tschak909 Posted March 8, 2020 Share Posted March 8, 2020 Is there a reference for the Atari 822 other than the Owners manual? There is obviously bitmap output, but the Owners Manual only provides a BASIC program where the bitmap mode is obscured in an assembler routine. -Thom Quote Link to comment Share on other sites More sharing options...
jamm Posted March 8, 2020 Share Posted March 8, 2020 Maybe this will help: the APX Screen Dump Utility will do dumps of graphics to the 822. If you could look at its source code... https://archive.org/embed/APXScreenDumpUtility Quote Link to comment Share on other sites More sharing options...
+hunmanik Posted March 9, 2020 Share Posted March 9, 2020 Quote Link to comment Share on other sites More sharing options...
+playsoft Posted April 1, 2020 Share Posted April 1, 2020 I don't know if this will help but I disassembled the code from the owner's manual to see what it was doing. Basically if you send a SIO Put with Aux1 set to $4C ('L' for Line perhaps) then instead of printing the 40 bytes as characters it prints a single line of 240 pixels (the last 10 bytes are not used - although you do seem to have to send them). The attached test.s continually prints lines of random data out on the 822: The code in the owner's manual prints the screen out sideways; I attach the disassembly for that which I've commented but haven't done anything else with. Paul test.s test.xex commented.s 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 2, 2020 Author Share Posted April 2, 2020 @playsoft Yup, it turns out we don't need to send the 4C, simply sending the SIO command P is sufficient, at this point you indeed get a 240 pixel 1bpp stream in. The firmware on the printer does a good job buffering in and converting it to the vertical 7 bits that the printer normally wants for graphics mode, and makes it REALLY EASY to make the printer do graphics. I wish Atari had done more printers like this. Because of it, @jeffpiep was able to completely implement the graphics mode on the 822 emulation in #FujiNet, producing output like this: This has also set the stage for how we'll implement the Epson MX/FX ESC/P graphics. -Thom 2 Quote Link to comment Share on other sites More sharing options...
+playsoft Posted April 2, 2020 Share Posted April 2, 2020 Looks great, opens the door to using the 822 in games! (print maps etc...). Strange, my 822 seems to need the $4C in my test program; with Aux1 set to $00 there's no printer output at all, just farting noises; with it set to $4E I get normal text output, not bitmap. Paul 1 Quote Link to comment Share on other sites More sharing options...
ClausB Posted April 4, 2020 Share Posted April 4, 2020 You're welcome to use any of this code for Epson graphics: 2 1 Quote Link to comment Share on other sites More sharing options...
jeffpiep Posted April 5, 2020 Share Posted April 5, 2020 On 4/4/2020 at 9:38 AM, ClausB said: You're welcome to use any of this code for Epson graphics: This is neat. I will try to use it to test the Epson emulator. I was imagining a program that would send all the grahpics/screen states to the FujiNet, which would then emulate the screen and the generate a modern graphics file (e.g., PNG). Would it be difficult to port it to C++ and run it on the ESP32? Quote Link to comment Share on other sites More sharing options...
ClausB Posted April 6, 2020 Share Posted April 6, 2020 (edited) @jeffpiep Not sure I understand the proposed architecture. Like this? - PRANTIC 6502 code captures graphics and sends over SIO in some format. - ESP32 receives over SIO and converts graphics into EPSON codes. - EPSON emulator converts codes to PNG file. If that's what you have in mind, then half of what PRANTIC does now would run in the Atari and half in the ESP32? Edited April 6, 2020 by ClausB Quote Link to comment Share on other sites More sharing options...
jeffpiep Posted April 8, 2020 Share Posted April 8, 2020 (edited) On 4/6/2020 at 9:40 AM, ClausB said: @jeffpiep Not sure I understand the proposed architecture. Like this? - PRANTIC 6502 code captures graphics and sends over SIO in some format. - ESP32 receives over SIO and converts graphics into EPSON codes. - EPSON emulator converts codes to PNG file. If that's what you have in mind, then half of what PRANTIC does now would run in the Atari and half in the ESP32? @ClausB I was thinking of - PRANTIC 6502 code captures graphics and sends over SIO in some format. - ESP32 receives over SIO and converts graphics into a color PNG much like an emulator screen capture. I don't know if this is an appropriate use of the PRANTIC emulation of ANTIC and GTIA. -Jeff Edited April 8, 2020 by jeffpiep Quote Link to comment Share on other sites More sharing options...
jeffpiep Posted April 8, 2020 Share Posted April 8, 2020 On 4/1/2020 at 5:03 PM, playsoft said: The code in the owner's manual prints the screen out sideways; I attach the disassembly for that which I've commented but haven't done anything else with. Paul test.s 1.9 kB · 3 downloads test.xex 91 B · 3 downloads commented.s 2.85 kB · 4 downloads Thank-you for the information and disassembling and commenting the example code from the user's manual. I was just guessing at how this worked by watching SIO traffic. Good to have the confirmation based on the example program. Jeff Quote Link to comment Share on other sites More sharing options...
jeffpiep Posted April 8, 2020 Share Posted April 8, 2020 (edited) On 4/2/2020 at 6:27 AM, playsoft said: Strange, my 822 seems to need the $4C in my test program; with Aux1 set to $00 there's no printer output at all, just farting noises; with it set to $4E I get normal text output, not bitmap. @playsoft Paul, I'd like to get the emulator behavior right. Right now, I send all SIO 'W' data to text and 'P' data to graphics. Should I be using the Aux1 instead sending 'N' to text and 'L' to graphics? Or is it a combination of command and aux1? Thanks Jeff Edited April 8, 2020 by jeffpiep Quote Link to comment Share on other sites More sharing options...
ClausB Posted April 12, 2020 Share Posted April 12, 2020 On 4/8/2020 at 8:18 AM, jeffpiep said: @ClausB I was thinking of - PRANTIC 6502 code captures graphics and sends over SIO in some format. - ESP32 receives over SIO and converts graphics into a color PNG much like an emulator screen capture. I don't know if this is an appropriate use of the PRANTIC emulation of ANTIC and GTIA. -Jeff @jeffpiep PRANTIC could do that. PM sent. 1 Quote Link to comment Share on other sites More sharing options...
