Shift838
IDE card components (hard to find items found)
So i have found a supplier for some of the harder to find components that has some stock and willing to sell.
If anyone want's to go in with me when i order a few I can get them added to the order.
RTC-65271 (Epson - original clock chip used by Thierry in his design.  has option for replaceable batteries!)  $10.00 each
767143220G (CTS 7x22Ohm array 200mw) $1.50 each
M68Z512W-70NC1 (original 512k SRAM used in card) $5.50 each
these are all the original and they come from one distributor.  If anyone want's in let me know via PM and we can work out a paypal.
  • Like 4
3 minutes ago, FarmerPotato said:
Is that a 220 ohm array? I’m looking at Mouser now. Does it match pinout with a new one?
https://www.mouser.com/ProductDetail/Bourns/4608X-101-221LF?qs=%2Fha2pyFadujGrwpxGSma51gvPokZCwAar6UktZ%2FCb%2Fnq5CFgv9kryg%3D%3D
I was in need of the 220-330 ohm dual terminator. They’re very cheap new.
no the one for the ide card is a SOIC14 package Isolated and needs to be .2 w or higher.
Righto. The Bourns equivalent for $0.60 is in SOM14 . But  its leads extend out to 7.62 mm while the SOIC14 leads extend out to 6 mm.
https://www.mouser.com/datasheet/2/54/4800P-777115.pdf
It might not fit on the pad.
I guess you have the best price on the original chip.
I looked at these Bourns too and came to the same conclusion on the leads.
Depends on what you want to do with the IDE card and this clock chip... but a quick look at the datasheet told me that this clock chip has 128 pages of 32 bytes, that is a total of 4096 bytes. I also don't see a pin that can supply a (backup) voltage to the RAM chip like the other clock chips do Thierry used/mentioned. IMHO this is not the correct clock chip to go for.
BTW: The size of my DSR for the IDE card is about 8Kb +9*4Kb = 44Kb
Fred ;-)
Posted (edited)
If I'm correct with my previous statement:
Brain wave alert: You can also create a little board with an extra 3V battery (and the transistors\resistors\diodes as I did for the HDX project) and use this as backup for the RAM chip and place it at one of the other clockchip locations.
Fred
Edited by F.G. Kaal
Fred
interesting.  I did not even think about that one!
will be putting more feelers out then to see if I can locate a BQ4847YMT the original one we all used for the original buy.
although these batteries in this unit cannot be replaced, with a little dremel work and a 3v battery holder a new battery can be wired up once the battery dies.
I have found the original BQ4847YMT real time clock chip.  The supplier has quite a bit and are willing to sell them at $8.00 each + shipping
The chip on the top, in the socket, is my (defective) original one,
the one in the red foam was a helpless try to replace it...
Posted (edited)
I've got three of these 58167 RTC chips.. I've always wondered if I could interface one with the TI..
eneral Description
The MM58167B is a low threshold metal gate CMOS circuit
that functions as a real time clock in bus oriented microproc-
essor systems. The device includes an addressable real
time counter, 56 bits of RAM, and two interrupt outputs. A
POWER DOWN input allows the chip to be disabled from
the rest of the system for standby low power operation. The
time base is a 32.768 kHz crystal oscillator.
Y Microprocessor compatible (8-bit data bus)
Y Milliseconds through month counters
Y 56 bits of RAM with comparator to compare the real
time counter to the RAM data
Y 2 INTERRUPT OUTPUTS with 8 possible interrupt
signals
Y POWER DOWN input that disables all inputs and out-
puts except for one of the interrupts
Y Status bit to indicate rollover during a read
Y 32.768 kHz crystal oscillator
Y Four-year calendar (no leap year)
Y 24-hour clock
Edited by GDMike
I think i may have found a suitable replacement for the clock chip.  It will require me to make a adapter for it.  TI tells me it should work in theory and all I have to do is add a crystal and 3v battery to it and of course the external SRAM since it has the ability to control SRAM.
It has the same pinout as the BQ4847YMT.  I may give this a shot one of my boards to test.  The clock chip is of course made by TI, it's the BQ4802YDW and is 5v.
Edited by Shift838
  • Like 6
