leech
Atari Touch Tablet, not working on my 800XL...
Yet it works on one of my 800s and 130XEs (I haven't tested the other two, nor my other 8bits yet, but it doesn't work on my original 800XL).
Fun thing is, my stock 130XE has kind of a crap video output.  Long vertical lines coming out of it when using Composite or S-Video.  The 800XL looks fantastic in both (well as good as composite seems to get) and after I patched in the wire for Chroma, it looks really good.  But Atari Artist is rather crap with the Touch Tablet not working.  The buttons all work, but when touching the stylus or with my finger, it doesn't move.
With the stock 130XE, I went through and tried RAMbrandt, Diamond Desktop and Blazing Paddles, and none of them seemed to work correctly (RAMbrandt and Blazing Paddles both just moved the cursor up).
My guess is that there is some weird inconsistencies on the systems, guess I could try the same software on the 800XL and 800 to see if it is the same issue.
Any ideas?
completely confused, does it work properly on any machine?
are your machines putting the proper voltage out at the joypad ports?
if yes then it's pokey, PIA, support chips in that order, with the caveat that the passive parts like coils, resistors, and caps connected to the joypadio ports aren't crispy ( I've seen a couple 800XL's with crispy port parts ) last stops are GTIA and the rest of the chips
Edited by _The Doctor__
From memory the X/Y pos of the surface comes over the POT lines.  The tablet buttons come through the paddle buttons aka the stick left/right directions and the stylus button is the stick trigger.
You could try a simple Basic program to test the inputs:
10 ? PADDLE(0),PADDLE(1),PTRIG(0) ; PTRIG(1), STRIG(0) : GOTO 10
For testing in port 2, change the parameters to the controller functions to 2,3,2,3,1 in that order.
PIA problems would see the tablet buttons not work.  GTIA problem would see the stylus button not work.  POKEY or external cap dump problem would see the X/Y surface not work.
Yes, it works in Atari Artist on both the 130XE and 800.  On the 800XL, the buttons are working, but the stylus/touch to move the cursor does not.  I will try to check the voltages to the ports, and see if anything is crispy.
Perfect, I can give that a shot.  I think it was RAMbrandt if I changed the option in there that the tablet worked, but up/down position was flipped.  This was on the 130XE.
Touch not working - then it's the POTs.  It might be a low or missing +5V line on the port there.  Other functions working means the GND is probably OK.
If you're in there then may as well lift and reseat Pokey as well.
The culprit was pin 5!  It was broken within the joystick port.  So for now I stole the one from my 7800 that is just a bare motherboard anyhow (I have a spare).  Ordered some new ones, to replace that one.
Now it's working :)  I also noticed the other joystick port on my 800xl has part of it's plastic broken off, so I can replace that as well when the new ones come in.
