The SNUG HRD16 uses the following battery:   ER6C (AA-size) 3,6 Volts Lithium
Questions:
- Is this a battery or a rechargeble accu ? (I think it is an accu, and it seems to have 1800 mAh)
- Is it okay to pay about 20 euros for this ?
(Maxell:)
PS: I see this accus now with 2400 mAh for ~6 Euros, is this OK ?
Edited by Schmitzi
1 hour ago, Flottmann1 said:
yeah this is exactly the one I spotted on ebay :)
So this is a NON-rechargable one, right ?
The Problem is, the pins will not work perfectly, but maybe I have to fiddle it
PS: If battery only, why not taking the one from Reichelt.de in the pic about, for 6,22 eu.
It´s cheaper and has the right pins
Edited by Schmitzi
Important on these is the voltage (3.6V), one with more power 2,400 mAH vs. 1,800 mAH will just last a little longer. Note: Lithium batteries like these are NOT rechargeable!
Can I use a rechargeable one, or does the board not support (charge) it ?
I don't think that board has a recharge circuit. It was designed for the Lithium batteries, as they last 7-10 years, sometimes longer.
Hi Ksarul,
sorry for asking again :) but, so it is that way that I can use ANY battery with 3.6 Volts or do I need this special "ER6C" type ?
Backgound: The Maxell ER6C comes with 1800 mAh and costs about 20 euros, and there are other ones for 5 euros,
and they have up to 2600 mAh. So they are cheaper, and  should work (save) much more longer ?
thx
Coming from here:
the question was:
The only .DSK [for the SNUG HRD16] I found in my snug directory is the "ROS8.14-F16". This one ?
And there are some HRD16*.P99-files which I don´t know to handle, and that are not mentioned in the manual.
Edited by Schmitzi
you can copy the p99 with TI-DIR on a emty DSK, look at the PDF at the SNUG Side
ah ok.
(I searched through the PDFs but I didn´t find "p99" so I just tried it  )
Edited by Schmitzi
