rietveld
ADE Lite dfefault settings
Is it possible to permanently change the settings on the ADE Lite, so that DRIVE 2 is always disabled , so that i can use a physical disk drive as 2 without holding the grey button on power up every time
ADE v.080 and later keeps the change permanent until you boot holding down the button again. The newer update will also add the ability to run ColecoVision cartridge ROMs up to 32k.
- Added support for a disk swap button. The disk swap only works on Device 4. Holding down the swap button on startup will either disable Device 5 if it is currently enabled, or enabled all of the devices if Device 5 is currently disabled.
- Added ColecoVision cartridge ROM support (Maximum 32k). Files needs to have a COL, BIN or ROM extension.
Visit Sean's GitHub site for update files and instructions.
https://github.com/Kalidomra/AdamNet-Drive-Emulator
thank you
