IDE Card Group Buy ?
Shift838
4 hours ago, OLD CS1 said:
? If I didn't need to work I wouldn't be here, I'd be back home on the Last Frontier. ?
Okay, so technically not Canadiastani, but still pretty close.
Ya. I am way out there in the middle of nowhere, a 60 minute drive from Port Huron Mi.  :)
(Ok so maybe Port Huron is not NY City but hey. It's USA)
Question:  Where do I find the latest DSR and loader program for this beautiful blue play toy that I have here?
Answer: I found Fred's site and downloaded V14.
In other news... I powered up the card and looked at the DSR RAM in Forth.
Works fine. Filled it up with data and erased it etc from the command line.
I noticed that the 5V heat sink runs really hot. (I took it off and reinstalled it with some heat sink compound just to maximize heat transfer)
Build a floppy disk with the DSR and loader.
Latest DSR can be obtained from Fred's site.
http://www.ti99-geek.nl/
Thanks Chris.  I found it and ran the IDELOAD progam. Got all passes so good work by you.
I have an old 80Gb IDE drive that I know works cuz I put Linux mint on it for fun.
Should I be able to run CALL IDEST in BASIC with no drive connected but the board loaded?
Neither E/A BASIC nor XBASIC can find the sub-program.
1 minute ago, Shift838 said:
are you running my 838 clock module or the standard BQ4847 ?  I don't recall if you purchased both..
BQ4847.
I just went to reload the DSR and I tried to set the clock. It said the DSR was not loaded so the RAM did not retain the load.
I will try it again
if you wire a battery on it then you will also need a diode or a FET in series with the battery to help ensure to protect the battery from getting a surge of power and exploding.  At least that's how I understand it.
Be safe.. Buy my board!  ?
Edited by Shift838
  • 2 weeks later...
Have to do more testing, but have the same issue with the first card I tested.
DSR needs to be loaded again when I turn off the PEB overnight.
Guess the battery in the BQ is half-dead.
It’s not a very big deal as loading the DSR goes real quick with Fred’s FGROM IDE loader cartrdige image.
But obviously it means I need to set the time again as well.
  • 3 weeks later...
The BQ clock ship seems to have died and is no longer recognized, rendering the IDE card useless. Not a good day...
