leech
Install guide for UAV with VBXE?
I've tried looking around a bit, but haven't had much luck.
Does anyone have a UAV with VBXE already installed guide?  Would like to make my normal monitor port work again, so I can just flip between outputs.
Thanks!
You can have VBXE without disturbing the normal video output.  Or did you remove the RF mod or something?
Ha, I sent it off to FJC to add all the things, and did not realize that with him removing the RF modulator to have the VBXE output in its place, that I would need to add the functionality back in.
You'd likely install the UAV as normal though the issue could be accessing the required pickup points and situating the board when installed.
By the looks the pickup points are early enough in the video circuit to not be affected by the RF mod being absent.
Note the video output of VBXE is totally independent but that also means no extra graphics stuff from UAV.
Yeah, it is just a matter of making the monitor port work again.  Ha, if you see my other thread, natively it looks like the 800xl monitor port has the best output, unless there is something wrong with my two 800s and the 130xe.
