GDMike
Another modem similar probs
My last modem went to the bin of parts.
I picked up this guy and I get an led flashing when I hit enter, and that's it...
Trouble in modem land
How do you have it connected to the TI?  IIRC, the TI RS-232 card is wired as a device.
Posted (edited)
How come I didn't get a dang message on this post. I got notification on my other posts.. hmm... sorry for the delay as I never received a notification..
It's late now, I'll reply tommorow..
Btw, notification switch is set for receive notification..I dunno but I bet it's got something to do with my modem problem!
Edited by GDMike
Posted (edited)
On 3/9/2020 at 11:12 PM, arcadeshopper said:
what are the switches set to?
Image result for usr 56k sportster dip switch
are they set:   up up down up down up up down
The last one,on the rt, was up so I adjusted. The modem now throws a tx led. And a Rd led flashes when it tries dialing then quickly goes off. Telco goes to next try
Edited by GDMike
Sigh ... good old modem times. I think we can't even connect these analog devices to the telephone network anymore, everything digital now.
Posted (edited)
I went to terminal, typed at and got an ok. Then I typed atdt and my phone# and received no dial tone msg.
I'm researching..the connector is in the correct jack on the modem and it's connected to the phone port on the wall..
Pulled the phone line out of the modem and I put an analog phone on that cable and I have a dial tone..
Any thoughts
Edited by GDMike
Well I did connect with the same hardware with my other modem but the modem was flaking out as it kept dropping power, going off and on.
Ok, I adjusted sw #7 and now I hear it dialing. But no connection
Do you hear a dial tone before it starts dialing?
I have an analog phone and I'm listening to it to see if the modem ever really tries to dial.. and even though I hear the modem dialing, the phone itself still has dial tone and I never hear the modem dialing in the phone.
I also can't get dialtone on my analog phone when I plug into the other port,the phone port, on the modem. Hmm
I think now what I've got after messing with everything, is that it's dialing but not waiting long enough for dialtone. Because I picked up the house phone and it's making the tones as if you dialed a wrong number.
So I guess it is working to a degree
First, the port you plug the line in matters.  One is for the wall outlet, the other is for the phone and the Sportsters physically disconnect the extension via a relay.
Secondly, try putting a W in your ATDT command.  This instructs the modem to wait for a dial tone before dialing.
atm1
atdtw(number-to-dial)
If it cannot hear a dial tone it will report so
NO DIAL TONE
It is not uncommon for the POTS line coupler in the modem to get blown out by an electrical surge.  This used to be a phone call we could expect at the ISP after a good storm: "When I try to connect it says 'NO DIAL TONE!'"  Yup, need to replace the modem and here is a good phone line surge protector to go with it.  (Seriously, I called it our "Lightning Special": A PCI or ISA controller-based (non-WinModem) USR 56k modem with a TrippLite PTEL7 installed for $159.)
yep the wall jack should be plugged into the connector closest to the side of the modem.. farthest away from the serial port.. if it doesn't detect dialtone it has probably taken a hit
Do you hear the modem make a loud "click" when it goes off-hook?  I have never had a relay fail on these modems, but I suppose it is not impossible given age.
BITD, many times when we had a t-storm and I neglected to unplug the modem, there'd be a "snap" sound from it that I would hear if I was nearby. That was the sound of another hundred-dollar bill vanishing from my wallet! I never could find what part failed inside so the modem became a brick. I just got in the habit of unplugging the phone jack and power when not using it.
-Ed
Posted (edited)
I can hear a crackle when it goes off hook, and not all the time. Mostly it is just quiet
Edited by GDMike
  • Haha 2
