manterola Posted March 19, 2020 Share Posted March 19, 2020 That's the question... I am trying to understand how A8cas works.. and I really don't know if everything was ok, it was a problem... where is the problem, etc. Thanks! Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted March 19, 2020 Share Posted March 19, 2020 If you are loading the CAS file into Altirra then with the debugger enabled you will see 'CAS' trace messages as blocks are loaded but you can also enable other logging, e.g. '.caslogdata', to provide extra detail SIO: Device $60[0], command $52, buffer $03FD, length $0083, aux $8000 timeout 45.0s | ? CAS: Reading block[02] = fa (pos = 159.727s) CAS: Reading block[03] = 5f (pos = 159.744s) CAS: Reading block[04] = 5f (pos = 159.761s) CAS: Reading block[05] = 5f (pos = 159.777s) CAS: Reading block[06] = 20 (pos = 159.794s) CAS: Reading block[07] = 2d (pos = 159.811s) CAS: Reading block[08] = 20 (pos = 159.827s) CAS: Reading block[09] = 2d (pos = 159.844s) CAS: Reading block[0a] = 20 (pos = 159.861s) CAS: Reading block[0b] = 2d (pos = 159.877s) CAS: Reading block[0c] = 20 (pos = 159.894s) CAS: Reading block[0d] = 2d (pos = 159.911s) CAS: Reading block[0e] = 20 (pos = 159.927s) CAS: Reading block[0f] = 2d (pos = 159.944s) CAS: Reading block[10] = 20 (pos = 159.961s) CAS: Reading block[11] = 2d (pos = 159.977s) CAS: Reading block[12] = 20 (pos = 159.994s) CAS: Reading block[13] = 2d (pos = 160.011s) CAS: Reading block[14] = 20 (pos = 160.027s) CAS: Reading block[15] = 2d (pos = 160.044s) CAS: Reading block[16] = 20 (pos = 160.061s) CAS: Reading block[17] = 2d (pos = 160.077s) CAS: Reading block[18] = 20 (pos = 160.094s) CAS: Reading block[19] = 2d (pos = 160.111s) CAS: Reading block[1a] = 18 (pos = 160.127s) CAS: Reading block[1b] = 3c (pos = 160.144s) CAS: Reading block[1c] = da (pos = 160.161s) CAS: Reading block[1d] = 44 (pos = 160.177s) CAS: Reading block[1e] = 5a (pos = 160.194s) CAS: Reading block[1f] = ba (pos = 160.211s) CAS: Reading block[20] = 46 (pos = 160.227s) CAS: Reading block[21] = 96 (pos = 160.244s) CAS: Reading block[22] = 36 (pos = 160.261s) CAS: Reading block[23] = 03 (pos = 160.277s) CAS: Reading block[24] = 29 (pos = 160.294s) CAS: Reading block[25] = 11 (pos = 160.311s) CAS: Reading block[26] = 36 (pos = 160.327s) CAS: Reading block[27] = 90 (pos = 160.344s) CAS: Reading block[28] = 2d (pos = 160.361s) CAS: Reading block[29] = 90 (pos = 160.377s) CAS: Reading block[2a] = 25 (pos = 160.394s) CAS: Reading block[2b] = 0e (pos = 160.411s) CAS: Reading block[2c] = 40 (pos = 160.427s) CAS: Reading block[2d] = 01 (pos = 160.444s) CAS: Reading block[2e] = 00 (pos = 160.461s) CAS: Reading block[2f] = 00 (pos = 160.477s) CAS: Reading block[30] = 00 (pos = 160.494s) CAS: Reading block[31] = 00 (pos = 160.511s) CAS: Reading block[32] = 14 (pos = 160.527s) CAS: Reading block[33] = 1d (pos = 160.544s) CAS: Reading block[34] = 07 (pos = 160.561s) CAS: Reading block[35] = 90 (pos = 160.577s) CAS: Reading block[36] = 22 (pos = 160.594s) CAS: Reading block[37] = 0e (pos = 160.611s) CAS: Reading block[38] = 40 (pos = 160.627s) CAS: Reading block[39] = 20 (pos = 160.644s) CAS: Reading block[3a] = 00 (pos = 160.661s) CAS: Reading block[3b] = 00 (pos = 160.677s) CAS: Reading block[3c] = 00 (pos = 160.694s) CAS: Reading block[3d] = 00 (pos = 160.711s) CAS: Reading block[3e] = 1b (pos = 160.727s) CAS: Reading block[3f] = 29 (pos = 160.744s) CAS: Reading block[40] = 36 (pos = 160.761s) CAS: Reading block[41] = 90 (pos = 160.777s) CAS: Reading block[42] = 2d (pos = 160.794s) CAS: Reading block[43] = 0e (pos = 160.811s) CAS: Reading block[44] = 40 (pos = 160.827s) CAS: Reading block[45] = 01 (pos = 160.844s) CAS: Reading block[46] = 00 (pos = 160.861s) CAS: Reading block[47] = 00 (pos = 160.877s) CAS: Reading block[48] = 00 (pos = 160.894s) CAS: Reading block[49] = 00 (pos = 160.911s) CAS: Reading block[4a] = 16 (pos = 160.927s) CAS: Reading block[4b] = f2 (pos = 160.944s) CAS: Reading block[4c] = 03 (pos = 160.961s) CAS: Reading block[4d] = 12 (pos = 160.977s) CAS: Reading block[4e] = 0f (pos = 160.994s) CAS: Reading block[4f] = 36 (pos = 161.011s) CAS: Reading block[50] = 99 (pos = 161.027s) CAS: Reading block[51] = 2d (pos = 161.044s) CAS: Reading block[52] = 40 (pos = 161.061s) CAS: Reading block[53] = 3a (pos = 161.077s) CAS: Reading block[54] = 82 (pos = 161.094s) CAS: Reading block[55] = 37 (pos = 161.111s) CAS: Reading block[56] = 90 (pos = 161.127s) CAS: Reading block[57] = 2c (pos = 161.144s) CAS: Reading block[58] = 2c (pos = 161.161s) CAS: Reading block[59] = 14 (pos = 161.177s) CAS: Reading block[5a] = 12 (pos = 161.194s) CAS: Reading block[5b] = 24 (pos = 161.211s) CAS: Reading block[5c] = 16 (pos = 161.227s) CAS: Reading block[5d] = 00 (pos = 161.244s) CAS: Reading block[5e] = 80 (pos = 161.261s) CAS: Reading block[5f] = 06 (pos = 161.277s) CAS: Reading block[60] = 06 (pos = 161.294s) CAS: Reading block[61] = 34 (pos = 161.311s) CAS: Reading block[62] = 16 (pos = 161.327s) CAS: Reading block[63] = 0d (pos = 161.344s) CAS: Reading block[64] = 48 (pos = 161.361s) CAS: Reading block[65] = 3a (pos = 161.377s) CAS: Reading block[66] = 43 (pos = 161.394s) CAS: Reading block[67] = 48 (pos = 161.411s) CAS: Reading block[68] = 49 (pos = 161.427s) CAS: Reading block[69] = 43 (pos = 161.444s) CAS: Reading block[6a] = 4b (pos = 161.461s) CAS: Reading block[6b] = 45 (pos = 161.477s) CAS: Reading block[6c] = 4e (pos = 161.494s) CAS: Reading block[6d] = 2e (pos = 161.511s) CAS: Reading block[6e] = 42 (pos = 161.527s) CAS: Reading block[6f] = 41 (pos = 161.544s) CAS: Reading block[70] = 53 (pos = 161.561s) CAS: Reading block[71] = 16 (pos = 161.577s) CAS: Reading block[72] = 5f (pos = 161.594s) CAS: Reading block[73] = 5f (pos = 161.611s) CAS: Reading block[74] = 5f (pos = 161.627s) CAS: Reading block[75] = 5f (pos = 161.644s) CAS: Reading block[76] = 5f (pos = 161.661s) CAS: Reading block[77] = 5f (pos = 161.677s) CAS: Reading block[78] = 5f (pos = 161.694s) CAS: Reading block[79] = 5f (pos = 161.711s) CAS: Reading block[7a] = 5f (pos = 161.727s) CAS: Reading block[7b] = 5f (pos = 161.744s) CAS: Reading block[7c] = 5f (pos = 161.761s) CAS: Reading block[7d] = 5f (pos = 161.777s) CAS: Reading block[7e] = 5f (pos = 161.794s) CAS: Reading block[7f] = 5f (pos = 161.811s) CAS: Reading block[80] = 5f (pos = 161.827s) CAS: Reading block[81] = 5f (pos = 161.844s) CAS: Reading block[82] = 20 (pos = 161.861s) CAS: Completed read with status 01 to buffer $03FD; control=FA, position=161.88s (cycle 5173633), baud=599.45s, checksum=B1 Quote Link to comment Share on other sites More sharing options...
Rybags Posted March 19, 2020 Share Posted March 19, 2020 I would presume a failure would produce a shorter file. From the Cas file format there's headers for each chunk. So probably several bytes fixed overhead then 138 or so bytes per record. I'd have though such utilities should give you some verbose logging option maybe? Quote Link to comment Share on other sites More sharing options...
