+dhe Posted March 19, 2020 Share Posted March 19, 2020 Hi, I downloaded the fortran (disk/files) available here on Atariage. Looking at the files - they have a TIFILES header. I'd like to use these with Classic99 - what is the easiest way to convert these to a compatible .dsk file? Also, so there an image for a DS/DD .dsk file for classic99? Thanks, Dano Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted March 19, 2020 Share Posted March 19, 2020 You can run them through TI Image Maker, TIDir, or just use a hex editor and chop off the first 128 bytes. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted March 19, 2020 Share Posted March 19, 2020 put them in a folder in the classic99 directory and point classic99 DSK1 at them? in FIAD mode they work directly from there.. use one of the tools to copy them into a dsk like tidir etc. You can create a dsdd disk image in tidir under File, create new dsk image Quote Link to comment Share on other sites More sharing options...
+dhe Posted March 19, 2020 Author Share Posted March 19, 2020 Thanks for the heads up, it took me a while to figure out the combo of tidir and settings in classic 99 to make everything happy.. I'm might not be done, but I'm on my way. I eventually, through a long journey had to go the *.dsk route, as the fortran compiler is really coded for dsk.fortcomp.* - so in this case the disks name was essential. d. Quote Link to comment Share on other sites More sharing options...
Tursi Posted March 20, 2020 Share Posted March 20, 2020 (edited) Don't make disk images for Classic99 - they are a compatibility concession. Primary disk interface is raw files in a folder on Classic99. The disk name can be emulated with folders, name the folder with the name of the disk, and it /should/ work. For instance, if the folder on your disk was named "C:\Classic99\FORTCOMP", then "FORTCOMP" would be the disk name. The TI search is case-sensitive, so that matters. At least, it's supposed to. A quick test just now shows it's returning the last 10 characters of the path instead of just the last folder, so I'll fix that. (Edit: it's working for normal DSK.DISKNAME.FILENAME access, it just shows up wrong in the sector emulation. So feel free to use it now. ) Edited March 20, 2020 by Tursi 1 Quote Link to comment Share on other sites More sharing options...
+dhe Posted March 20, 2020 Author Share Posted March 20, 2020 Thank you for your work on the emulator. I initially tried to use WorkShop to rename the disk, that of course didn't work out well for me! Quote Link to comment Share on other sites More sharing options...
