Sign in to follow this
Gunstar
ST and the Internet.
I recently aquired and Supra modem, which I am already using on my Mac 6115PPC, and soon will have my Amiga 2000 (uprgaded with harddrive and 4megs) online too, but I'm most interested in getting my ST online. I'm wondering if it's possible to do so with only a megabyte of memory and no HD? I intend to upgrade the memory and give it an HD someday, and a blitter chip, but it'd be cool if I could go online with it now anyway...if it's possible to get online with a meg and one floppy drive, what programs will do it? Anyhow what programs are needed regardless? CAB? A TCP stack program? What else? What are they called, what are the alternatives, and most importantly, where can I find them online? Thanks!
I have not tried this myself, but I've seen pictures of the ST browsing the web. However, I don't know how much memory these machines have or what particular STs they may have been. Might be tough with just 1MB. I think you'll definitely have an easier time of it if you add more memory (say, 4MB total) and add a hard drive. I can't even imagine trying to browse the web on a floppy-based system.
I've also seen 8-bit systems surfing the web, if rather crudely, so I can't imagine it'll be all that difficult to get your ST online. Please keep us abreast of your quest, I'd like to learn more about this myself. :)
..Al
The first computer I ever used to get on the Internet was my 1040ST. :D Of course, back then it was about the same as dialing into a BBS. I just used Flash, and later ANSI, and my modem. If you're wanting to use the ST as more than just a dummy terminal, you'll need a TCP/IP stack such as STiK or STinG, and of course other software for doing things like browsing, such as CAB or Highwire. That's about the extent of my knowledge, as I never used my ST to get online in any other way than as a terminal. I'm sure there's plenty of others here who can give you much more detailed information than I can, but that should give you the basic gist of it.
I am not sure if 1 MB is enough. Nevertheless you have two possibilitiies, you can try STIK together with CAB or you can use Draconis packet.
I have my Falcon connected to the internet via tv cable and I am running Sparemint with all internet application without problem. I think that on the 1MB ST it will be more difficult but not impossible.
]with a 1mb st forget the www ..... for irc mail and news no problem
It can be done with 1 MB and no hard disk, but only if you want to prove it works. It's of no practical use and I wouldn't encourage it.
Its more than possible ive done it myself
attached is the directions to do it.
you need 2 blank disks and you dont need more than 1 disk drive
and 1 meg of ram no 520's
Setting Up
STinG 1.20 and CAB 1.5 on a 1 mb 1040 STf
____________________
by Tony Cianfaglione
In our user group, we have many members who are still using a plain
'vanilla' 1 mb (non-expandable) 1040 STf. These members would like to be
able to access the Internet, even if it is text-only, as most ISPs today
only offer PPP access. Locally, we are also fortunate to have one ISP
offering Lynx text dialup so that members currently access the Internet
using a terminal program such as Flash or Teddy Term.
For those who wish to use the TCP/IP package, STinG v1.20 by Peter
Rottengarter and Ronald Andersson and CAB (Crystal Atari Browser) v1.5,
this info sheet is for you. I have tested this setup on several 1040's
and a Mega2 and it works very well. I have not tried CAB v2.7 because
there is so much to that program that it would be difficult to fit onto a
720k disk. Both STinG 1.20 and CAB 1.5 in this document are run from 720k
disks and are fully optimized (thanks to many helpful suggestions from
Ronald Andersson, John Whalley, Ric Easton and others).
I have included parts of my email conversation with Ronald on these
programs as he can better explain the different procedures.
STEP 1: (Setting up STinG 1.20)
My final configuration files are included at the end of this document
so that you can compare them to what you have in the event you can't get
it to work just right.
I started out by formatting 2 - 720k double sided, double density
disks; one for STinG, the other for CAB.
On the STinG disk, I created several directories:
AUTO
CPX
STING
I placed the following files in the auto directory in the following
order so that they would load in that particular order:
DRVIN.PRG, MFP.PRG, STING.INF, STING.PRG
DRVIN.PRG and MFP.PRG are from the file: HSMODA07.LZH and STING.INF and
STING.PRG are from the STinG zipfile. Unzipping STinG 1.20 creates the
various files you need in their various sub-directories.
You should get the file called XCONTROL.ACC (version 1.31 is available
from ftp://ftp.cs.tu-berlin.de/pub/atari/Utils/XControl/ or
ftp://ftp.fu-berlin.de/atari/tools/xcontrol/) and put it in your root
directory as it is essential to load the CPX's and it will also create
your drop down Control Panel menu. Once STinG is unzipped and all files
are set up properly, your disk directory should look like this:
A:CONTROL.INF
A:XCONTROL.ACC
A:AUTODRVIN.PRG
A:AUTOMFP.PRG
A:AUTOSTING.INF
A:AUTOSTING.PRG
A:CPXSERIAL.CPX
A:CPXSTING.CPX
A:CPXSTING.PRT
A:CPXSTNGPORT.CPX
A:CPXSTNGPROT.CPX
A:STINGCACHE.DNS
A:STINGSTING.HYP
A:STINGDEFAULT.CFG
A:STINGROUTE.TAB
A:STINGTCP.STX
A:STINGUDP.STX
A:STINGSERIAL.STX
A:STINGRESOLVE.STX
A:STINGDIALERDIALER.APP
A:STINGDIALERDIAL.RSC
A:STINGDIALERDIAL.INF
A:STINGDIALERICON.RSC
A:STINGDIALERDIAL.SCR
A:STINGDIALERLOCAL.FEE
A:STINGDIALERLOGIN.BAT
A:STINGDIALERDIAL.LOG
A:STINGDIALERIP.INF
A:STINGDIALERCALL_ITCALL_IT.PC
A:STINGDIALERCALL_ITCALL_IT.PRG
A:STINGDIALERREM_CTRLREMCTRL.H
A:STINGDIALERREM_CTRLFAKE.PRG
A:STINGDIALERREM_CTRLREQUEST.PRG
A:STINGDIALERDEV_KITLOGSTRING
A:STINGDIALERTOOLSPING.PRG
A:STINGDIALERTOOLSPING.RSC
A:STINGDIALERTOOLSTRACROUT.PRG
A:STINGDIALERTOOLSTRACROUT.RSC
A:STINGDIALERTOOLSSAVE_IP.TTP
A:STINGDIALERTOOLSSYSINFO.TTP
A:STINGDIALERTOOLSSHUTDOWN.PRG
You will notice that there are some programs missing. Not all of the
programs included in the STinG 1.20 zipfile are necessary and can be
deleted to save precious RAM and disk space. Make sure that data in any
of the INF files (which are used to supply information to the program
files) are all in uppercase (CAPITAL) letters as STinG looks for the
uppercase letters.
Also ensure that RESOLVE.STX is loaded last. You should have 228,885
bytes remaining on the disk.
STEP 2: (Setting up CAB 1.5)
The CAB disk directory should look like this:
A:CABCAB.APP
A:CABCAB.INF
A:CABCAB.OVL
A:CABCAB.RSC
A:CABCABOVL.CFG
A:CABSTART.HTM
A:CABHOTLIST.HTM
A:CABMODULESCAB_JPEG.OVL
A:CABCACHENEWCACHE
A:CABCACHECACHE.CAB
A:CABCACHE subdirectories A through Z (needed for caching files)
You should have 293,406 bytes space remaining on the disk.
Included below is an email from Ronald Andersson on things to do at
this point to help save valuable disk space and ram on both disks:
Start CAB.APP *without* having the CAB.OVL present in the same folder.
That saves some RAM, and ensures that no attempt is made to contact STinG,
which was not booted this time around. With some luck this should allow
CAB to start up properly, though naturally only with offline capability.
Next you go through the display settings and turn off all image displays,
and set the RAM cache to some really low value (Try 0, it works here).
That cache won't really be needed anyway for most text pages, and you
can't get reliable graphics display without more RAM. Save these new
settings, and just to make sure, restart CAB to check that it is not
allergic to the settings saved (which has happened on some occasions).
Next, kill any STX files that you don't need, as they will only steal
RAM, and that may be more than just program size, if they need buffers.
The STXs you will not need, that are in the STinG 1.20 packager are
probably two. The ETHER.STX is for Peter Rottengatter's Ethernet board
(Riebl board I think.) and is not useful for you. MASQUE.STX is also
not useful, except if you want to use a modem connected to this STF,
and use it to masquerade some other machines. That is not a good idea
anyway, if you plan to use this machine for browsing, as it is not
really fast enough to do both things well. So you should erase both
ETHER.STX and MASQUE.STX, to save a little more RAM for CAB.
Since you will not be using multitasked STinG clients or servers either,
you can also try setting the ALLOCMEM value in DEFAULT.CFG to a lower value,
such as 50000 or 60000.
Now you reboot with the necessary STING.PRG, and XCONTROL, and the other
stuff you want, but still avoiding wasteful RAM usage. It is for example
important not to be using late-version NVDI, or THING desktop in such a
boot, as they both waste RAM something awful (for so small a system).
If you have done all the above properly you should be able to browse most
HTML documents online in text-only mode, but if you reach any really
'heavy' text pages (eg: the RFC index at FUNET.FI), then you can still
suffer bombs, as there may not be enough RAM free to read such huge files.
You may also need to experiment with the available CAB.OVL files, to see
if this makes any difference to the RAM used. It is very likely that the
newer and smarter (and more speed-optimized) versions may waste more RAM
than some older ones. So on a 'low-end' system like a 1040 STF, the old
stuff may work better. Only tests can prove it.
Regards: Ronald Andersson mailto:[email protected]
http://dlanor.atari.org/ ICQ:38857203 http://www.ettnet.se/~dlanor/
STEP 3: (Configuring the RAM and disk settings)
Ensure that you are using the 68000 version of CAB.OVL as I made the
early mistake of copying my Falcon install over, including the 68030
version which caused it to crash with 3 bombs. Using the correct version
fixed that problem. Another note from Ronald explains it better:
on Tue 15-06-1999 18:28 I wrote:
re: using a 68000-compatible CAB 1.5 version
>How do you tell the difference between them?
The 68030 version originally came in a separate archive, containing only the
program file and a small readme. The real CAB 1.5 package was still needed,
and it was that package that held the 68000 version. I'm not sure if these
versions have been 'repacked' by anyone though, so a size check may help.
The 68030 version is 288970 bytes.
The 68000 version is 290040 bytes.
All other files in the CAB 1.5 package are shared, so it is only the program
file that needs to be changed if you have the wrong one.
BUT..., there are also '030 versions of some of the CAB.OVL releases.
These may also bomb when loaded by CAB on a 68000 machine. That is one
reason why I recommended testing without any CAB.OVL present with CAB.
(Either in the same folder, or in the 'MODULES' subfolder.)
Do this to make sure that CAB itself will run properly, then install
various CAB.OVL versions until you find one that works.
If you want to avoid such problems for the users that visit your support
pages, the best way is to simply include only 68000-compatible versions.
These will run on all 680x0 machines, and there is very little difference
in their effective speed.
These reasons are also why STinG itself is only released in a single
version for all users, regardless of which CPU they use.
The following is a report I made during trial and error testing. It is
included for the benefit of anyone who may experience similar problems.
(Comments and suggestion from Ronald Andersson helped solve the problems):
Update:
After making the mods that Ronald suggested (ALLOCMEM at 50000),
ETHER.STX, MASQUE.STX, MASQUE.HYP deleted, I have STinG 1.20 running fine
on the 1 mb STf and I can connect successfully to the ISP.
I found the 68000 CAB.OVL but it is 35,626, not 29,000 bytes. I set
RAM to 0, CACHE to 0, left images on as a trial. CAB 1.5 connected and
images worked fine for first 3 pages then lockup.
(Ronald writes: You must have misunderstood me. I told you to set RAM
CACHE to zero, not RAM *and* disk CACHE. Given the
way CAB and CAB.OVL interact I doubt that CAB can work
correctly with no disk cache at all. Naturally you
can't have a very large disk cache on floppy, but you
can have enough for some simple text browsing, and
clean that cache out regularly after you are finished
with a site.)
Turning images off and saving changes, I went online again and selected
our ISP homepage which loaded fine. However, a new problem has occured.
After accessing the ISP's simple homepage, the words: Formatting text...
appear in the info line at the top of the screen and disk access is
constant. After 10 minutes, the disk drive is still running. I had to
cut the power to stop it.
(Ronald writes: I think this means CAB is trying to use the disk
cache while also trying to keep its size below the
zero value you set up above. That can't work of
course.)
Repeated tries all render the same results. Not sure if cutting power
corrupted the files. Turned images on again to see if I could connect as
I did originally but the same formatting text message and disk access
again. I can't seem to get any farther at this point.
T.-----
STEP 4: (First connection attempts and troubleshooting)
I made the changes as suggested by Ronald but I still have some
problems as noted below:
STinG connects fine, starting CAB works well until I enter the first
url for the Internet. When I first start CAB, it loads a special small
html file I have on the A: drive disk which is fine. So far so good -
I am successfully online with PPP on a 1040 STf and CAB is running.
Entering the first url:
http://www.chebucto.ns.ca/ (our freenet homepage)
with the images turned off, the page loaded is only 1400 bytes total.
I had set the disk ram, per your instructions, at 1 mb (the smallest
setting there is, unfortunately - any way around this limitation?) and
saved the settings. I get the same result as before.
(Ronald writes: I assume you mean "disk cache" above, not "disk ram"
as you wrote. (Mainly because the latter makes no
sense. ;-) Or in other words that you set the cache
size in the right half of that dialog to 1MB, and the
one in the left half to zero. It is also this dialog
that you will need to re-enter now and then to free
the disk cache space that has been used up, using the
"Free cache" button in the right half of the dialog.)
The page loads and the words "Formatting text..." appear in the url
header and the A: drive starts running with a 'chip-chip, chip-chip'
sound as if it were looking for something.
(My note: it was at this point, that I formatted another disk and
copied everything over...my testing and subsequent lockups trashed part of
the disk which was why I was getting the 'chip-chip' searching sound.)
STEP 5: (A successful connection...this was my report at this point!
I finally have it working well.
I refresh CAB immediately before proceeding with the first offsite URL
by freeing the disk cache and then doing it every 5 sites I visit.
I also created a fresh new disk and put the files there as I think I
may have trashed the first one by powering down when it was locked up.
Using graphics enabled, you need to flush your disk cache every 5 pages
on average; with graphics disabled, it would be every 15 - 20 pages unless
they are massively sized pages.
Using an SM124 or 125 monochrome monitor, I am able to enable images
although they are monochrome. Using an SC1224 color monitor, I cannot
enable monochrome or color mode for some reason but the text version works
well. With or without images, just being able to surf the 'Net using a
1040 STf (1 mb) machine is quite encouraging.
Please note that the DIAL.LOG file in the STINGDIALER directory will
grow with each login (successful or unsuccessful) and must be edited
occasionally to remove the stored lines otherwise it will eat up valuable
disk space.
The following configuration files are supplied to help in your setup:
CONTROL.INF:
A:CPX*.CPX
0
STING.INF:
A:STING
DIAL.INF:
A:STINGDIALER
LOGIN.BAT:
A:STINGTOOLSSAVE_IP.TTP A:STINGDIALERIP.INF Modem 1
START.HTM: (this is just a small html file I created to give CAB 1.5
something to look for as it will not seek an online page upon startup and
will crash if you don't supply it with a start page. The one included in
the CAB zipfile is quite large and takes a lot of RAM and disk space so I
am including my small start page here.)
Welcome To STinG 1.20
& CAB 1.5
Use the hotlist or enter a URL for Internet startup.
DEFAULT.CFG: (the MSS may differ with your ISP. The one supplied works
with mine. You can check with your ISP for their settings).
# This is the STinG relevant stuff.
ALLOCMEM = 50000
THREADING = 50
FRAG_TTL = 60
ICMP_GMT = -60
ICMP_AD = 10
ICMP_FLAG = 0
TCP_PORT = 1024
MSS = 956
RCV_WND = 3824
DEF_RTT = 500
DEF_TTL = 128
TCP_ICMP = 1
UDP_PORT = 1024
UDP_ICMP = 1
USERNAME =
HOSTNAME =
FULLNAME =
NAMESERVER =
DOMAIN = sting.org
DNS_CACHE = 64
DNS_SAVE = TRUE
PAP_ID =
PAP_PASSWD =
# Here starts the client relevant stuff.
# Used by the Dialer :
DIALER = 0.0.0.0
LOGIN_BATCH = A:STINGDIALERLOGIN.BAT
DIAL.SCR: (the MTU may differ with your ISP. The one supplied works with
mine. You can check with your ISP for their settings.)
# General Parameters
SERIALPORT = Modem 1
DEF_ROUTE = TRUE
MASQUERADE = FALSE
EXEC_BATCH = TRUE
CIX_LOGIN = FALSE
RESIDENT = FALSE
DEBUGGING = FALSE
# Port Parameters
CLIENT_IP = 0.0.0.0
MTU = 1006
PAP_ID = username (if applicable)
PAP_PASSWORD = password (if applicable)
PAP_PROMPT = FALSE
PROTOCOL = 1
VJHC = TRUE
LAN_PORT = FALSE
# Addressing
USERNAME = username (fill in yours)
FULLNAME = full name (fill in yours)
HOSTNAME = hostname (fill in yours)
NAMESERVER = your IP DNS number here (ie...123.45.67.890)
FETCH_DNS = FALSE
# Modem Specifics
INIT = ATZ
PREFIX = ATDT
HANGUP = +++,ATH
CONNECT_WAIT = 60
REDIAL_DELAY = 0
SUCCESS = CONNECT
FAILURE = BUSY
FAILURE = NO CARRIER
ABORT = NO DIALTONE
# Telephone
PHONE_NUMBER = put your ISP phone # here
FEE_FILE = LOCAL.FEE
ISP_TIME = 0, 0.00
ISP_SENT = 0, 0.00
ISP_RECVD = 0, 0.00
# Network Environment
# Dial Script
FIND_TIMEOUT = 30
DIAL_SCRIPT
SUPPORT URLs:
Ronald Andersson:
[email protected]
ICQ:38857203
John Whalley:
Site index: http://www.whalley.demon.co.uk/
Atari index: http://www.whalley.demon.co.uk/atari/
Sting setup helpsheet:
http://www.whalley.demon.co.uk/atari/texts...s/stingset.html
Peter Rottengatter:
http://www.stud.uni-hannover.de/~perot/index-e.html
ASH homepage:
http://www.application-systems.de/
Atari ST Quick FAQ:
http://bales.online.fr/atari
Nova Scotia Atari Computer Users Group website:
http://www.chebucto.ca/Technology/NSACUG
Homepage for this file:
http://www.chebucto.ca/Technology/NSACUG/f...aq/stfsting.txt
hi,
I never say impossible :)
but it's slow and not very usable for www
Thank you so much for those instructions, they will come in very handy, even if I do wait until I upgrade to at least a HD before attemting (I only have one drive now anyway).
