moulinaie Posted March 30, 2020 Share Posted March 30, 2020 19 hours ago, Vorticon said: Well it seems that the random shot method has its limits. After 14.3 billion iterations, PI has converged to 3.141076. I guess we're not going to get that 4th decimal after all. Interesting... Hi ! The RND function used has a precision of 1/4096 = 0.00024. The best we can expect is a value in PI +/- 0.00024 3.1413 and 3.1418 Guillaume. 2 Quote Link to comment Share on other sites More sharing options...
moulinaie Posted March 30, 2020 Share Posted March 30, 2020 Hi, Supposing that every value of the RND generator appears as many times as the others, here is a calculation of the "Best PI' you can expect according to the number of bits of the RND value. Note: for MLC, the number of bits is 12. 50 CALL CLEAR 100 INPUT "# of bits in RND : ":B 105 S=0::R=2^B-1::R2=R*R 110 FOR I=0 TO R 120 S=S+INT(SQR(R2-I*I)) 130 NEXT I 140 PRINT "Best PI with";B;"bits" 150 PRINT 4*S/(2^(2*B)) 160 PRINT 170 GOTO 100 Take care of the calculation time. Use the CPU overdrive mode... Guillaume. 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 30, 2020 Author Share Posted March 30, 2020 5 hours ago, moulinaie said: Hi ! The RND function used has a precision of 1/4096 = 0.00024. The best we can expect is a value in PI +/- 0.00024 3.1413 and 3.1418 Guillaume. Good to know! The problem is that even after 14 billion+ iterations, that 4th decimal was still stuck at 0, outside of the theoretical range... I would assume then that the XB RND function has the full TI precision and should give a better result, although it would take months to get a decent number of iterations... Quote Link to comment Share on other sites More sharing options...
moulinaie Posted March 30, 2020 Share Posted March 30, 2020 1 hour ago, Vorticon said: Good to know! The problem is that even after 14 billion+ iterations, that 4th decimal was still stuck at 0, outside of the theoretical range... I would assume then that the XB RND function has the full TI precision and should give a better result, although it would take months to get a decent number of iterations... Hi, Sure ! You're right. But MLC can do FLOAT operations. The lack is that I can see no call to the XB RND function from assembler. Else, I could try to program a faster version with MLC. Guillaume. Quote Link to comment Share on other sites More sharing options...
RXB Posted March 30, 2020 Share Posted March 30, 2020 17 minutes ago, moulinaie said: Hi, Sure ! You're right. But MLC can do FLOAT operations. The lack is that I can see no call to the XB RND function from assembler. Else, I could try to program a faster version with MLC. Guillaume. Well XB RND in GROM is here and it shows the Assembly CALLS used: <0218> A295 42,03,23 X2SEED BYTE >42,>03,>23,>15,>00 * = 33521, X2 INITIAL VAL A298 15,00 <0219> A29A 43,02,3E X1SEED BYTE >43,>02,>3E,>2A,>17 * = 2624223, X1 INITIAL VAL A29D 2A,17 <0220> *********************************************************** <0221> * PSEUDO-RANDOM NUMBER GENERATOR <0222> * X(N+1) = (A*X(N)+C) MOD M; RND = X/M 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0016 EQUATES EXEC-359 <0223> * WHERE: X = X2 * 1E7 + X1 <0224> * A = A2 * 1E7 + A1 <0225> * C = C2 * 1E7 + C1 <0226> * M = 1E14 <0227> * ASSUMPTIONS: <0228> * (1) All numbers are integers; fractional parts are <0229> * truncated <0230> * (2) If the variables listed below start in the ranges <0231> * specified. They will also end in the ranges specified <0232> * <0233> * CONSTANTS: 0 <= A2 < 5E6 ; 0 <= C2 < 1E7 <0234> * 0 <= A1 < 5E6 ; 0 <= C1 < 1E7 <0235> * VARIABLES: 0 <= X2 < 1E7 ; 0 <= T1 <= 1E14 ; 0 <= T2 < 1E <0236> * 0 <= X1 < 1E7 ; 0 <= T3 <= 1E14 ; 0 <= T4 < 1E <0237> * <0238> * STACK USAGE: <0239> * CONSTANT REFS CONTANT REFS CONTANT REF <0240> * +---------+ IN/OUT IN/OUT IN/OUT <0241> * | STACK+4 | X2*A1(F)(H) -- ---- -- ---- <0242> * +---------+ <0243> * | STACK+3 | T2 (C)(J) -- ---- -- ---- <0244> * +---------+ <0245> * | STACK+2 | T1 (B)(D) new X1 (E)(N) -- ---- <0246> * +---------+ <0247> * | STACK+1 |old X1(A)(G) T3 (K)(L) new X2 (M)(P) <0248> * +---------+ <0249> *********************************************************** <0250> * COMPUTE NEW VALUE FOR X1, SAVE IT IN V@RNDX1 <0251> * STACK <0252> * SREFS FAC CONTENTS <0253> A29F 35,00,05 NRND MOVE 5,V@RNDX1,@FAC FAC = X1 A2A2 4A,A3,A5 <0254> A2A5 86,4F CLR @FAC5 FAC = CLR <0255> A2A7 87,50 DCLR @FAC6 FAC = CLR <0256> A2A9 0F,77 XML VPUSH (A) FAC = X1 <0257> A2AB 31,00,08 MOVE 8,G@RNDA1,@ARG ARG = A1 A2AE 5C,A3,57 <0258> A2B1 0F,08 XML FMUL FAC = X1*A1 <0259> A2B3 31,00,08 MOVE 8,G@RNDC1,@ARG ARG = C1 A2B6 5C,A3,67 <0260> A2B9 0F,06 XML FADD T1=FAC = X1*A1+C1 <0261> A2BB 0F,77 XML VPUSH (B) FAC = T1 <0262> A2BD 31,00,08 MOVE 8,G@RNDEM,@ARG ARG = 1/1E7 A2C0 5C,A3,77 <0263> A2C3 0F,08 XML FMUL FAC = T1/1E7 <0264> A2C5 06,00,22 CALL GRINT T2=FAC = INT(T1/1E7) <0265> A2C8 0F,77 XML VPUSH (C) FAC = T2 <0266> A2CA 31,00,08 MOVE 8,G@RNDEP,@ARG ARG = 1E7 A2CD 5C,A3,6F <0267> A2D0 0F,08 XML FMUL FAC = T2*1E7 <0268> A2D2 A7,6E,00 DSUB 8,@VSPTR A2D5 08 <0269> A2D6 0F,0C XML SSUB (D) X1=FAC = T1-T2*1E7 <0270> A2D8 35,00,05 MOVE 5,@FAC,V@RNDX1 FAC = X1 (new) A2DB A3,A5,4A <0271> A2DE 0F,77 XML VPUSH (E) FAC = X1 <0272> * COMPUTE NEW VALUE FOR X2, SAVE IT IN V@RNDX2 <0273> A2E0 35,00,05 MOVE 5,V@RNDX2,@FAC FAC = X2 A2E3 4A,A3,A0 <0274> A2E6 86,4F CLR @FAC5 FAC = CLR <0275> A2E8 87,50 DCLR @FAC6 FAC = CLR <0276> A2EA 31,00,08 MOVE 8,G@RNDA1,@ARG ARG = A1 A2ED 5C,A3,57 <0277> A2F0 0F,08 XML FMUL FAC = X2*A1 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0017 EQUATES EXEC-359 <0278> A2F2 A3,6E,00 DADD 8,@VSPTR A2F5 08 <0279> A2F6 0F,77 XML VPUSH (F) FAC = X2*A1 <0280> A2F8 A7,6E,00 DSUB 24,@VSPTR A2FB 18 <0281> A2FC 0F,78 XML VPOP (G) FAC = X1 <0282> A2FE A3,6E,00 DADD 32,@VSPTR A301 20 <0283> A302 31,00,08 MOVE 8,G@RNDA2,@ARG ARG = A2 A305 5C,A3,4F <0284> A308 0F,08 XML FMUL FAC = X1*A2 <0285> A30A 0F,0B XML SADD (H) FAC = X2*A1+X1*A2 <0286> A30C 31,00,08 MOVE 8,G@RNDC2,@ARG ARG = C2 A30F 5C,A3,5F <0287> A312 0F,06 XML FADD FAC = X2*A1+X1*A2 <0288> A314 0F,0B XML SADD (J) T3=FAC = X2*A1+X1*A2 <0289> A316 A7,6E,00 DSUB 16,@VSPTR A319 10 <0290> A31A 0F,77 XML VPUSH (K) FAC = T3 <0291> A31C 31,00,08 MOVE 8,G@RNDEM,@ARG ARG = 1/1E7 A31F 5C,A3,77 <0292> A322 0F,08 XML FMUL FAC = T3/1E7 <0293> A324 06,00,22 CALL GRINT T4=FAC = INT(T3/1E7) <0294> A327 31,00,08 MOVE 8,G@RNDEP,@ARG ARG = 1E7 A32A 5C,A3,6F <0295> A32D 0F,08 XML FMUL FAC = T4*1E7 <0296> A32F 0F,0C XML SSUB (L) X2=FAC = T3-T4*1E7 <0297> A331 35,00,05 MOVE 5,@FAC,V@RNDX2 FAC = X2 (new) A334 A3,A0,4A <0298> * COMPUTE NEW VALUE FOR RND, LEAVE IT IN FAC <0299> A337 31,00,08 MOVE 8,G@RNDEM,@ARG ARG = 1/1E7 A33A 5C,A3,77 <0300> A33D 0F,08 XML FMUL FAC = X2/1E7 <0301> A33F 0F,77 XML VPUSH (M) FAC = X2/1E7 <0302> A341 A3,6E,00 DADD 8,@VSPTR A344 08 <0303> A345 0F,78 XML VPOP (N) FAC = X1 <0304> A347 0F,08 XML FMUL FAC = X1/1E7 <0305> A349 0F,08 XML FMUL FAC = X1/1E14 <0306> A34B 0F,0B XML SADD (P)RND=FAC = (X2/1E7)+(X1/1E14) <0307> A34D 0F,75 XML CONT [0008] *********************************************************** [0009] COPY 'DSK5.MYXB5-D' <0001> * CONSTANTS FOR THE RANDOM NUMBER ROUTINE <0002> A34F 43,01,2B RNDA2 BYTE >43,>01,>2B,>59,>52,>00,>00,>00 * = 1438982 A352 59,52,00 A355 00,00 <0003> A357 42,2A,08 RNDA1 BYTE >42,>2A,>08,>15,>00,>00,>00,>00 * = 0420821 A35A 15,00,00 A35D 00,00 <0004> A35F 43,02,0B RNDC2 BYTE >43,>02,>0B,>20,>30,>00,>00,>00 * = 2113248 A362 20,30,00 A365 00,00 <0005> A367 43,06,36 RNDC1 BYTE >43,>06,>36,>05,>13,>00,>00,>00 * = 6540519 A36A 05,13,00 A36D 00,00 <0006> A36F 43,0A,00 RNDEP BYTE >43,>0A,>00,>00,>00,>00,>00,>00 * = 1E7 A372 00,00,00 A375 00,00 <0007> A377 3C,0A,00 RNDEM BYTE >3C,>0A,>00,>00,>00,>00,>00,>00 * = 1/1E7 A37A 00,00,00 A37D 00,00 <0008> *********************************************************** <0009> * RANDOMIZE STATEMENT 99/4 GPL-ASSEMBLER (Pass 3) correct PAGE 0018 EQUATES EXEC-359 <0010> *********************************************************** <0011> A37F 06,6A,78 NRNDMZ CALL CHKEND Seed provider? <0012> A382 63,C0 BS RNDM1 No <0013> * RANDOMIZE given a see value <0014> * (99,000,000,000,001 possible starting positions) <0015> * (Place-value is ignored in the input number) <0016> A384 0F,74 XML PARSE Parse the seed <0017> A386 83 BYTE TREMZ * Up to end of statement <0018> A387 06,A3,ED CALL CKSTNM <0019> A38A 8F,4A DCZ @FAC Check FAC for zero <0020> A38C 63,B6 BS GA3B6 <0021> A38E BE,4A,46 ST >46,@FAC 0 < FAC < 1E14 <0022> A391 0F,77 XML VPUSH Let FAC = X2*1E7+X1 <0023> A393 31,00,08 MOVE 8,G@RNDEM,@ARG ARG = 1/1E7 A396 5C,A3,77 <0024> A399 0F,08 XML FMUL FAC = X2+X1/1E7 <0025> A39B 06,00,22 CALL GRINT FAC = X2 <0026> A39E 35,00,05 MOVE 5,@FAC,V@RNDX2 FAC = X2 A3A1 A3,A0,4A <0027> A3A4 31,00,08 MOVE 8,G@RNDEP,@ARG ARG = 1E7 A3A7 5C,A3,6F <0028> A3AA 0F,08 XML FMUL FAC = X2*1E7 <0029> A3AC 0F,0C XML SSUB FAC = X1 <0030> A3AE 35,00,05 MOVE 5,@FAC,V@RNDX1 FAC = X1 A3B1 A3,A5,4A <0031> A3B4 0F,75 XML CONT FAC = X1 <0032> A3B6 BD,A3,A0 GA3B6 DST @FAC,V@RNDX2 FAC = 0 A3B9 4A <0033> A3BA BD,A3,A5 DST @FAC,V@RNDX1 FAC = 0 A3BD 4A <0034> A3BE 0F,75 XML CONT <0035> * RANDOMIZE given number seed value (use GPL RAND function) <0036> * (16K possible starting positions) <0037> A3C0 BF,4A,42 RNDM1 DST >4201,@FAC FAC = >4201 A3C3 01 <0038> A3C4 86,4E CLR @FAC4 FAC4= >00 <0039> A3C6 06,A3,D2 CALL RNDMZ <0040> A3C9 03,A5 DATA RNDX1 <0041> A3CB 06,A3,D2 CALL RNDMZ Set up seed <0042> A3CE 03,A0 DATA RNDX2 <0043> A3D0 0F,75 XML CONT Continue on <0044> A3D2 88,52 RNDMZ FETCH @FAC8 Fetch address of seed (high b <0045> A3D4 88,53 FETCH @FAC9 Fetch address of seed (low by <0046> A3D6 02,63 RAND 99 GPL Randomize <0047> A3D8 BC,4C,78 ST @RANDOM,@FAC2 >00<=FAC+2<=FF <0048> A3DB E6,4C,02 SRL 2,@FAC2 >00<=FAC+2<=3F <0049> A3DE 02,63 RAND 99 GPL Randomize <0050> A3E0 BC,4D,78 ST @RANDOM,@FAC3 >00<=FAC+3<=FF <0051> A3E3 E6,4D,02 SRL 2,@FAC3 >00<=FAC+3<=3F <0052> A3E6 35,00,05 MOVE 5,@FAC,V*FAC8 Put in seed A3E9 B0,52,4A <0053> A3EC 00 RTN <0054> A3ED D6,4C,65 CKSTNM CEQ >65,@FAC2 <0055> A3F0 6D,BE BS ERRSNM <0056> A3F2 00 RTN <0057> A3F3 40,01,00 FLT1 BYTE >40,>01,>00,>00,>00,>00,>00,>00 A3F6 00,00,00 A3F9 00,00 <0058> *********************************************************** 17 minutes ago, moulinaie said: Quote Link to comment Share on other sites More sharing options...
moulinaie Posted March 30, 2020 Share Posted March 30, 2020 10 minutes ago, RXB said: Well XB RND in GROM is here and it shows the Assembly CALLS used: <0220> *********************************************************** <0221> * PSEUDO-RANDOM NUMBER GENERATOR <0222> * X(N+1) = (A*X(N)+C) MOD M; RND = X/M Ok thanks! I got the method... I can simulate it in assembly. But, isn't there a way to call this routine from assembler without rewriting it? Guillaume. 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted March 30, 2020 Share Posted March 30, 2020 2 hours ago, moulinaie said: Ok thanks! I got the method... I can simulate it in assembly. But, isn't there a way to call this routine from assembler without rewriting it? Guillaume. Most of the work of making a Random Number is done is Assembly in XB ROMs. XML VPUSH XML VPOP XML FMUL XML FADD XML SSUB Quote Link to comment Share on other sites More sharing options...
moulinaie Posted March 31, 2020 Share Posted March 31, 2020 Hi all, I have been able to recreate with MLC (using its inline assembler) the Extended Basic RND routine. You can see on the left the value from MLC and on the right the XB RND call. They start with the same seed (so, you must reboot your TI before), and the list generated is the same. Then... If you try form the command line FOR I=1 TO 1000::A=RND::NEXT I The XB function takes 72 seconds. And if you try: FOR I=1 TO 1000::CALL LINK("RANDOM",A)::NEXT I MLC function takes 46 seconds. And for the same result with the same precision ! Download the ZIP file, put everything in DISK1 folder and load DSK1.XBRND to test it. DISK1.zip Next work... Calculate PI with it! Guillaume. 3 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 31, 2020 Share Posted March 31, 2020 1 hour ago, moulinaie said: They start with the same seed (so, you must reboot your TI before), and the list generated is the same. Or...you can start each program with the same seed by using the same number (seed) with RANDOMIZE as the first statement. 10 RANDOMIZE 111 ...lee 1 Quote Link to comment Share on other sites More sharing options...
moulinaie Posted March 31, 2020 Share Posted March 31, 2020 3 minutes ago, Lee Stewart said: Or...you can start each program with the same seed by using the same number (seed) with RANDOMIZE as the first statement. 10 RANDOMIZE 111 ...lee Yes you're right! I meant that with the same seed, the two lists are equal. That was to prove that MLC simulates exactly what XB does. And... as MLC is not concerned by RANDOMIZE, but uses the boot seed of the TI, you must reboot the TI to be sure that the seeds ar the same. I don't know if I'm clear... ? Guillaume. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 31, 2020 Share Posted March 31, 2020 1 hour ago, moulinaie said: I don't know if I'm clear... ? You were clear. I just wanted to point out another way to insure the same sequence of pseudo-random numbers. ? ...lee 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted March 31, 2020 Share Posted March 31, 2020 2 hours ago, moulinaie said: Hi all, I have been able to recreate with MLC (using its inline assembler) the Extended Basic RND routine. You can see on the left the value from MLC and on the right the XB RND call. They start with the same seed (so, you must reboot your TI before), and the list generated is the same. Then... If you try form the command line FOR I=1 TO 1000::A=RND::NEXT I The XB function takes 72 seconds. And if you try: FOR I=1 TO 1000::CALL LINK("RANDOM",A)::NEXT I MLC function takes 46 seconds. And for the same result with the same precision ! Download the ZIP file, put everything in DISK1 folder and load DSK1.XBRND to test it. DISK1.zip 9.08 kB · 2 downloads Next work... Calculate PI with it! Guillaume. XB RND sucks for being so slow that it is insane just to have that precision! I mean why do you need 9 decimal places of Random Numbers for plotting on a 24x32 screen or even a 49152 pixel screen as 1 decimal place is more then enough. What TI should have done was have a high precision version RAND and a non precision one RND. This is why so many games on the TI99/4A sucked as being so slow. By the way: FOR I=1 TO 1000::A=RND::NEXT I I did this in RXB and it took 22 seconds in GPL! 1 Quote Link to comment Share on other sites More sharing options...
moulinaie Posted March 31, 2020 Share Posted March 31, 2020 19 minutes ago, RXB said: By the way: FOR I=1 TO 1000::A=RND::NEXT I I did this in RXB and it took 22 seconds in GPL! Damned!! That's a good chrono ! So, you'll be able to test one of my programs with RXB! (the first in the list) I have put three programs in this ZIP, all allow to save the current state. The second one even saves its current random seed. DSK1.PIXBALONE That uses only Extended Basic, full precision RND, 34 seconds for 200 points. Speed = 5,88 point / sec DSK1.PIXBLIKE Thats uses MLC, but simulates the full precision RND, 34 seconds for 1000 points. Speed = 29,41 point / sec DSK1.PIRANDOM Thats uses MLC with its fast RND routine from 0 to 4095, 15 seconds for 25000 points. Speed = 1666,67 point / sec DISK1.zip Guillaume. 2 Quote Link to comment Share on other sites More sharing options...
RXB Posted March 31, 2020 Share Posted March 31, 2020 2 hours ago, moulinaie said: Damned!! That's a good chrono ! So, you'll be able to test one of my programs with RXB! (the first in the list) I have put three programs in this ZIP, all allow to save the current state. The second one even saves its current random seed. DSK1.PIXBALONE That uses only Extended Basic, full precision RND, 34 seconds for 200 points. Speed = 5,88 point / sec DSK1.PIXBLIKE Thats uses MLC, but simulates the full precision RND, 34 seconds for 1000 points. Speed = 29,41 point / sec DSK1.PIRANDOM Thats uses MLC with its fast RND routine from 0 to 4095, 15 seconds for 25000 points. Speed = 1666,67 point / sec DISK1.zip 11.71 kB · 1 download Guillaume. RXB uses the same RND as TI Basic now, so what ever speed TI Basic does it will be with a second of that. Just using my wrist watch on both RXB and TI Basic for FOR I=1 TO 1000::A=RND::NEXT I both resulted in about 20 or up to 22 seconds, I would say both average about 21 seconds. So if you test you program on TI Basic should be almost the same for RXB, unless you use a ton of slower TI Basic routines. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted May 4, 2022 Author Share Posted May 4, 2022 With all the discussion about benchmarking going on, I remembered that thread about the PI Calculator program I wrote in XB back in 2007. I wonder if I could engage the Forth gurus to take a shot at it for timing comparison. Spoiler 10 REM PI CALCULATOR 20 REM BY WALID MAALOULI 30 REM AUGUST 2007 40 REM 100 CALL CLEAR 110 OPTION BASE 1 120 DIM SUM(652),SUM1(652),TERM(652),TEMP(652) 130 DISPLAY AT(1,8):"Pi Calculator" :: DISPLAY AT(3,6):"By Walid Maalouli" :: DISPLAY AT(5,9):"August 2007" 140 DISPLAY AT(10,2)BEEP :"# of decimals (mult. of 8)" :: DISPLAY AT(11,2):"(Maximum of 5200 decimals)" :: ACCEPT AT(13,12)VALIDATE(DIGIT):D 150 IF D>5200 THEN 140 160 ITR=INT(D/1.4) :: D=INT(D/8)+2 170 SUM(1)=3 :: SUM(2)=20000000 :: TERM(1)=0 :: TERM(2)=20000000 :: S=0 :: DENOM1=3 :: TBASE=25 :: MULT=16 180 FOR N=1 TO ITR+1 190 IF FLAG=0 THEN DISPLAY AT(20,5):"Term 1 iteration #";N;" " ELSE DISPLAY AT(20,5):"Term 2 iteration #";N;" " 200 IF N=1 THEN 220 210 FOR I=1 TO D :: TERM(I)=TEMP(I) :: NEXT I 220 DENOM=TBASE :: REMAINDER=0 230 GOSUB 1050 240 FOR I=1 TO D :: TEMP(I)=TERM(I) :: NEXT I 250 DENOM=DENOM1 :: REMAINDER=0 260 GOSUB 1050 270 FOR I=1 TO D 280 IF S=0 THEN 300 290 SUM(I)=SUM(I)+MULT*TERM(I) :: GOTO 310 300 SUM(I)=SUM(I)-MULT*TERM(I) 310 NEXT I 320 IF S=0 THEN S=1 ELSE S=0 330 FOR I=D TO 2 STEP-1 340 IF SUM(I)>=100000000 THEN 350 ELSE IF SUM(I)<0 THEN 390 ELSE 420 350 QUOTIENT=INT(SUM(I)/100000000) 360 SUM(I)=SUM(I)-QUOTIENT*100000000 370 SUM(I-1)=SUM(I-1)+QUOTIENT 380 GOTO 420 390 QUOTIENT=INT(SUM(I)/100000000)+1 400 SUM(I)=SUM(I)-(QUOTIENT-1)*100000000 410 SUM(I-1)=SUM(I-1)+QUOTIENT-1 420 NEXT I 430 IF FLAG=2 THEN 680 440 DENOM1=DENOM1+2 450 NEXT N 460 IF FLAG=1 THEN 620 470 TBASE=57121 :: DENOM1=3 :: MULT=4 480 FOR I=1 TO D 490 SUM1(I)=SUM(I) 500 SUM(I)=0 :: TERM(I)=0 510 NEXT I 520 TERM(1)=4 530 DENOM=239 :: REMAINDER=0 540 GOSUB 1050 550 FOR I=1 TO D 560 SUM(I)=TERM(I) :: TERM(I)=0 570 NEXT I 580 DENOM=239 :: TERM(1)=1 :: REMAINDER=0 590 GOSUB 1050 600 FLAG=1 :: S=0 610 GOTO 180 620 PRINT :: PRINT "Finalizing calculations..." :: PRINT 630 FOR I=1 TO D 640 SUM1(I)=SUM1(I)-SUM(I) :: SUM(I)=SUM1(I) 650 NEXT I 660 FLAG=2 670 GOTO 330 680 CALL CLEAR :: DISPLAY AT(2,3)BEEP :"Calculations complete!" 690 DISPLAY AT(5,3):"Send results to:" :: DISPLAY AT(8,5):"1- Screen" :: DISPLAY AT(10,5):"2- Printer (PIO)" :: DISPLAY AT(12,5):"3- File" 700 CALL KEY(0,K,ST) :: IF ST=0 THEN 700 710 IF K<49 OR K>51 THEN 700 720 ON K-48 GOTO 730,860,950 730 CALL CLEAR :: PRINT "Pi=3." 740 FOR I=2 TO D-1 750 SUM$=STR$(SUM(I)) 760 IF LEN(SUM$)=8 THEN 780 770 SUM$="0"&SUM$ :: GOTO 760 780 PRINT SUM$;" "; 790 L=L+1 :: IF L=64 THEN 800 ELSE 830 800 PRINT :: PRINT :: DISPLAY AT(24,1)BEEP :"Press any key to continue" :: L=0 810 CALL KEY(0,K,ST) :: IF ST=0 THEN 810 820 CALL CLEAR 830 NEXT I 840 PRINT :: PRINT :: DISPLAY AT(24,1)BEEP :"End. Press any key to exit" 850 CALL KEY(0,K,ST) :: IF ST=0 THEN 850 ELSE STOP 860 OPEN #1:"PIO" 870 PRINT #1:"Pi=3." 880 FOR I=2 TO D-1 890 SUM$=STR$(SUM(I)) 900 IF LEN(SUM$)=8 THEN 920 910 SUM$="0"&SUM$ :: GOTO 900 920 PRINT #1:SUM$;" "; 930 NEXT I 940 CLOSE #1 :: END 950 DISPLAY AT(22,1)BEEP :"Enter path.filename:" :: ACCEPT AT(24,1):FL$ 960 OPEN #1:FL$,OUTPUT,VARIABLE 80 970 PRINT #1:"Pi=3." 980 FOR I=2 TO D-1 990 SUM$=STR$(SUM(I)) 1000 IF LEN(SUM$)=8 THEN 1020 1010 SUM$="0"&SUM$ :: GOTO 1000 1020 PRINT #1:SUM$;" "; 1030 NEXT I 1040 CLOSE #1 :: END 1050 REM DIVIDE SUBROUTINE 1060 FOR I=1 TO D 1070 DIVIDEND=REMAINDER*100000000+TERM(I) 1080 TERM(I)=INT(DIVIDEND/DENOM) 1090 REMAINDER=DIVIDEND-TERM(I)*DENOM 1100 NEXT I 1110 RETURN Fred Kaal did some speed comparisons for 100 decimals in August 2007 which he posted on the old Yahoo listserve: Geneve: ExBasic = 7min 32sec, C99 = 30 seconds TI 99/4A: ExBasic = 13min 51sec, C99 = 1min 16sec Picalc.dsk 1 Quote Link to comment Share on other sites More sharing options...
Willsy Posted May 4, 2022 Share Posted May 4, 2022 (edited) Some sort of fixed-point Forth implementation would be great. Build a fixed-point library that can do simple FP arithmetic, and then code an appropriate PI calculation algorithm using the FP library. I'm not going to have the time to look at that though, unfortunately. Too much RL stuff in the way! Edited May 4, 2022 by Willsy typos 1 Quote Link to comment Share on other sites More sharing options...
+dhe Posted May 4, 2022 Share Posted May 4, 2022 6 hours ago, Vorticon said: Fred Kaal did some speed comparisons for 100 decimals in August 2007 which he posted on the old Yahoo listserve: Geneve: ExBasic = 7min 32sec, C99 = 30 seconds TI 99/4A: ExBasic = 13min 51sec, C99 = 1min 16sec Abasic 408 - MAME - GenMod Geneve (2:17) The tool chain for doing this was super easy! I cut the code from Atariage Saved the code in notepad to a file Used TI image tool to import an extended basic file to a hard drive image. Ran the program: The run took 2:17 3 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted May 5, 2022 Author Share Posted May 5, 2022 22 hours ago, Willsy said: Some sort of fixed-point Forth implementation would be great. Build a fixed-point library that can do simple FP arithmetic, and then code an appropriate PI calculation algorithm using the FP library. I'm not going to have the time to look at that though, unfortunately. Too much RL stuff in the way! I might take a crack at it. I'd like to use Lee's FbForth though as I have not had a chance to play with it yet. Just need some time to re-familiarize myself with Forth in general as it has been a while. Amazing how memory fails with disuse! 4 Quote Link to comment Share on other sites More sharing options...
Willsy Posted May 5, 2022 Share Posted May 5, 2022 2 minutes ago, Vorticon said: I might take a crack at it. I'd like to use Lee's FbForth though as I have not had a chance to play with it yet. Just need some time to re-familiarize myself with Forth in general as it has been a while. Amazing how memory fails with disuse! That works for me. If you write a fixed-point library for fbForth I'll port it over to TF. I doubt it will need much alteration. 4 Quote Link to comment Share on other sites More sharing options...
Willsy Posted May 5, 2022 Share Posted May 5, 2022 As it happens, when you posted, I had this page open so I saw it immediately, and I also had Forth Dimensions magazine, Volume IV, issue I open, which has a ruck of fixed point articles! Whet your appetite (and reacquaint yourself with Forth here!). 2 2 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted May 5, 2022 Author Share Posted May 5, 2022 4 minutes ago, Willsy said: As it happens, when you posted, I had this page open so I saw it immediately, and I also had Forth Dimensions magazine, Volume IV, issue I open, which has a ruck of fixed point articles! Whet your appetite (and reacquaint yourself with Forth here!). Ah very cool bedtime reading! ? This actually looks very interesting. Thanks! 3 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted May 5, 2022 Share Posted May 5, 2022 About Pi calculations 3 Quote Link to comment Share on other sites More sharing options...
RXB Posted May 5, 2022 Share Posted May 5, 2022 This was on my facebook page the day it came out! Great video thanks again. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted May 5, 2022 Share Posted May 5, 2022 On 5/4/2022 at 8:56 AM, Vorticon said: With all the discussion about benchmarking going on, I remembered that thread about the PI Calculator program I wrote in XB back in 2007. I wonder if I could engage the Forth gurus to take a shot at it for timing comparison. Reveal hidden contents 10 REM PI CALCULATOR 20 REM BY WALID MAALOULI 30 REM AUGUST 2007 40 REM 100 CALL CLEAR 110 OPTION BASE 1 120 DIM SUM(652),SUM1(652),TERM(652),TEMP(652) 130 DISPLAY AT(1,8):"Pi Calculator" :: DISPLAY AT(3,6):"By Walid Maalouli" :: DISPLAY AT(5,9):"August 2007" 140 DISPLAY AT(10,2)BEEP :"# of decimals (mult. of 8)" :: DISPLAY AT(11,2):"(Maximum of 5200 decimals)" :: ACCEPT AT(13,12)VALIDATE(DIGIT):D 150 IF D>5200 THEN 140 160 ITR=INT(D/1.4) :: D=INT(D/8)+2 170 SUM(1)=3 :: SUM(2)=20000000 :: TERM(1)=0 :: TERM(2)=20000000 :: S=0 :: DENOM1=3 :: TBASE=25 :: MULT=16 180 FOR N=1 TO ITR+1 190 IF FLAG=0 THEN DISPLAY AT(20,5):"Term 1 iteration #";N;" " ELSE DISPLAY AT(20,5):"Term 2 iteration #";N;" " 200 IF N=1 THEN 220 210 FOR I=1 TO D :: TERM(I)=TEMP(I) :: NEXT I 220 DENOM=TBASE :: REMAINDER=0 230 GOSUB 1050 240 FOR I=1 TO D :: TEMP(I)=TERM(I) :: NEXT I 250 DENOM=DENOM1 :: REMAINDER=0 260 GOSUB 1050 270 FOR I=1 TO D 280 IF S=0 THEN 300 290 SUM(I)=SUM(I)+MULT*TERM(I) :: GOTO 310 300 SUM(I)=SUM(I)-MULT*TERM(I) 310 NEXT I 320 IF S=0 THEN S=1 ELSE S=0 330 FOR I=D TO 2 STEP-1 340 IF SUM(I)>=100000000 THEN 350 ELSE IF SUM(I)<0 THEN 390 ELSE 420 350 QUOTIENT=INT(SUM(I)/100000000) 360 SUM(I)=SUM(I)-QUOTIENT*100000000 370 SUM(I-1)=SUM(I-1)+QUOTIENT 380 GOTO 420 390 QUOTIENT=INT(SUM(I)/100000000)+1 400 SUM(I)=SUM(I)-(QUOTIENT-1)*100000000 410 SUM(I-1)=SUM(I-1)+QUOTIENT-1 420 NEXT I 430 IF FLAG=2 THEN 680 440 DENOM1=DENOM1+2 450 NEXT N 460 IF FLAG=1 THEN 620 470 TBASE=57121 :: DENOM1=3 :: MULT=4 480 FOR I=1 TO D 490 SUM1(I)=SUM(I) 500 SUM(I)=0 :: TERM(I)=0 510 NEXT I 520 TERM(1)=4 530 DENOM=239 :: REMAINDER=0 540 GOSUB 1050 550 FOR I=1 TO D 560 SUM(I)=TERM(I) :: TERM(I)=0 570 NEXT I 580 DENOM=239 :: TERM(1)=1 :: REMAINDER=0 590 GOSUB 1050 600 FLAG=1 :: S=0 610 GOTO 180 620 PRINT :: PRINT "Finalizing calculations..." :: PRINT 630 FOR I=1 TO D 640 SUM1(I)=SUM1(I)-SUM(I) :: SUM(I)=SUM1(I) 650 NEXT I 660 FLAG=2 670 GOTO 330 680 CALL CLEAR :: DISPLAY AT(2,3)BEEP :"Calculations complete!" 690 DISPLAY AT(5,3):"Send results to:" :: DISPLAY AT(8,5):"1- Screen" :: DISPLAY AT(10,5):"2- Printer (PIO)" :: DISPLAY AT(12,5):"3- File" 700 CALL KEY(0,K,ST) :: IF ST=0 THEN 700 710 IF K<49 OR K>51 THEN 700 720 ON K-48 GOTO 730,860,950 730 CALL CLEAR :: PRINT "Pi=3." 740 FOR I=2 TO D-1 750 SUM$=STR$(SUM(I)) 760 IF LEN(SUM$)=8 THEN 780 770 SUM$="0"&SUM$ :: GOTO 760 780 PRINT SUM$;" "; 790 L=L+1 :: IF L=64 THEN 800 ELSE 830 800 PRINT :: PRINT :: DISPLAY AT(24,1)BEEP :"Press any key to continue" :: L=0 810 CALL KEY(0,K,ST) :: IF ST=0 THEN 810 820 CALL CLEAR 830 NEXT I 840 PRINT :: PRINT :: DISPLAY AT(24,1)BEEP :"End. Press any key to exit" 850 CALL KEY(0,K,ST) :: IF ST=0 THEN 850 ELSE STOP 860 OPEN #1:"PIO" 870 PRINT #1:"Pi=3." 880 FOR I=2 TO D-1 890 SUM$=STR$(SUM(I)) 900 IF LEN(SUM$)=8 THEN 920 910 SUM$="0"&SUM$ :: GOTO 900 920 PRINT #1:SUM$;" "; 930 NEXT I 940 CLOSE #1 :: END 950 DISPLAY AT(22,1)BEEP :"Enter path.filename:" :: ACCEPT AT(24,1):FL$ 960 OPEN #1:FL$,OUTPUT,VARIABLE 80 970 PRINT #1:"Pi=3." 980 FOR I=2 TO D-1 990 SUM$=STR$(SUM(I)) 1000 IF LEN(SUM$)=8 THEN 1020 1010 SUM$="0"&SUM$ :: GOTO 1000 1020 PRINT #1:SUM$;" "; 1030 NEXT I 1040 CLOSE #1 :: END 1050 REM DIVIDE SUBROUTINE 1060 FOR I=1 TO D 1070 DIVIDEND=REMAINDER*100000000+TERM(I) 1080 TERM(I)=INT(DIVIDEND/DENOM) 1090 REMAINDER=DIVIDEND-TERM(I)*DENOM 1100 NEXT I 1110 RETURN Fred Kaal did some speed comparisons for 100 decimals in August 2007 which he posted on the old Yahoo listserve: Geneve: ExBasic = 7min 32sec, C99 = 30 seconds TI 99/4A: ExBasic = 13min 51sec, C99 = 1min 16sec Picalc.dsk 180 kB · 2 downloads I can't take credit for the code. It was written by Ed of DxForth fame in Australia. Ed makes DxForth for other legacy op. systems like CPM and DOS. According to the credits some of it goes back 1991. It uses Machin's algorithm. Most of the programs I have seen use the "spigot". I don't think they are the same so this could be an invalid comparison. It's pretty hairy code. It does some pretty neat dynamic memory allocation as well. The video is running on my indirect threaded system. It would go a bit faster on direct threading. I will try it. Spoiler \ PI.FTH from DxForth \ \ Revised 2015-02-09 es \ \ Compute Pi to an arbitrary precision. Uses Machin's \ formula: pi/4 = 4 arctan(1/5) - arctan(1/239) \ \ Compile with 16-bit DX-Forth: FORTH - INCLUDE PI.F BYE \ Compile with CAMEL99 Forth: INCLUDE DSK*.PI ( where * is your drive no.) \ \ This 16-bit implementation allows up to 45,808 digits \ to be computed before arithmetic overflow occurs. \ \ The code can be used on 32-bit targets with appropriate \ changes: \ \ 16-bit 32-bit \ \ 10000 Multiply 100000000 Multiply \ <# # # # # #> <# # # # # # # # # #> \ 4 +loop 8 +loop \ 525 um/mod 1050 um/mod \ remove 'digits > 45808' warning \ \ Acknowledgements: \ \ Roy Williams, Feb 1994 \ J. W. Stumpel, May 1991 \ E. Ford, Aug 2009 \ R. Bishop, Aug 1978 \ \ This code is PUBLIC DOMAIN. Use at your own risk. \ Modified for Camel99 Forth Mar 2021 Fox NEEDS D. FROM DSK1.DOUBLE NEEDS DUMP FROM DSK1.TOOLS NEEDS VALUE FROM DSK1.VALUES NEEDS .R FROM DSK1.UDOTR NEEDS ELAPSE FROM DSK1.ELAPSE DECIMAL 0 VALUE POWER ( adr) 0 VALUE TERM ( adr) 0 VALUE RESULT ( adr) 0 VALUE SIZE ( n) VARIABLE CARRY : ADD ( -- ) 0 CARRY ! RESULT 0 SIZE 1- DO I CELLS OVER + ( res) DUP @ 0 I CELLS TERM + @ 0 D+ CARRY @ M+ ( hi) CARRY ! ( lo) SWAP ( res) ! -1 +LOOP DROP ; : SUBTRACT ( -- ) 0 CARRY ! RESULT 0 SIZE 1- DO I CELLS OVER + ( RES) DUP @ 0 I CELLS TERM + @ 0 D- CARRY @ M+ ( HI) CARRY ! ( LO) SWAP ( RES) ! -1 +LOOP DROP ; 0 VALUE FACTOR \ scan forward for cell containing non-zero : +INDEX ( ADR -- ADR INDEX ) -1 BEGIN 1+ DUP SIZE - WHILE 2DUP CELLS + @ UNTIL THEN ; : (DIVIDE) ?DO I CELLS OVER + ( res) DUP @ CARRY @ FACTOR UM/MOD ( quot) ROT ( res) ! ( rem) CARRY ! LOOP ; : DIVIDE ( ADR FACTOR -- ) TO FACTOR 0 CARRY ! +INDEX ( adr index ) SIZE SWAP (DIVIDE) DROP ; \ scan backward for cell containing non-zero : -INDEX ( adr -- adr index ) SIZE BEGIN 1- DUP WHILE 2DUP CELLS + @ UNTIL THEN ; : MULTIPLY ( adr factor -- ) TO FACTOR 0 CARRY ! -INDEX ( adr index ) 0 SWAP DO I CELLS OVER + ( res) DUP @ FACTOR UM* CARRY @ M+ ( hi) CARRY ! ( lo) SWAP ( res) ! -1 +LOOP DROP ; : COPY ( -- ) POWER TERM SIZE CELLS CMOVE ; \ : ZERO? ( result -- f ) +INDEX NIP SIZE = ; 0 VALUE PASS VARIABLE EXP VARIABLE SIGN : DIVISOR ( -- N ) PASS 1 = IF 5 ELSE 239 THEN ; : ERASE 0 FILL ; : INITIALIZE ( -- ) POWER SIZE CELLS ERASE TERM SIZE CELLS ERASE PASS 1 = IF RESULT SIZE CELLS ERASE THEN 16 PASS DUP * / POWER ! POWER DIVISOR DIVIDE 1 EXP ! PASS 1- SIGN ! ; 0 VALUE NDIGIT : CalcPi ( -- ) NDIGIT 45800 U> IF ." Warning: digits > 45808 will be in error " CR THEN 2 1+ 1 DO I TO PASS INITIALIZE BEGIN COPY TERM EXP @ DIVIDE SIGN @ DUP IF SUBTRACT ELSE ADD THEN 0= SIGN ! 2 EXP +! POWER DIVISOR DUP * DIVIDE POWER ZERO? UNTIL LOOP ; \ Camel99 has OUT but I don't use in the Video driver \ : CR CR OUT OFF ; \ : # # OUT 1+! ; DECIMAL : (PRINT) ?DO 0 OVER ! DUP 10000 MULTIPLY DUP @ 0 <# # # # # #> TYPE SPACE VCOL @ 3 + C/L @ > IF CR THEN 4 +LOOP ; : PRINT ( -- ) CR RESULT DUP @ 0 .R [CHAR] . EMIT SPACE NDIGIT 0 (PRINT) DROP CR ; \ : GetNumber ( -- n ) \ CR ." How many digits do you want? " \ PAD DUP 20 ACCEPT NUMBER? ABORT" Invalid" CR ; : PI ( n -- ) ( GetNumber ) DUP TO NDIGIT \ array size = ceil(ndigit / log10(2^16)) 109 UM* 525 UM/MOD SWAP ( rem) IF 1+ THEN 2+ TO SIZE ( extra for accurate last digits) 50 ALLOT ( expand the HOLD buffer space) HERE TO POWER SIZE CELLS ALLOT HERE TO TERM SIZE CELLS ALLOT HERE TO RESULT SIZE CELLS ALLOT TICKER OFF CalcPi .ELAPSED PRINT ; \ end PI-100-DIGITS-ITC.mp4 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted May 5, 2022 Share Posted May 5, 2022 DTC is predictably a bit faster. Edit: I am still perfecting this DTC system. I realized that I used a "colon" alias for CELLS and old code for VALUES. Since I want this system to be optimized for speed not size, that is a faux pas. So this the result with the changes. 2 Quote Link to comment Share on other sites More sharing options...
