact response I got back.Sent from my SM-N960U using Tapatalk Link to comment Share on other sites More sharing options...
+Andrew Davie Posted January 2, 2021 Share Posted January 2, 2021 Same response for me. Link to comment Share on other sites More sharing options...
