Nolium
Atari 800XL, occasional picture problem after UAV install
Hi all,
can anyone give me some advice how can I diagnose and repair this issue. After I installed Ultimate Atari Video from The Brewing Academy I get mostly one sweet, sharp as sharpen knife picture (just awesome), but occasionally (every 10-20 power cycles) picture is just trash.
It is not a big problem, usually just takes single power cycle to return to normal.
So, the problem surfaces only occasionally when I turn on computer.
My guess: the TV , not the computer. I might be wrong, but that it is an easy test if you have another monitor.
I'll second that.  Looks like the TV is not properly synching to the Atari signal.
Holly crap, I think you are absolutely right. Tried to turn off TV and back on. Bingo, of sync picture on first try.
Thanks!
Thanks!
If you want to use this monitor / TV anyway, then change of the 500k color pot (lower left corner of your 800XL) might be worth a try. Sometimes after warming up these pots are changing their resistor significantly and this also forces some monitors / TVs to make a wrong colored picture like in your 2nd picture. It´s a standard pot, 500k, linear, 10mm pitch. Take a closed case one like Piher PT10 or so. It´s just a buck or less.
