krae_man
FS: Gamepark Systems GP32, GP2X, GP2X Wiz, Caanoo
Its a shame with that GP2X. I had a whole lot of fun with that device when it came out years ago. The description of the problem sounds like the voltage regulator chip...which is prone to failing on these. The batteries will no longer work and the thing gets hot on wall power. To make matters worse that chip is an SMD. If someone has the skill and a replacement chip they will be able to fix this, but I would not advise on wall powering it any more until it is fixed.
GP32, I have the same problem. The flash ROM chip is loosing it's contents for some reason, and it needs a reflash, which is almost impossible.
I built a special interface to do that, but I was unsuccessful, because the sw gave me an error.
Lots of those have that problem. I had one with the same thing years ago and was unable to fix it myself. What a shame...such great handhelds too.
I actually still use my GP2x Wiz.  I guess I might consider getting another as I am familiar with it.  How is the screen on yours?  A lot of them have spotting that gets worse and worse with time.
If you like the Wiz you should pick up that Caanoo. The best GPH device IMHO. I had both a black and a white one. They are awesome!
Screen is great. I can't see any problems. Everything looks perfect.
