Bee Posted April 4, 2020 Share Posted April 4, 2020 I will start out saying I had the 502 ST, then 1040 ST, the a Mega ST 4. Back in the day. After I sold my Mega ST4, I picked up a used Atari Mega ST2. It was a quick deal on Craigslist back in the 90's and 1 out of 4 times it would white screen and lock up. I pulled it out after reviving my 1040ST, and the Mega ST2 is a no go after it's last boot 17 years ago. I tried 3 different power supplies and the same result. So I decided to get a 1040STE and pump it up to 4 megs of RAM off eBay. It boots and runs as one would expect with 2 strange observations. No matter what I do if I change to medium resolution and save the desktop it boots back to low resolution. Also I realized I have no sound coming form my color monitor and no way to control the volume. "It's not you it's me" It dawned on me the problem is probably my lack of knowledge on the STE and updated software I don't have. Can anyone enlighten me on what I'm looking for? I'm assuming a newer control accessory? Thank you Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted April 5, 2020 Share Posted April 5, 2020 It's known bug of TOS 1.06 of STE - that resolution problem with Save Desktop. You need TOS 1.62, where it is fixed. Quote Link to comment Share on other sites More sharing options...
Bee Posted April 5, 2020 Author Share Posted April 5, 2020 (edited) Is it worth going to TOS 2.06 on a 1040STE? Thank you Edited April 5, 2020 by Bee Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted April 5, 2020 Share Posted April 5, 2020 (edited) I love v2.06 and much prefer it to earlier versions. However, in the interest of compatibility what you may want to do is install a TOS switcher - that way you can boot up into what ever version you need/want. PS Keep in mind, going from TOS v1.6 to v1.62 is a matter of simply swapping 2 chips. It's a bit more difficult to install a TOS switcher. Edited April 5, 2020 by DarkLord Additional info provided. Quote Link to comment Share on other sites More sharing options...
Bee Posted April 5, 2020 Author Share Posted April 5, 2020 Problems mostly sorted, now need to upgrade the simms. Thanks for the replies. Where do I find the TOS 1.62 chips? Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted April 5, 2020 Share Posted April 5, 2020 I can send you programmed EPROMs with TOS 1.62, or with multiple TOS versions - up to 4 . Considering switchable TOS: 2.06 is not good for gaming, while it has much better Desktop than TOS 1.xx . TOS switch is really easy to make - if you can do little soldering. Need only to bend little highest address pin(s) and connect it to switch. With it you select which section of EPROM is active, so which TOS is active. Quote Link to comment Share on other sites More sharing options...
zzip Posted April 6, 2020 Share Posted April 6, 2020 On 4/5/2020 at 12:38 AM, Bee said: Problems mostly sorted, now need to upgrade the simms. Thanks for the replies. Where do I find the TOS 1.62 chips? I might actual have a legit set that I removed from my STe when I upgraded to 2.06, is this a US system? Quote Link to comment Share on other sites More sharing options...
Bee Posted April 7, 2020 Author Share Posted April 7, 2020 (edited) It is a US system. I'm seeing the "flaws" of 1.06 now I connected a Hard Drive. Thank you Edited April 7, 2020 by Bee Quote Link to comment Share on other sites More sharing options...
zzip Posted April 7, 2020 Share Posted April 7, 2020 11 hours ago, Bee said: It is a US system. I'm seeing the "flaws" of 1.06 now I connected a Hard Drive. Thank you I looked, and the 1.62 roms aren't where I thought they were. I may have thrown them in as a 'bonus' when I sold my STe Quote Link to comment Share on other sites More sharing options...
Bee Posted April 7, 2020 Author Share Posted April 7, 2020 No worries, Thanks for looking. I have a set of Simms coming later this week, I will open up my STE and check the DMA chip, upgrade the Ram. Then I will follow up with @ParanoidLittleMan, your offer is very kind. There is a learning curve for sure beyond the Mega 2 ST. Thank you Quote Link to comment Share on other sites More sharing options...
