BobZ #1 Posted March 30, 2020 I use a mouse for 2600 games that normally use a paddle (Warlords, Kaboom,etc). but the direction is reversed....left is right and right is left. I have the full Stella users manual but don’t see where I could reverse that so left=left and right=right. I’ve tested a bunch of setting changes with no luck! any suggestions? Bob Quote Share this post Link to post Share on other sites
ave1 #2 Posted March 31, 2020 Here's an option: At around 4min 40 seconds to 5 min 10 seconds pay close attention. 1 Quote Share this post Link to post Share on other sites
BobZ #3 Posted April 1, 2020 That’s cool. I’m saying I use a mouse but it’s actually mouse internals inside of an Atari Paddle that I built. So it’s really still a mouse, much like the build you posted. What’s odd is that if I run Stella on my PC it works as expected. When I run Stella from my RetroPie (my default), the control is reversed. Even weirder...inside Stella on the RetroPie, you can also use the mouse in Stella for navigating all of the config menus. My mouse/paddle goes in the correct direction inside Stellas menus!!! Then I exit the config menus and the mouse is back to reverse. So I really thought the solution resides inside the Stella configs somewhere. I haven’t found where so far! I like the fidget spinner controller, that’s great. Maybe I’ll build that too....stuck indoors with extra time! Quote Share this post Link to post Share on other sites
Thomas Jentzsch #4 Posted April 2, 2020 You can reverse the paddle x axis directions in the Game Properties/Controllers dialog. Quote Share this post Link to post Share on other sites
BobZ #5 Posted April 2, 2020 Yes, I’ve tried that. I methodically tested every permutation on the Game Properties/controllers tab. I can always just run Stella from my PC if I want to play a paddle game I guess! Not sure why Stella on Linux (RetroPie) is giving me this issue. Plus I could create a spinner like the video above - you can change the axis physically on the spinner by adjusting it. So there’s that. I definitely have a few work around options. Just bummed I can’t get this to work as expected! Quote Share this post Link to post Share on other sites
Thomas Jentzsch #6 Posted April 2, 2020 So "Paddles_IAxDr" does not work? BTW: Without any info, I have to assume you are using the latest version of Stella. Quote Share this post Link to post Share on other sites
BobZ #7 Posted April 2, 2020 Paddles_IAxDR is the setting I use. That works best. It’s reversed as I was saying...and other setting are pretty lousy. If I press the TAB button to get to the Stella config menus, the mouse goes in the correct direction!! WTF. Exit the menus and I’m in reverse for game play. I tried the Stella version RetroPie uses by default then I upgraded to whatever version it uses when you tell it to go out to the github Stella site and get the most recent. I think the issue is the Stella on Linux or whatever version you get with RetroPie. I can stick to Stella on my PC but I use RetroPie for all of my game emulators. It would be nice to have it all in 1 place. Quote Share this post Link to post Share on other sites
Thomas Jentzsch #8 Posted April 2, 2020 Now I am confused. Why are you using Paddles_IAxDr instead of just Paddles? No wonder that the axis is reversed. Quote Share this post Link to post Share on other sites
BobZ #9 Posted April 3, 2020 Just “Paddles” produces terrible results - jittery, jumpy, etc.... I’ve already tried every combination of settings. The only one where my mouse works well is IAxDR. But the motion is reversed. Any other settings produce an unusable result. I just built a quick test version of the spinner as in the video posted on here - that works well. I’ll just build that for my RetroPie. I’ll stick to the mouse/paddle in Stella for the PC version. Quote Share this post Link to post Share on other sites
Thomas Jentzsch #10 Posted April 3, 2020 Paddles and Paddles_IAxDr are identical, except for the reversed axis. So if one is jumpy and one is not, this makes no sense. Sorry, I am running out of ideas. Quote Share this post Link to post Share on other sites
BobZ #11 Posted April 4, 2020 That’s okay, I appreciate the suggestions. Makes no sense to me either. I’ll just use it for PC Stella. I just made a quick and dirty spinner like the video showed as it works great!!! Link here: Quote Share this post Link to post Share on other sites
