RWDPLZ #1 Posted March 10, 2020 Hello! I'm working on a couple Atari 2600 six switch consoles, a heavy sixer and an early light sixer, both made in Sunnyvale. -The heavy sixer plays Donkey Kong and Dig Dug flawlessly. However, it will not play any of my other older cartridges (Adventure, Space Invaders, Pacman, ET, etc.). I tried cleaning the cartridge connector on the board and took apart a Space Invaders and cleaned it, and tried inserting it without the cartridge housing, no improvement. It either displays a black screen or a gray one with vertical lines and interference. Tried two different TV's, same results. Tried taking apart a Space Invaders, inserted the bare board fully to rule out the board not being fully inserted/seated, no change. -The light sixer: When I turn it on I can frequently see the start screen of some games for half a second, but then shows interference, too. Donkey Kong is playable, but the screen is gray with white characters and the sound is a screeching noise (see image) Tried Console5 refresh kits, swapping the 3 socketed chips between boards, replaced the 3 chip sockets on the heavy sixer, replaced the ribbon cables between the main and switch boards, deoxit-ed the switches and checked with multimeter, swapped switch boards between the units, replaced RF module on light sixer, tried a brand new and old power supplies. Both voltage regulators are putting out ~5.05 volts on the switch boards. Any ideas? Thanks! Quote Share this post Link to post Share on other sites
RWDPLZ #2 Posted March 14, 2020 Well I fixed the light sixer: Short version is, it turns out it's a PAL unit. I bought it from a US seller that had advertised it as simply broken. It now plays NTSC games, just with a completely wrong color palette. (ignore the 82/22 date code CPU, I was testing the one from a 4 switch). I also AV modded it. Ever seen Dig Dug like THIS? I found an interesting explanation of the color swaps here: http://spiceware.org/atari_ntsc_pal_secam.html For example, the sky above should be blue, but is displaying purple, as seen in the TIA color charts http://www.qotile.net/minidig/docs/tia_color.html It's made in Sunnyvale. The lack of any FCC compliance labeling probably should have been a clue? Also bought and fixed a 4 switch Vader, with what turned out to be a bad CPU. Re-capping and AV modding next. Then hopefully the heavy sixer. Quote Share this post Link to post Share on other sites
RWDPLZ #3 Posted March 14, 2020 Heavy sixer has been repaired! I started swapping chips 1 by 1 with the Vader, and it turned out to be the RIOT chip. It now plays everything I throw at it. Original chip was MOS branded, date code 1577 (15th week of 1977), so almost certainly the original. I've ordered replacement chips for the Vader and a Console5 kit to get it back to 100% Quote Share this post Link to post Share on other sites
Jason_Atari #4 Posted March 14, 2020 Every PAL 6 Switch 2600 I've seen has a P after the model number (see pic) You sure it's not just the colour pot needing adjustment? Quote Share this post Link to post Share on other sites
RWDPLZ #5 Posted March 14, 2020 Yes, I tried turning the pot to get at least a better palette, but ultimately left it there so it could potentially play PAL games with the correct colors if I get a TV that can somehow handle a 50Hz signal on 120V/60Hz. If you look at the TIA, the part number on the chip, C011903-11, is the PAL TIA, this one from the 30th week of 1978. You can see in this post the NTSC and PAL TIA's have a slightly different pinout, which was why swapping them between the NTSC and PAL consoles had no effect on fixing them. Quote Share this post Link to post Share on other sites
