towmater #1 Posted March 20, 2020 I'm Googled out... does anyone know of a video mod for 2600's that does not require removal/cutting of existing components? I'm imagining a circuit board that plugs into the Tia Maria chip and intercepts the video while simply not continuing the output to the existing modulator circuitry. Quote Share this post Link to post Share on other sites
+-^CrossBow^- #2 Posted March 20, 2020 The UAV doesn't require removing any components from the main board far as I know. I know it doesn't require it on the 7800 or 5200. I believe you just have to tap the needed LUM and sync signals off the main board and feed them to the UAV. It has its own encoder to output separately. Can even keep the RF intact and working that way if you wanted. https://thebrewingacademy.com/collections/atari-2600/products/tba-ultimate-atari-video-uav-board-for-atari-2600 Quote Share this post Link to post Share on other sites
towmater #3 Posted March 20, 2020 (edited) 1 hour ago, -^CrossBow^- said: https://thebrewingacademy.com/collections/atari-2600/products/tba-ultimate-atari-video-uav-board-for-atari-2600 Thanks, I ordered one, hopefully it will arrive while I still have all this free time. Edited March 20, 2020 by towmater Quote Share this post Link to post Share on other sites
towmater #4 Posted March 26, 2020 (edited) On 3/20/2020 at 12:15 PM, -^CrossBow^- said: The UAV doesn't require removing any components from the main board far as I know. I know it doesn't require it on the 7800 or 5200. I believe you just have to tap the needed LUM and sync signals off the main board and feed them to the UAV. It has its own encoder to output separately. Can even keep the RF intact and working that way if you wanted. It was fairly straightforward, although I had to bypass their color signal and attach directly to the motherboard, as seen here on the bottom. I'm assuming it doesn't really make a difference. Any ideas from where to tap audio? Edited March 26, 2020 by towmater Quote Share this post Link to post Share on other sites
towmater #5 Posted March 26, 2020 Meanwhile, I've tried a 24MB and a 1GB card formatted as Fat12, Fat16, and Fat32, but I always only get this error on the Harmony. Any suggestions are welcome! Quote Share this post Link to post Share on other sites
towmater #6 Posted March 30, 2020 I'm gonna try bumping this just once before turning it into a Harmony thread... anyone know how to format an SD card for the Harmony, as nothing I have tried seems to make it happy? I updated the firmware via USB without issue. Quote Share this post Link to post Share on other sites
Keatah #7 Posted March 30, 2020 Any mod can be non-destructive. Just depends on how you choose to do the work. Desoldering and lifting out parts instead of cutting them permanently. Executed with a bit of thought, every mod can be undone and the unit returned to stock. I hate that mod where they tell you to cut out the RF modulator and break off the connector. Just desolder it instead!! Quote Share this post Link to post Share on other sites
gbennett0321 #8 Posted March 30, 2020 On 3/25/2020 at 6:32 PM, towmater said: Meanwhile, I've tried a 24MB and a 1GB card formatted as Fat12, Fat16, and Fat32, but I always only get this error on the Harmony. Any suggestions are welcome! Try checking to make sure you have only one partition on the SD card. If you've previously used it for other purposes (e.g Raspberry PI, etc.) you might have some other partitions on the card. You can check for the partitions in Windows by going to the Administrative tools/Computer Management application. Quote Share this post Link to post Share on other sites
Brian W. #9 Posted May 13, 2020 I'm planning on a 7pin Svideo Size jack that's through Hole. It's the same diameter as the RF jack. I can add Svideo, Composite, Ground, And Stereo out on it. I'm also building 2 custom cables for it. I'll be my own system I do this to. I was hoping to find a Sega rev 2 jack that was though hole, but I can't find any beyond PCB mount styles. It's a more common standard that would allow any assortment of cable purchases if another is ever needed, vs repairing a failed cable in the future. This project is only in the planning stages, so I don't have any examples to share. Quote Share this post Link to post Share on other sites
